IATF 16949 Clause 10.2.4 - Error Proofing
H
htozturk
#11
Re: IATF 16949 Clause 10.2.4 - Error-proofing question
Hello Everyone. I am little bit confused about "verification of challenge parts". Does anyone have an auditor point of view on how to proceed verification of the challenge parts? I have an end line tester checking function and missing sub part. To do verification of challenge parts by the tester sounds not logic. Should these parts be initially verified by third party at first?
optomist1
A Sea of Statistics
#12
although it may not be stated in 16949, when using EP Masters (known good "Gold Rabbit" and bad "Red Rabbit"), the masters must be controlled, for example access limited to line/shift supervisor, and stored to prevent unauthorized access/use.....
#13
This hasn't been true in my experience, at least insofar as limiting access to test parts to leadership. These green & red rabbits need to be available at point of use, and are typically used by equipment operators. Competency for how to verify error-proofing is part of the training operators are documented to, and associated Work Instructions call out the ID(s) of the rabbits to be used. This is why a master list of green/red rabbits should be maintained, and these are typically subject to periodic calibration verification (as with gaging) if they confirm an under or over-sized dimensional characteristic. Not so much on the calibration if the red rabbit verifies that the e-p device can detect a missing component (shields, rods) or presence of a feature (machined keyway or timing mark).
The CP/ PFMEA will call out the error-proofing device ("Poka #123") but the rabbits themselves usually only on the associated WIs.
V
vivkrish
#14
I agree with you that the frequency of error proofing device verification should be documented somewhere.
But in control plan normally they only list controls over product characteristics, and process parameters.
For example:
Product characteristics Measuring equipment Frequency
Dimension Error proofing device 100%
Process parameters Measuring equipment Frequency
Air pressure Pressure gage at M/C start of shift
It would take some modification to include the frequency of the error proofing device in the control plan. How should we write the control plan?
Error proof verification frequency should be incorporated in Control plan.
You have separate column in control plan, that possess inspection size and frequency..
you should add your error proof verification frequency in the above.
H
htozturk
#15
In fact, i was focusing the verification of green rabbits. I dont think that it will be enough to put them in to end line tester and see green light saying that "this part is OK".
My opinion is, as an example, one part should be verified by customer or designer mentioning as "OK part (green rabbit)". Then verification of this green rabbit (ex. each month) could be done by end line tester. I hope it has clear explanation :confused:
#16
Agreed, it should be a "known good part" and this should be demonstrated by up to and including a layout, or short of that it should have met all criteria for a good part in your control plan. Generally haven't seen the Customer approve the specific green rabbit
Re-verification of the part should match the process by which it was initially approved. This may involve individuals beyond the end line tester (layout or calibration personnel) and is periodic. End of line tester uses green/ red rabbit to ensure ongoing function of the error-proofing device. Don't have the standard in front of me, but this is generally done at the start of each shift...
Andy63
#17
Error-proofing device failures shall have a reaction plan.
Do they mean Mistake proofing rather than error proofing?
Stijloor
#18
Mistake proofing, Error proofing, Poka Yoke, etc., are all the same.
#19
This may not be relevant to IATF, but Shigeo Shingo made a distinction between mistake proofing and error proofing in his book. His distinction was that a mistake proof was something put into place in the process (e.g., sensor), while an error proof was a change made to the product design (e.g., a notch to prevent misalignment).
Stijloor
#20
Per IATF 16949:2016, 3.1 Terms and definitions for the automotive industry
Page 12: Error proofing
Product and manufacturing process design and development to prevent manufacture of nonconforming products.
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
QChas IATF 16949 Clause 8.5.1.2 - C -Standardized Work IATF 16949 - Automotive Quality Systems Standard 1
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 clause 8.3.4.3 Prototype programme IATF 16949 - Automotive Quality Systems Standard 0
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 9.2.2.2 - Which QMS Processes are Included IATF 16949 - Automotive Quality Systems Standard 1
J What are sample documents of IATF 16949 Clause 8.6.4 a? IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable IATF 16949 - Automotive Quality Systems Standard 64
M IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition Compliance IATF 16949 - Automotive Quality Systems Standard 38
M Exclusion of IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 13
M Compliance with IATF 16949 Clause 8.3.4.4 Product Approval Process IATF 16949 - Automotive Quality Systems Standard 2
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
P IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls IATF 16949 - Automotive Quality Systems Standard 21
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 Clause 8.5.1.4 - Verification after Shutdown IATF 16949 - Automotive Quality Systems Standard 27
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
