IATF 16949 9.2.2.3 - Manufacturing process audits
Hendor
Hi everyone,
My plan is to reduce the number of audits that are scheduled. I share a little of my current situation and some doubts.
Our bussines is metal stamping, molding and spot welding assemblies, for example we have 20 presses, 10 molding equipment and 25 welding cells. in total 55 work center (That is, I have 3 different manufacturing processes: Stamping, Molding, Welding).
My internal audit program (annual) for 9.2.2.3 manufacturing process audits. The programming and audit is by work center; that is to say, to the year they are 55 audits to the year (one for each press, molding equipment and welding cell) * In some cases the frequency is higher due to performance, risks, criticality, etc.).
My goal is to make this audit program light. In 9.2.2.3 The requirement as I understand it is to audit all the manufacturing processes, (and we have 3: Stamping, Molding, Welding).
Using this criteria can be 3 audits per year, one to each process. (They could be more in agreement with the risks, performance, etc).
From all this I have come some doubts that within the main ones are:
Is there a requirement that you are omitting me? (without thinking about CSR)
♦ How could a good sampling plan be applied? I have in mind something similar to this:
Stamping
2019 - Sample includes: Press # 1, # 3, # 5, # 8, # 10, # 15, # 20
2020 - Sample includes: Press # 2, # 4, # 9, # 13, # 15, # 19
2021 - Sample includes: Press # 6, # 7, # 11, # 14, # 18
♦ Taking this as an example: Should I include all work centers in the 3 year period?
I would appreciate your comments and apotaciones.
regards
QChas
Involved - Posts
Hi everyone,
Stamping
regards
As an ISO Injection Molder with 28 presses, when we audit the injection molding process we look at a sample from machines (maybe 5 different presses). We do not audit all 28 presses. I also am interested in the response since we are in the preliminary stages of looking at IATF16949. Will we need to do 28 audits vs the sample of 5 for this process?
Pjservan
Your manufacturing processes need to include all the steps that are called out in your Control Plan, so you need to take that into account. THere is no requirement to audit all work stations but all processes within a 3 year schedule. Your plan ought to be design around the complexity, performance, risk, etc and customer requirements, of course.
Golfman25
Following on Pservan. You can split your manufacturing audits into two types. What you have laid out is a good general manufacturing audit based on each work center to ensure each work center is doing the basics they are required -- everything is identified, paperwork filled out, etc. You an also do "manufacturing process audits" which will essentially follow a part thru Stamping, molding and welding (or whatever processes the parts go thru). There, you can pick a few parts per customer and audit those to the control plan. You'll pick up and customer specific issues that way as well. Good luck.
Rahul26692
I have come across a NC regarding laboratory personnel after testing material in our inhouse laboratory have not signed his testing report.
after asking i have found that he have just taken print outs and filed without signing .
So what should i give root cause, corrective action and preventive action for this ? please suggest
KimGr
You have to figure out why he was just doing it that way (or didn't know he shouldn't) and what in your system allowed it to happen before you can figure out corrective action. Is there a procedure or work instruction? Is it trained?
Rahul26692
Yes he is trained even though he has not done in that way. Procedure and WI are present but there is absence of signing authority after Report has been made.
Rahul26692
Thanks for the reply
Advice for the future: Rather than asking a question in a thread that's only peripherally related to your topic, you should start a new thread.
What you seem to be saying is that when asked why an unsigned report was filed, the person responded that an unsigned report was filed. That doesn't seem like an appropriate response to me. Some questions you might want to ask:
  • Before engaging in full-fledged CA, what are the risks involved? Is a simple correction all that's needed?
  • Are hand signatures really necessary? Is there a simpler way to indicate on the reports who the person was who did the testing?
  • Is it necessary to retain paper copies of test reports?
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 6
J Manufacturing Process Auditor Requirements - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
bettsaj IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
B IATF 16949 - Different Registrars for remote and manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 2
V IATF 16949 Manufacturing Process & Product Audits IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
M IATF 16949 - Cl. 8.3.3 - Product design inputs, manufacturing process design inputs IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
A IATF 16949 Cl. 8.3.5.2 e) - Manufacturing Process Flow Charts & Layout IATF 16949 - Automotive Quality Systems Standard 5
Q IATF 16949 9.2 Internal Auditor IATF 16949 - Automotive Quality Systems Standard 13
Vader22 INTELEX software for their IATF 16949 QMS IATF 16949 - Automotive Quality Systems Standard 0
D Preparing for IATF 16949 Letter of Conformance Stage 1 audit IATF 16949 - Automotive Quality Systems Standard 4
D Is it required to have the operator initial their work in the IATF 16949:2016 standard? IATF 16949 - Automotive Quality Systems Standard 3
X IATF 16949 Section 3.2 Change of ownership IATF 16949 - Automotive Quality Systems Standard 2
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Sidney Vianna IATF 16949 News IATF News - Top 10 IATF 16949 nonconformities and more..... IATF 16949 - Automotive Quality Systems Standard 7
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
V IATF 16949 GM CSR 10.2.4 Error-proofing requirement IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 5
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 19
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
