IATF 16949 Audit Nonconformance Responses per 5.1.1.2 - Format
I have a couple non-conformances to respond to from our IATF 16949 audit a few weeks ago but I'm unsure of the best format to use for the responses. Fortunately, my auditor was kind enough to simply state a section of the rule book. Unfortunately, I only have the mini version of the standard and those rules aren't in it. Is someone able to tell me what the rules require for audit responses from section 5.1.1.2? It would be greatly appreciated.:):)
Golfman25
Your CB should be able to provide guidance -- maybe even the specific format they want. I know ours is online. You'll basically need to do an 8D. Their big focus will be on the root cause analysis and effectiveness of your corrective actions. Good luck.
Sidney Vianna
Post Responsibly
As previously mentioned, your CB should provide you with guidance/format/forms etc for you to respond with containment, root cause analysis and corrective action, but you seem to be asking for proposed corrective actions for CB reported nonconformities related to paragraph 5.1.1.2, Process effectiveness and efficiency. Is that right? We can’t help if we don’t know exactly what the actual non conformance is. There is no “default” boiler plate corrective actions for nonconfomities related to a section of the standard, so please clarify what exactly you are asking for.
Howard Atkins
Forum Administrator
There is no real secret
from the rules
5.11.2 Client responsibility for a minor nonconformity
The certification body shall require the client to submit, within a maximum of sixty {66} calendar days from
the closing meeting of the site audit, evidence of the following:
a} implemented correction;
b} root cause including methodology used, analysis, and results;
c} implemented systemic corrective actions to eliminate each nonconformity, including consideration of
the impact to other similar processes and products;
d} verification of effectiveness of implemented corrective actions.
Any standard 8 D or similar answers all these requirements
Most CBs give a form on a portal to answer.
you can use 5 whys or fishbone.... whatever yoy want, as long as you can identify rootcause, correction, corrective action
By the way have you been given minor or major NC?
Thanks for the input guys. They are all minor non-conformances. Everything thus far has been "a little info here, a little there. Trip over it and I'll tell you when you hit the ground". On top of that I'm waiting a long time for responses from them when I submit stuff.
One of my responses includes a form - a checklist - that we will use to make sure we have everything accounted-for when planning a PPAP. The auditor rejected it because it wasn't a record yet - it was just a blank form. Am I supposed to pretend that I have a PPAP to do in order to fill out the form? Mind you, the actual correction has already been made. This is the result of "mistake-proofing" so it doesn't happen again.
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 20
B Remote IATF 16949 audit preparation General Auditing Discussions 10
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
QMMike IATF 16949 Audit Day Requirements IATF 16949 - Automotive Quality Systems Standard 4
Ashland78 IATF 16949 9.2.2.1 - How often do we have to audit entire IATF Manual IATF 16949 - Automotive Quality Systems Standard 6
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
C Acquiring an IATF 16949 Certified Company - What happens at the next audit? IATF 16949 - Automotive Quality Systems Standard 4
Ashland78 IATF 16949 Internal Audit Checklist Manufacturing and Related Processes 11
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 3
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
F Information Technology in IATF 16949 audit scope IATF 16949 - Automotive Quality Systems Standard 14
A Man Days for IATF 16949 Audit IATF 16949 - Automotive Quality Systems Standard 5
S IATF 16949 Audit MSA IATF 16949 - Automotive Quality Systems Standard 10
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 9
T Example wanted - Template for internal audit IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
D IATF 16949 surveillance audit frequency IATF 16949 - Automotive Quality Systems Standard 16
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
A IATF 16949 - 9.2.2.1 Internal Audit Programme - looking for example IATF 16949 - Automotive Quality Systems Standard 5
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
M IATF 16949 - Multiple Locations - 3rd party audit scope IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 9.2.2.1 - Internal audit program - Types of evidence Internal Auditing 1
S Second Party Audit - GM IATF 16949 CSR September 2017 General Auditing Discussions 1
T Example System & Process Audit Check Sheet for IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
S Has anyone completed IATF 16949 Certification - Share your Audit Experience? IATF 16949 - Automotive Quality Systems Standard 2
M Who has had a Transition Audit from TS 16949 to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 120
P IATF 16949 - Internal Audit Frequency Requirements Internal Auditing 2
Q IATF 16949 Strategy - Audit Team Requirement IATF 16949 - Automotive Quality Systems Standard 4
Q Rule 5.2h - Site Separation - Audit Manday Calculation (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 17
Q Scheduling IATF 16949 Audits - Audit Man-Days IATF 16949 - Automotive Quality Systems Standard 12
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
tony s TS 16949 Internal Audit Trainer Traceability to IATF General Auditing Discussions 6
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Sidney Vianna IATF 16949 News IATF News - Top 10 IATF 16949 nonconformities and more..... IATF 16949 - Automotive Quality Systems Standard 7
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
