IATF 16949 Cl. 8.4.2.3 - Supplier Quality Management System Development
vincee
#11
CRVG, I received a minor during transition audit from TS 16949 to IATF for not having a plan in place to develop the supply base that are only ISO and "compliant to" TS 16949.
What i believe is required here is to have a plan, which can be having the supply base complete a IATF gap analysis or readiness survey.
I am too hoping that someone out there has an example wiling to share of a ISO 9001 IATF gap analysis or readiness survey?
Vince
AMIT BALLAL
#12
Vince
Enclosed herewith a sample document. Feel free to edit and use.
vincee
#13
Thanks CRVG, still hoping that someone out there has an example to share of a ISO 9001 to IATF gap analysis or readiness survey?
Long story short I received a minor for item 8.4.2.3 of the standard during transition audit from TS 16949 to IATF for not having a plan in place to develop the supply base that are ISO certified only but are "compliant to" TS 16949 Std.
What I believe is required as a solution to the minor is to have a plan in place displaying suppliers are working to the IATF. Hoping someone can share an IATF gap analysis or readiness survey from ISO 9001:2009 to becoming IATF 2016.
Vince
#14
Vince
Who said you had to have a plan? An IATF gap analysis won't help you here.
All you need to do is inform your suppliers - many of whom will ignore you - that you require them to comply with the IATF requirements. Of course, some won't be able to, but that's another story...
vincee
#15
Good Morning Andy, the Lead Auditor stated this during our audit on June 6, which I received a minor finding. According to Clause 8.4.2.3 there is a "Sanctioned Interpretation" from IATF that was effective June 1, 2018 stating "the organization shall require their suppliers of automotive products and services to Develop, Implement, and Improve a QMS with the ultimate objective of becoming certified to this Automotive QMS Standard".
Prior to this "Sanctioned Interpretation", we were Compliant to all IATF's 8.4.2.3 October 2016(1st Edition) requirement's.
#16
Indeed! However having a "plan" and "shall require" are 2 different things in my mind. Sending an email out to suppliers to warn them of this requirements (which, as I have experienced they will thumb their collective noses at because the "spend" you have is too small for them to bother) and having a "Plan" to develop suppliers is waaaay different. Did you auditor write the NC for not having a plan? I don't see the word plan in any IATF requirement (or SI)?
AMIT BALLAL
#17
Andy, agree with you that there is no shall. But, standard states a sequence towards IATF certification. Some suppliers can be upgraded directly from ISO 9001 certification to IATF if they are having enough automotive business. Whereas for others, different sequence might be needed (as specified in 8.4.2.3).
What auditor might be asking is what's their plan (documented or undocumented) to upgrade suppliers from ISO 9001 to IATF.
What you are suggesting is also fine, but is vincee's organization planning to upgrade all suppliers directly to IATF or only some of them at present? This plan he has to demonstrate (documented/ undocumented won't matter).
Sent from my CPH1821 using Tapatalk
AMIT BALLAL
#18
How you were complying with 8.4.2.3? I would like to know in order to answer correctly. Because, only change in this clause is removal of first stage of QMS development i.e. "compliance to ISO 9001 through second party audits".
#19
Agreed, Amit. I'm questioning the accuracy of the auditor's NC which states a "plan" isn't available...
Golfman25
#20
I think it depends on the "definition" of plan. I think what they are really looking for is some criteria as to which suppliers should have completed which step and what moves them to the next level. In our case, we where asked to become compliant with the minimum IATF standards with the statement that we wouldn't do full IATF certification due to the low volume of auto work we do. However, that will change over the years and we may kick into IATF sooner than we want. :)
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
P IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J IATF 16949 8.4.1.2 Supplier selection process IATF 16949 - Automotive Quality Systems Standard 4
noratkhen Eligibility to get a IATF 16949 certificate for a Tier N>3 supplier? IATF 16949 - Automotive Quality Systems Standard 25
B IATF 16949 Supplier QMS Requirements IATF 16949 - Automotive Quality Systems Standard 3
A IATF 16949 Cl. 8.4.1.2 Supplier Selection Process - assessment example IATF 16949 - Automotive Quality Systems Standard 11
P Supplier (Vendor) Evaluation Criteria - IATF 16949 Cl. 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 1
H Sorting Supplier Requirements - IATF 16949 Cl. 8.4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
E IATF 16949 Cl. 8.4.2.5 - Supplier Development Type and Extent IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949 Cl. 8.4.2.2 - Country of Receipt - The provider's or supplier's country? IATF 16949 - Automotive Quality Systems Standard 5
S IATF 16949 Supplier Management - Supplier Tooling Requirements Supplier Quality Assurance and other Supplier Issues 1
B IATF 16949 Cl. 7.1.5.3.2 - External Laboratory Sub-Supplier Requirements IATF 16949 - Automotive Quality Systems Standard 2
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
