IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls
Peters
I have a problem with 8.5.6.1.1 Temporary change of proces controls
1.I have a problem with interpretation of this text:
The organization shall identify, document, and maintain a list of the process controls…
…The organization shall maintain and periodically review o list of approved alternate process control methods that are referenced in the control plan.
The text indicates that the list of alternative tests and inspections is expected, which is not a control plan. Question how does it differ from the control plan, what structure and content should it has? Would it be more a part of the control plan (as variant lines) or a completely separate document? Does it contain only list of alternative gages/devices or also list of alternative measurements with alternative frequency, sampling and criteria?
2.I have a problem with understanding of this text:
Restart verification is documented for a defined period based on severity and confirmation that all features of error-proofing device or process are effectively reinstated.
What is “Restart verification” in this context?
What is “defined period” in this context?
What is “features” in this context?
Sebastian
Re: IATF 16949 Clause 7.5.6.1.1 - Temporary Change of Process Controls
In further part of this sentence process controls are referring to listed devices and related methods. Coming from risk based thinking, we shall select back-up devices and methods during APQP activities, document them and get customer approval in advance, if required.
It may be documented by:
- control plan (e.g. additional line in Evaluation/Measurement Technique column in AIAG form),
- contingency plan (e.g. table listing alternate work (inspection) instruction in case of primary control device failure),
- other document.
Focus of "back-up / alternate" words is on device & methods, but I see there also "opportunity" for specification, control frequency or sample size of controlled characteristic. "Opportunity" means, that "back-up / alternate" can make them only more severe e.g. specification range narrowed due to lower reliability of alternate inspection device.
Similar wording we can find in GM CSR Section 4.1.21 Bypass Management, but "bypassing" sounds a little bit "negative" to me, comparing to "back-up".
joekirk
I had an interested discussion with an IATF auditor yesterday regarding this clause.
My interpretation is that you would develop and document back-up or alternate methods for inspection processes based on risk and include those in our process control plan.
Auditors interpretation is that you must have a back-up or alternate method for each process control listed on the control plan.
Someone please clarify.
Peters
I can't see such requirement in 8.5.6.1.1
What for?
For example:
Auditee: For this inspection my inspector uses caliper.
Auditor: Please show me back-up or alternate method for this process control.
Auditee: What for?! I have a lot of inspectors and a lot of calipers!
jelly1921
Not for each process control.
IATF training PPT comments:
• This new requirement for temporary control of process changes addresses issues experienced by the IATF OEM customers.
• The organization must identify, document, and maintain a list of process controls that includes both the primary process control (example: automated nut driver) and the approved back-up or alternate methods (example: manual torque wrench). The list must be updated regularly to reflect the current and approved process controls.
• The use of alternative control methods is considered a process; therefore, the organization is expected to manage these activities appropriately.
GM's CSR says more clearly: The organization shall keep a list of all error proofing devices and identify which can be bypassed and which cannot (also see clause 8.5.6.1.1).
Jelly
QualitySpirit
Verification after the standard process controls have been resumed.
A period of close monitoring after the standard process controls have been resumed. It should be based on severity if it has a high severity then it should be closely monitored for a longer period.
Features = intents of each process controls - it must be made sure that all process controls are working as they are intended to.
Blaest
During training at SMMT Industry Forum Birmingham the trainer had the exact same attitude and insisted for an alternate control methold for each inspection on the control plan, he even stated that every entry on the control plan was by definition an inspection - so this would mean every control plan would be exactly double the size compared to TS 16949 requirements. Now that I look for the 'shall' it it not so easy to see why the trainer put it like that.
srfeyzi
IMS Manager
Hi
I have two questions:
1- do you think the third party auditor will look for "a list" of all primary and back up process controls? or as long as those items are listed in the control plan, it would be enough? I mean should we keep a separate list for this clause?
2- do we need alternative methods for all process controls, or we can determine which ones we can bypass?
in our plant, we have more than 10,000 process controls, including automated, error-proofing, manual, visual, etc.
mihir.bajekal
Hi
I have a question. We were recently audited for IATF 16949 by a third party auditor. During the audit, he raised a non conformity for not having covered contingency plan in the temporary change of process controls. However, after going through the standard once again, I could not find any linkage to that. So, can anyone confirm to me whether the two are linked and whether we should include the contingency plan also in the same document?
Mihir
Sebastian
6.1.2.3 c) prepare contingency plans for continuity of supply in the event of any of the following: key equipment failures (also see Section 8.5.6.1.1)
He was right, as expected.
