IATF 16949 Audit MSA
s00067824
Hi Guys,
Our annual IATF audit will be happening in a couple of weeks. I am new to the company so this will be my first experience with an audit like this. I carry out all the MSA's and am just curious about what kind of questions to expect from the auditor? I am afraid I will be asked something that I won't have an answer to and already feel nervous about it.
All help and advice much appreciated.
Thanks in advance :)
It's almost impossible to tell you what any specific auditor will ask. Some know MSA better than others. My advice is not to let them ask questions, take control of the audit by confidently demonstrating what it is you do. Job done!
Marc
Fully vaccinated are you?
The key is that you do MSA's and the assumption is you understand MSA. Remember that. The only time there may be a problem is if you do not understand what you are doing.
You should also have a copy of the AIAG's MSA manual. As Andy said about auditors:
Over the years I have seen many auditors who did not understand a variety of requirements, not to mention have any expertise in various areas, one of which is MSA and statistics in general. Never assume the auditor is more knowledgeable than you are.
You you are competent and you know your job. Be confident in that. Don't let an auditor scare you.
Mr.Ruiz
Hi Guys,
I carry out all the MSA's and im just curious about what kind of questions to expect from the auditor?
As Marc and Andy already said, try to look into your process, and try to match the MSA requirements to your company, just ask to yourself "are all the type of studies being done?" "did we consider MSA studies for visual inspections?" "are all methods and/or criteria for acceptance defined?" "any of them requires customer approval?"
Remember that any NC Finding not necessary represent a negative matter, it might be an opportunity to reinforce your system.
This might be slightly off-topic, but this is the only place I see on the forum where MSA for visual inspections is mentioned...
When visual verification is indicated in control plan for workmanship criteria (presence of machined features, absence of burrs, etc.) in a strictly CNC-based industry that produces no products with appearance criteria, is there a simple method of keeping a "Visual MSA" on file? I was under the impression that any kind of MSA for visual inspections would only apply if there were appearance criteria involved, but I also want to make sure we're prepared if this question comes up next year.
There is no such thing as a "visual MSA," as such. There is an attributes MSA, which is used in Go/No-Go cases where actual measurement data isn't used. If there are control plan requirements for visual inspection, and there are related specific acceptance criteria, you need to do an attributes study.
Mr.Ruiz
Like Jim said, you can cover them with the attribute study. If you have an acceptance criteria for those type of controls in your control plan, you need to ensure that your measurement system is "in shape" or you might deliver bad product to your customer, that's why those type of study are required.
Golfman25
A lot will depend on your auditor. Most of us normal people use "visual inspection" to look for obvious defects and issues -- i.e.; is the package damaged when taken off the truck, scratches, is the hole there, etc. Don't really need an MSA for that. Of course if you put that into your control plan, then all heck breaks loose when a goofy auditor comes in and wants to see the MSA. We get around it by making it a reference note in our control plan as opposed to a "control" item. Stupid if you ask me.
Contrast that from a situation where you using visual inspection criteria to verify colors or something similar. Then it may be worthwhile to do an MSA.
I agree completely! :bonk:
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
B Remote IATF 16949 audit preparation General Auditing Discussions 10
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
QMMike IATF 16949 Audit Day Requirements IATF 16949 - Automotive Quality Systems Standard 4
Ashland78 IATF 16949 9.2.2.1 - How often do we have to audit entire IATF Manual IATF 16949 - Automotive Quality Systems Standard 6
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
C Acquiring an IATF 16949 Certified Company - What happens at the next audit? IATF 16949 - Automotive Quality Systems Standard 4
PastorBee13 IATF 16949 Audit Nonconformance Responses per 5.1.1.2 - Format IATF 16949 - Automotive Quality Systems Standard 11
Ashland78 IATF 16949 Internal Audit Checklist Manufacturing and Related Processes 11
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 3
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
F Information Technology in IATF 16949 audit scope IATF 16949 - Automotive Quality Systems Standard 14
A Man Days for IATF 16949 Audit IATF 16949 - Automotive Quality Systems Standard 5
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
T Example wanted - Template for internal audit IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
D IATF 16949 surveillance audit frequency IATF 16949 - Automotive Quality Systems Standard 16
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
A IATF 16949 - 9.2.2.1 Internal Audit Programme - looking for example IATF 16949 - Automotive Quality Systems Standard 5
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
M IATF 16949 - Multiple Locations - 3rd party audit scope IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 9.2.2.1 - Internal audit program - Types of evidence Internal Auditing 1
S Second Party Audit - GM IATF 16949 CSR September 2017 General Auditing Discussions 0
T Example System & Process Audit Check Sheet for IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
M Who has had a Transition Audit from TS 16949 to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 120
P IATF 16949 - Internal Audit Frequency Requirements Internal Auditing 2
Q IATF 16949 Strategy - Audit Team Requirement IATF 16949 - Automotive Quality Systems Standard 4
Q Rule 5.2h - Site Separation - Audit Manday Calculation (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 17
Q Scheduling IATF 16949 Audits - Audit Man-Days IATF 16949 - Automotive Quality Systems Standard 12
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
tony s TS 16949 Internal Audit Trainer Traceability to IATF General Auditing Discussions 6
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 1
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
