IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title
morteza
Hi all
I am not native to English.
I faced with a problem about the concept of the terms "product safety" and "product-safety related products".
Which of the following is correct?
1. Product safety means the "safety of product"
2. Product safety means a "product with safety characteristics"
I think the second should be true. But the I do not know how to translate the term "product-safety related products" with the second concept.
Thanks all
Sidney Vianna
Post Responsibly
Re: 4.4.1.2 product safety- concept of the title
In the Aerospace sector, one of the product safety definitions is
The state in which a product is able to perform to its designed or intended purpose without causing unacceptable risk of harm to persons or damage to property. (9100) (9110)
The way I interpret it is to think of product integrity. Assuring the product conforms as intended. So, for example, if a product was designed with limited life expectancy, eg, spark plugs, supposed to be replaced every 100,000 miles. If you fail to replace them, you are compromising it's integrity and safety.
QualitySpirit
It is already in terms and definitions section 3 in IATF16949
product safety
standards relating to the design and manufacturing of products to ensure they do not represent harm or hazards to customers :yes:
qusys
How to interpret it if it is referred to a semi finished good and not the final product provided to the Customer, intended in a supply chain as tier 3?
Sebastian
As I understand requirement stated in point b), it can not be, that safety-related requirements identified on tier-3 level are not forwarded to tier-2 level until reaching final customer.
I have own question related to point e).
Could you support me with its challenging grammar?
"... and at ..."
Maybe this "and" is a mistake?
Maybe after "and" should be "process" or maybe instead of "product", "process" should be there?
First paragraph of this section mentions both product and manufacturing process, so that is why I think there should be "process" as well.
