IATF 16949 clause 7.1.5.1.1
"Statistical studies shall be conducted to analyse the variation present in the results of each type of inspection, measurement, and test equipment system identified in the control plan. The analytical methods and acceptance criteria used shall conform to those in reference manuals on measurement systems analysis. Other analytical methods and acceptance criteria may be used if approved by the customer..."
MSA 4th edition page 77:
"Since the final (total) variation is based on a combination of the process and measurement variation (total=process+MSA), When SPC is being applied for process control or collecting process data, and the control chart indicates that the process is stable and the total variation is acceptable, the measurement system can be considered acceptable for this use and does not require separate reevaluation."
I just received a major in a transition audit due to an optical measurement machine that had a calibration certificate, a Type-1 MSA (50 measurements with a known and calibrated master) that was acceptable - the measurements from the machine is used to collect and evaluate SPC/CPK mainly Cpk>1,33 but also Cpk>1,67
To sum up:
-SPC is applied for process control
-The process is stable
-The total variation is acceptable
Objective evidence for the finding:"There is no MSA study made for the specific product the measurements made on the system. This process is the basic for calculating CpK values"
I challenged the auditor multiple times during audit without luck.
Should I accept this finding and why? Where is the 'shall'?
To sum up:
