IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management)
#12
Yes I understood her answer. I have addressed in my procedures that 2nd party audits are one of many ways to monitor the performance of suppliers. I guess it depends on the products and services you provide to determine if and when you will perform these. I have a documented risk assessment that resulted in no negative impact to not performing 2nd party audits of my suppliers at this time.
These may be needed for some organizations.
Sebastian
#13
Need, type, frequency and scope you can decide, but decision "no need at all" for all suppliers is not compliant to this requirement. I understand this is OK according to your auditor evaluation. Stay with that, but keep in mind, other auditor can evaluate it as nonconformity.
malasuerte
#15
I just had my Stage 1 audits and asked my auditor about this. As long as your suppliers are 3rd party certified, you do not need to perform the 2nd party audits.
Not sure how you auditor can tell you this? The clause explicitly states that you must have a "second-party audit process".
It goes on to state you must have records of the second-part audit.
It states also that you must document: need, type, frequency and scope of the audits.
For the OP, if your Purchasing group is conducting these assessments, you should ensure they are trained to do the audits, and then meet all the requirements of the clauses.
Sidney Vianna
Post Responsibly
#16
I don't have a copy of the IATF 16949:2016 Standard, but the presentation material available online mentions that supplier QMS development goes all the way to supplier accredited certification to IATF 16949. So, it seems me that second party audits are not mandatory if the supplier has the proper certification. For those cases WHEN 2[sup]nd[/sup] party audits are used,
Section 8.4.2.4.1: Second-party audits
• This new section aligns customer-specific requirements into the IATF 16949 standard.
• Second-party audits should consider issues relevant to the organization beyond simply the maturity of their QMS development.
• Examples of situations that could trigger a second-party audit include: input from supplier performance indicators; risk assessment results and follow-up of open issues from process and product audits; and new development launch readiness.
• The organization's criteria for determining the need, type, frequency, and scope of second-party audits must be based on a risk analysis
Sebastian
#17
Supplier development process is described by 8.4.2.3 and second party audits are sub-clause of supplier monitoring 8.4.2.4.
There is no way to not perform a second party audit at all. Suppliers certification status is one of criteria to determine whether there is a need or not to perform second party audit in case of certain supplier, but there are still other ones as e.g. supplier performance. So "no process" due to all suppliers are IATF certified requires n/c.
malasuerte
#18
IATF Clause 8.4.2.4.1 Second Party Audits
The organization shall include a second-party audit process in their supplier management approach.
Second-party audits may be used for the following:
-supplier risk assessment
-supplier monitoring
-supplier QMS development
-product audits
-process audits
"....the organization shall document criteria for second-party audits"
"....the organization shall retain records of second part audits."
[/LIST]
mbehmazia
#19
I am not sure if this is in the correct section so pardon me ahead of time.
The way I am reading the new IATF requirements, since my company is going for our IATF16949:2016 registration audit, our lead auditor is telling us that all of our Tier II suppliers must all be IATF certified also. I don't interpret that clause of IATF that way. I think that we can "approve" our suppliers via second party audits. Can any one agree or disagree with this observation? Thanks.
Golfman25
#20
See 8.4.2.3. It gives the hierarchy. They basically want ISO 9001 certification with an "objective" of getting IATF certification. I don't see that happening for a lot of the supply chain.
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
QChas IATF 16949 Clause 8.5.1.2 - C -Standardized Work IATF 16949 - Automotive Quality Systems Standard 1
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 clause 8.3.4.3 Prototype programme IATF 16949 - Automotive Quality Systems Standard 0
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 9.2.2.2 - Which QMS Processes are Included IATF 16949 - Automotive Quality Systems Standard 1
J What are sample documents of IATF 16949 Clause 8.6.4 a? IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable IATF 16949 - Automotive Quality Systems Standard 64
M IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition Compliance IATF 16949 - Automotive Quality Systems Standard 38
M Exclusion of IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 13
M Compliance with IATF 16949 Clause 8.3.4.4 Product Approval Process IATF 16949 - Automotive Quality Systems Standard 2
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
P IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls IATF 16949 - Automotive Quality Systems Standard 21
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 Clause 10.2.4 - Error Proofing IATF 16949 - Automotive Quality Systems Standard 25
P IATF 16949 Clause 8.5.1.4 - Verification after Shutdown IATF 16949 - Automotive Quality Systems Standard 27
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
