IATF 16949 Cl. 8.4.2.3 - Supplier Quality Management System Development
joekirk
This clause is "Supplier quality management system development".
Does this section only apply to "traditional" suppliers as defined by GM as "Suppliers are defined as organizations that are providers of production materials, or production or service parts, directly to an organization who is a provider of General Motors or other customers subscribing to this document. Also included are organizations who are providers of heat-treating, painting, plating or other finishing services."
I have had several auditors and consultants give conflicting answers when asked if this section applies to suppliers and/or "providers of externally provided products, processes and services".
Example: ABC company gets gauges calibrated by an out side company (DEF company). I know DEF is a provides of externally provided products, processes and services, but is the calibration company (DEF in this case) considered a supplier and is Clause 8.4.2.3 applicable to them?
Coury Ferguson
Moderator here to help
In the Aerospace Industry (AS9100, ISO9001), all of the above referenced are considered suppliers. A supplier is defined as "any product, services, processing provided outside of the organization (my definition)" are suppliers. But ones that provide office supplies and such could be excluded in the control, in my opinion.
Johnnymo62
Haste Makes Waste
I believe the clause defines itself.
The organization shall require their suppliers of automotive products and services to develop...
Only automotive product and service suppliers need ISO9001.
mbehmazia
The way I interpret this clause, an IATF certified organization only has to make sure their key suppliers are ISO9001 compliant via second party audits. However, the standard also states, "unless notified by the customer" so the IATF certified organization can waive this requirement.
C.R.V.G.
Quality Engineer
Good day!
I'm not sure how to initiate another discussion topic in this forum so I'm posting on this one because I think it fits best.
Our company is in transition to IATF 16949 and will be certified on May/18. Recently we had an internal audit already based on IATF 16949 requirements along with a gap analysis between TS and IATF. Going directly to the point, it was evidenced a non conformity in the clause 8.4.2.3, since we were not able to show any criteria for stablishing a minimum acceptable level and the target level for the QMS of each supplier.
My question is: could anyone please share some good practices or methods for determining minimum and target QMS levels? We are still thinking on a solution for that, but we're afraid to let our method too subjective and get another non conformity on the certification audit.
Thanks a lot for the attention!
Golfman25
Good day!
To me it's pretty clear. You need them to at a minimum be ISO 9001 certified, or approved by your customer. Then they should have some planned progression toward IATF or a reason why full IATF wouldn't be applicable, i.e.; not enough auto business.
lmamao
My interpretation is only the suppliers that affect directly to customer requirements (this could be from components to packaging), this would include calibration, what is out of this scope are things like office supplies, cleaning supplies, etc.
C.R.V.G.
Quality Engineer
Ok, I think I wasn't clear enough on my point... sorry for this...
IATF 16949 and its SI made it clear about minimum and target QMS. This is clear to us.
So... during the internal audit, the auditor from our consulting company suggested to plan some kind of decision score, which would determine initial & target QMS requirements for each supplier. He suggested some kind of score based on component criticality (not critical, functional, safety) technology/process domain and KPI performance. Multiplying the 3 criterias (like a RPN), the score (according to a score table) would show us:
- The minimum QMS level required for this supplier
- Which one should be upgraded to next QMS level
- Which one should only keep the current QMS level
The QMS levels could be:
- ISO 9001 requirements met and confirmed through 2nd party audit (and approved by customers
- 3rd party certified ISO 9001
- 3rd party certified ISO 9001 + MAQMSR requirements met
- 3rd party certified ISO 9001 + IATF 16949 requirements met and confirmed through 2nd party audit
- 3rd party certified IATF 16949
Point is (for example): XYZ Steel is one of our suppliers. Currently this supplier is ISO 9001 certified. The cl. 8.4.2.3 objective is to "upgrade" all suppliers to IATF 16949 certification, but XYZ Steel automotive market share is 5% of their revenue and our company represents not even 1% of their revenue. In short, this means that they won't upgrade their QMS just because of us.
Is anyone here working with a prioritizing method such as the above? Please share, if possible.
Sorry for the long text :tg:
Golfman25
I suppose you can make it as complicated as you want, depending upon what you need it for.
But I would avoid a strict numerical "grade." You'll find and auditor who says once you are 0.5 over the grade, you move to the next level. I would make is as discretionary as possible. And what about your supplier. Do they have input? I expect a lot of push back from suppliers who aren't primary automotive. The new standard is just too burdensome for many. So their plans are important. Like your example of XYZ steel. They could be really critical, and really good, and really resistant to IATF based on their customer base.
C.R.V.G.
Quality Engineer
Yeah... you're right. We thought this way too and we believe that this is the best option. We'll try something more subjective, although mainly based on risk analysis.
Our IATF transition audit is in May, so let's see what happens :D
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
P IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J IATF 16949 8.4.1.2 Supplier selection process IATF 16949 - Automotive Quality Systems Standard 4
noratkhen Eligibility to get a IATF 16949 certificate for a Tier N>3 supplier? IATF 16949 - Automotive Quality Systems Standard 25
B IATF 16949 Supplier QMS Requirements IATF 16949 - Automotive Quality Systems Standard 3
A IATF 16949 Cl. 8.4.1.2 Supplier Selection Process - assessment example IATF 16949 - Automotive Quality Systems Standard 11
P Supplier (Vendor) Evaluation Criteria - IATF 16949 Cl. 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 1
H Sorting Supplier Requirements - IATF 16949 Cl. 8.4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
E IATF 16949 Cl. 8.4.2.5 - Supplier Development Type and Extent IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949 Cl. 8.4.2.2 - Country of Receipt - The provider's or supplier's country? IATF 16949 - Automotive Quality Systems Standard 5
S IATF 16949 Supplier Management - Supplier Tooling Requirements Supplier Quality Assurance and other Supplier Issues 1
B IATF 16949 Cl. 7.1.5.3.2 - External Laboratory Sub-Supplier Requirements IATF 16949 - Automotive Quality Systems Standard 2
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 11
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
