IATF 16949 Cl. 8.4.2.2 vs 8.6.5 - Is there any difference between these clauses?
morteza
Dear friends,
I have read the clause 8.4.2.2 and 8.6.5 many times, and actually I could not see any difference in their underlying content, both require to ensure that purchased/externally provided products or process conform to statutory and regulatory requirements of different countries.
Do you see any difference?
Ferreira_Portugal
Hello all,
Also I didn't see a relevant difference among both clauses !
Just if for the clause 8.6.5 is expected that the organization defines a method to check the compliance of the purchased products against the statuory and regulatory requirements. (For exemple during PPAP phase check IMDS, reach and conflict minerals compliance).
For the clause 8.4.2.2 is more complicated to understand the applicability of the requirement. Seems to be the same.
AMIT BALLAL
8.4.2.2:
This clause speaks about defining the process (Procedure) about how you'll ensure that applicable statutory and regulatory requirements are met by external providers.
Planning phase.
Documented procedure is required.
8.6.5:
This clause speaks about actual implementation. Ensuring that applicable requirements are met by external providers as defined in the process (Procedure) as per requirement of 8.4.2.2.
Records are required, as specified in the procedure.
Do phase.
These are my observations about the standard.
I hope it helps.
Thanks,
Amit
Qualbug
Hello, Can someone comment on which statutory / regulatory requirements are in the scope of these clauses? I saw a couple examples above, but are there others about which we should be concerned? How would one go about determining the regulatory requirements of a particular country? To what level / scope is expected?
David J Quality
IATF Statutory & Regulatory Requirements
Good morning my fellow Elsmar friends!
I've got a question....
Can someone explain the difference in clause 8.4.2.2 "Statutory and Regulatory Requirements" and clause 8.6.5 "Statutory and Regulatory Conformity"? Seems redundant.
Thanks for any clarity!
David
David J Quality
I would also like to understand how one is able to find the "S&R" requirements of all of these countries. :confused:
Re: IATF Statutory & Regulatory Requirements
8.4.2.2 requires you to have a documented process to ensure that purchased products meet the legal requirements.
8.6.5 requires you to have evidence that all products that you ship meet the legal requirements.
Hi All,
completly agree with this explanation.
We just had a transition audit and it's was also explained like this by auditor.
In IATF you must have a process, procedure showing how you work and process all above requirements for example :
Customer sends RFQ-> Sales dept. is processing it togheter with R&D-> They need to check which legal requirements should be included-> Then they should transfer it to Purchasing so they can apply it in supplier chain-> Suppliers need to confirm within quotation phase.
You need to describe it, make a flow chart, assign responsibilities etc.
It can be connected with IMDS, REACH, Special methods and standards used in different countries for example flammability requirements etc.
In big organizations usually Legal department should be involved.
Hope it helps
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 3
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
C IATF 16949 - Scope or not? IATF 16949 - Automotive Quality Systems Standard 2
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
D IATF 16949 FAQ 24 (8.4.2.2 Countries of Destination) - How is this actually being interpreted? IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 5
J IATF 16949 8.4.1.2 Supplier selection process IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 CAPITULO 7.3.2 IATF 16949 - Automotive Quality Systems Standard 3
Casana IATF 16949 7.1.5.3.2 External Laboratory - On Site Calibration IATF 16949 - Automotive Quality Systems Standard 8
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
