IATF 16949 Cl. 8.4.2.3 - Supplier Quality Management System Development
QualitySpirit
#41
It's not clear where you are getting this from. 8.4.2.3 applies only to "suppliers of automotive products and services." Requiring Office Depot to be ISO certified is silly.
Definition of supplier from ISO9000:2015
3.2.5 provider /supplier
organization (3.2.1) that provides a product (3.7.6) or a service (3.7.7)
If it only applies to suppliers of automotive products and services, all of these suppliers are eligible for IATF16949 certification.
Then the SI#8 revised should not have added the word "eligible organizations"
In addition, it adds the rationale for changes giving example scrap metal suppliers, trucking companies who provide transport and logistics support, etc.. Are scrap metal suppliers, trucking companies suppliers of automotive products and services?
And according to this SI#8 revised, scrap metal suppliers, trucking companies need ISO9001 certification, right?
AMIT BALLAL
#42
Not true any more as the new SI made it such that all suppliers not just automotive ones are applicable for this requirement e.g. minimum ISO9001 certified or customer approved+second party audit to ISO9001. Now even suppliers who supply pens, toilet papers would need ISO9001 certification by a recognized CB under IAF MLA.
Sorry to say, but interpretation is wrong. Is stationary supplier an automotive product or service supplier? Definitely not. In that case, 8.4.2.3 is not applicable to them. 8.4.2.3 is specifically for automotive products and services supplier.
Reason for sanctioned interpretation is that unless the supplier is manufacturing automotive product, they are not eligible for IATF certification. Scrap metal suppliers, logistics are not eligible for IATF certification, since they don't manufacture any automotive product.
AMIT BALLAL
#43
Unless the supplier is manufacturing an automotive product, it is not eligible for IATF16949 certification. Service suppliers are not eligible for IATF16949 certification.
The SI is nowhere saying that scrap metal suppliers, trucking companies should be ISO9001 certified. This requirement is only for suppliers of automotive products and services.
Credit of all this confusion goes to IATF. :applause::frust:
It seems like IATF will have to release one more standard just for FAQs and SIs on IATF16949.
QualitySpirit
#44
Service suppliers are not eligible for IATF16949 certification..
This is wrong. Organizations that do not produce any products but provide services such as Heat treatment services can be IATF16949 certified.
If it is not the requirement, what is the point the IATF mentioned them in the sanctioned interpretation of the requirement clause for suppliers that require ISO9001 certification or customer approval.
AMIT BALLAL
#45
Is heat treatment a service or manufacturing? I consider it manufacturing. And IATF also considers it as manufacturing. Refer IATF rules 5th edition page 6 for the same.
Purpose for release of sanctioned interpretation is to clarify that only organization manufacturing automotive product can be certified to IATF16949, others are not eligible.
If any supplier is providing automotive product or service, it has to follow the sequence of QMS development as specified in 8.4.2.3. If scrap metal suppliers, logistics coming under your organization's definition (based on functioning / your organizational needs) as automotive service supplier, then it should be ISO9001 certified.
QualitySpirit
#46
Is heat treatment a service or manufacturing? I consider it manufacturing. And IATF also considers is as manufacturing. Refer IATF rules 5th edition page 6 for the same.
If by the scope wording, I consider heat treatment a service.
The certification scope will be -
"Manufacturing of XXX", if they produce products.
And "Provision of XXX services" if they receive parts, components or materials from their customers, process them with XXX services and deliver to customers. such as Provision of assembly services, Provision of EDP coating services, Provision of heat treatment services.
QualitySpirit
#47
Do you mean the organization has a freedom to define by their own what service suppliers are or aren't automotive service supplier based on their functioning/ organization needs?
AMIT BALLAL
#48
Assembly, heat treatment is manufacturing, not service. You have to follow definitions of standard, you can't use your own definitions.
QualitySpirit
#50
Ok. In your opinion, if an organization does not buy any materials/components to produce their own products but they have assembly lines/heat treatment lines and workers and their business is to process components/materials supplied from their customers and deliver assembled/heat treated automotive products to the customers.
1) Are they eligible for IATF16949 certification?
2) If they are eligible what would the CB write as the scope of certification in their IATF16949 certificate?
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
P IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J IATF 16949 8.4.1.2 Supplier selection process IATF 16949 - Automotive Quality Systems Standard 4
noratkhen Eligibility to get a IATF 16949 certificate for a Tier N>3 supplier? IATF 16949 - Automotive Quality Systems Standard 25
B IATF 16949 Supplier QMS Requirements IATF 16949 - Automotive Quality Systems Standard 3
A IATF 16949 Cl. 8.4.1.2 Supplier Selection Process - assessment example IATF 16949 - Automotive Quality Systems Standard 11
P Supplier (Vendor) Evaluation Criteria - IATF 16949 Cl. 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 1
H Sorting Supplier Requirements - IATF 16949 Cl. 8.4.2.3 IATF 16949 - Automotive Quality Systems Standard 8
E IATF 16949 Cl. 8.4.2.5 - Supplier Development Type and Extent IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949 Cl. 8.4.2.2 - Country of Receipt - The provider's or supplier's country? IATF 16949 - Automotive Quality Systems Standard 5
S IATF 16949 Supplier Management - Supplier Tooling Requirements Supplier Quality Assurance and other Supplier Issues 1
B IATF 16949 Cl. 7.1.5.3.2 - External Laboratory Sub-Supplier Requirements IATF 16949 - Automotive Quality Systems Standard 2
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 6
