IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory
Bran
Hello! Long time lurker to this forum, decided it was finally time to get my feet wet by sharing a recent experience.
IATF FAQ #7 for External Laboratory states:
QUESTION 1: When can the equipment manufacturer be used to calibrate inspection and test equipment? If an accredited laboratory exists but is very remote and/or expensive and the inspection or test equipment manufacturer is nearby and available can they be used (even if they are not accredited to ISO/IEC 17025)?
ANSWER 1: The inspection or test equipment manufacturer developed the methodology to maintain and adjust the equipment to meet calibration requirements as part of the design and manufacture of the inspection or test equipment. Therefore, the original equipment manufacturer of the inspection and test equipment is qualified to calibrate the equipment they designed and manufactured.
The organization shall obtain customer approval before using any original equipment manufacturer for calibration services.
My organization recently went through a Stage 2 IATF audit. The auditor came across one of our OEM calibration suppliers who is not ISO 17025 accredited, and we had no record of any customer approval to use this OEM for calibration services. Naturally the conversation went to the section discussing OEMs, needing to meet the requirements listed in 7.1.5.3.1, from which there was evidence to show, such as the lab's scope document, their ISO 9001 cert, etc.
We still ended up with a finding against IATF 7.1.5.3.2 because there was no record of customer approval of the OEM calibration service. The auditor based his decision on the FAQ #7 comment (in red above), which reads like an IATF requirement.
This FAQ forces customer approval to use OEMs providing calibration services. Was this always the requirement and I was misinterpreting the intention, or does the FAQ add the requirement of customer approval?
morteza
Hi Bran,
Good Question,
At first I should mention that this FAQ has added a new requirement to clause 7.1.5.3.2 (like a SI, but we know that FAQ only clear the current requirement without adding any new requirement. So, one of the reasons that can justify your auditor finding is the following requirement in IATF 16949 clause 7.1.5.3.2:
- there shall be evidence that the external laboratory is acceptable to the customer.
If we accept that this requirement also apply to the following requirement of clause 7.1.5.3.2:
Calibration services may be performed by the equipment manufacturer when a qualified laboratory is not available for a given piece of equipment.
The FAQ would be right. but we know that IATF only requires the organization to ensure that the requirements listed in Section 7.1.5.3.1 have been met.
Another justification would be that in the case of FAQ#7, there is an accredited laboratory exists but is very remote and/or expensive. Based on clause 7.1.5.3.2 the organization is allowed to use the equipment manufacturer for calibration service when a qualified laboratory is not available for a given piece of equipment. When there is a laboratory, it should meet at least one of the following conditions:
- accreditation to ISO/SEC 17025 or national equivalent
- Customer approval
for this reason FAQ#7 has required the organization to obtain customer approval.
Anyway, I think this question has the potential to be answered by IATF oversight offices.
Golfman25
It's a "clarification" (i.e, rewrite) of the requirement. Not much you can do but get customer approval. Good luck.
Bran
Thank you both for your input.
The RCA for this gave actions to address the "systemic issue" by:
(1) identifying all OEM calibration suppliers we use (I believe this number may be 15-30 for my organization)
(2) contacting each of our automotive customers (close to 100 for us...) to get their approval to use each of the OEM suppliers listed above
Problem here is obviously getting this done within the time frame for the IATF CAR.
I could understand getting customer approval for new line setup, or new business, but many of the calibration OEMs we use have been in use by my organization for decades and we have been supplying customers up to this point with no history of issues. Also, a good number of these calibration OEMs do not have anything to do with product measurement devices; for example we have many EHS-related devices in place, or other devices to meet internal requirements.
For most IATF items up to this point I have been able to make a business case, showing how the new requirement would benefit either my organization or the customer. This one I'm struggling with. If each customer does not approve a calibration OEM, there is no alternative equipment or source. The equipment is too specialized and/or antiquated to the point where we're already locked into using the OEM. Even if replacement or upgrade of equipment (in order to make it serviceable by a 17025 accredited lab) was an option, this would be cost prohibitive in almost all cases.
Golfman25
All true. And your customers will be shaking their heads asking why they have to do this. But it is what it is. Make up a letter and see if you can get some approvals to close it out. Then work on the rest before the next audit. Good luck.
Hi Bran,
I am curious how did it go with closing this non-conformity? We received the same one and we are in similar situation, however only have two customers.
Thank you.
Bran
Hi Bran,
Thank you.
I sent an email to the customers which included a list our OEMs performing calibration services, asking for approval to use the OEMs. I limited the email distribution to only those customers who were on our CSR matrix, so only those customers that are either IATF subscribing or have a CSR document per the IATF definition (these would be most visible to our auditors).
Surprisingly, I did get approval email responses from most on the list within a week or two. Only 1 of the "big 3" questioned a single item on the list - the SQE didn't agree that only the OEM could perform calibration for one of the devices, he challenged us to find an alternative calibration lab. I explained that moving away would take much longer than the time I had to close out the finding, eventually he agreed.
Our CSR matrix has changed since the time of the audit, so I will need to send a few more emails to capture approvals of the new customers added prior to the next audit.
D IATF 16949 FAQ 24 (8.4.2.2 Countries of Destination) - How is this actually being interpreted? IATF 16949 - Automotive Quality Systems Standard 3
U IATF 16949 8.4.2.2 FAQ 24 - Countries of destination IATF 16949 - Automotive Quality Systems Standard 3
H New FAQ & SI -IATF 16949 - Effect in april and june 2018 IATF 16949 - Automotive Quality Systems Standard 0
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 4
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 11
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
