IATF 16949 Cl. 7.5.1.1 d - Customer Requirements - How are people addressing?
jfriess
Under quality management system requirements,"d" states a document (matrix) indicating where within the organization's quality management system their customer requirements are addressed. My question is how are people addressing this? Just a reference to customer requirements or a correlation matrix... Or something I haven't thought of...
QualityTaz
Last week on Friday IATF put out some Sanctioned Interpretations see Item #5 they do not require a matrix it can be a table or a list indicating where within your organization customer specific requirements are address. Example: You could create a list of all your customer with hyperlinks to each of the customer specific requirements. You also should be aware they also released revision 4 of the transition strategy document.
howste
Thaumaturge
Thanks for the heads-up. Here are direct links to the new documents:
IATF 16949:2016 Sanctioned Interpretations #1-9 (SIs)
IATF 16949 Transition Strategy and Requirements REV04
howste
Thaumaturge
Those aren't "interpretations." They are flat out changes. Just more evidence that they rushed this thing thru.
I have to say that I agree. You can't use the published standard now without crossing out existing text and adding the new text from the "interpretations." :rolleyes:
Scanton
Wearer of many hats
Just to pop this one back on topic, although I have to say thank you for venturing off as this is very interesting indeed and makes me wonder what exactly I will be audited against a year from now.
Our auditor was looking for something similar to the file attached, I suppose it makes is easy to find what you need during an audit is regards to the standard, our documented QMS and the CSR's.
I would be interested in hearing your thoughts and seeing how other people managed the relationship between their QMS and the CSR's.
  • CSR Matrix - Issue 2.xlsx
Blaest
Is there any requirements regarding the implemenations of QMS CSR?
Clause 7.5.3.3 mention '10 working days' but in relation to engineering standards/specifications and that is for the review, not the implementation.
howste
Thaumaturge
There is no timing for implementation of CSRs mentioned in IATF 16949. Some CSRs have an "effective date" on them, so the customer expects implementation by that date.
Realistically at the time of any IATF audit, the auditors would expect to see evidence of implementation of any new requirements, evidence that internal auditors (and second-party auditors) have an understanding of the changes. Also having evidence that the implemented changes have been audited would be a good idea.
If you look at new CSRs the week before the audit it's probably too late to get all this done. It should be an ongoing process to review and implement CSR changes in a timely manner.
Golfman25
That's actually a bit complicated. I would only be interested in the CSRs which change our obligations under the standard. For example, it seems every customer has their own twist on PPAP. So starting with the light blue section is fine, but then I would just highlight where the customer requirements differs from the standard.
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
octavio tarango Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
D Customer Specific Requirements / Distributors (IATF 16949) Customer and Company Specific Requirements 1
K IATF 16949 "if required by the customer" Internal Auditing 7
E IATF 16949 Cl. 8.2.3.1.2 - Customer-designated special characteristics IATF 16949 - Automotive Quality Systems Standard 1
T IATF 16949 - Customer Authorization for Concession or Deviation Permit IATF 16949 - Automotive Quality Systems Standard 22
D IATF 16949 Cl. 4.3.2 - Customer Requirements vs. Customer Specific Requirements IATF 16949 - Automotive Quality Systems Standard 55
B IATF 16949 Cl. 4.3.2 - Meeting Customer Specific Requirements IATF 16949 - Automotive Quality Systems Standard 13
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
K Need Help With IATF 16949 Audit NC IATF 16949 - Automotive Quality Systems Standard 6
F IATF 16949 Clause 8.5.1.5 - OEE, MTTR, and MTBF Calculation IATF 16949 - Automotive Quality Systems Standard 2
M HOW TO Self Study on IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 8
Q IATF 16949 9.2 Internal Auditor IATF 16949 - Automotive Quality Systems Standard 13
Vader22 INTELEX software for their IATF 16949 QMS IATF 16949 - Automotive Quality Systems Standard 0
D Preparing for IATF 16949 Letter of Conformance Stage 1 audit IATF 16949 - Automotive Quality Systems Standard 4
D Is it required to have the operator initial their work in the IATF 16949:2016 standard? IATF 16949 - Automotive Quality Systems Standard 3
X IATF 16949 Section 3.2 Change of ownership IATF 16949 - Automotive Quality Systems Standard 2
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Sidney Vianna IATF 16949 News IATF News - Top 10 IATF 16949 nonconformities and more..... IATF 16949 - Automotive Quality Systems Standard 7
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
octavio tarango IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
V IATF 16949 GM CSR 10.2.4 Error-proofing requirement IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 5
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 19
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
