IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change)
Golfman25
#21
Great inputs Sebastian.
Just wanted to chime in and say this is not as difficult as it sounds. Make yourself a quick table of you Control Methods today. Then simply determine what the "alternate" method would be if you were w/o that primary method.
i.e. - Note, there are only random examples off the top of my head to illustrate a point.
Primary method for 'inspection of defects': MIK - microscope
Alternate method: Manual visual inspection
Primary method of control of product dimensions: Caliper
Alternate method: Ruler
Primary method of controlling product output: SPC - statistical process control
Alternate method: FDC - fault detection classification
Ok, but what if you only had manual visual inspection capabilities and a ruler?
malasuerte
#22
Then you need to devise an alternate control method.
In your 'scenario', you could have a template - the piece could 'fit into the template' or the template can be used as comparison.
You have to meet the requirement, but also do what works for your business.
John C. Abnet
Teacher, sensei, kennari
#23
Good day @bkirch;
Consider this...
What are the author's concerns? (i.e. why did they add this?)
Example:
ACME corporation uses a DC runner and controller to install threaded nuts on an assembly. During the manufacturing process, the DC runner breaks and they need to make shipment. What do they do ? They send "Tom" to the nearest hardware store to purchase a torque wrench.
Problem?
There are no established process controls, instructions, verification requirements, etc... necessary for the temporary process.
The key words here are "...Process Control..." What do organizations ALREADY have in place that defines process controls? The Control Plan.
Suggestion:
Simply add columns to the control plan template to allow for temporary process controls to be identified, including the need for the required additional verifications and frequencies.
Benefits:
This prevents the need for additional and fragmented documentation, when feasible gains customer pre-approval for if/when the temporary control is needed, and ensures sustainability (i.e. the control plan remains active for the life of the product).
Hope this helps.
Be well.
Golfman25
#24
That's kind of silly. We primarily use calipers and micrometers. If one fails, we grab another. No alternate needed.
Johnson
#25
In fact, IATF 16949 Clause 8.5.6.1.1 requirements was originated from customer specific requiremnts, in this case, from GM BIQS-5 "Bypass / Deviation Management".
Due to this reason, there is a lots of confusion and mis-understanding about the requirements. So IATF has made revisons and SI's on this clause.
The follwoing is quoted from GM BIQS-5, which will help to understand IATF temporary process (equivelent to GM bypass management):
The plant shall identify manufacturing processes and error proofing devices which can be bypassed or placed in deviation. Risk Priority Number (RPN) for all approved Bypass / deviation processes are evaluated and risks are reviewed. Standard work instructions are available for each Bypass / deviation process.
Implemented bypasses/deviations are reviewed in daily Leadership Meeting with the goal to reduce or eliminate bypassed/deviated operations. Processes/devices in bypass / deviation must have a quality focused audits performed. Supplier locations that have a process in bypass/deviation shall have the bypass/deviation process checked on the daily LPA. Restart verification is documented for defined period. It should be 100% checked for all features
The following also came from GM for finding evidence if BIQS-5 is implemented.
Look for the plant list of manufacturing processes and error proofing devices which can be bypassed or placed in deviation. Confirm that Risk Priority Number (RPN) for all approved bypass / deviation processes are evaluated and that Standardized Work is available for each bypass/deviation process. Supplier locations shall have a written and approved bypass/deviation procedure that includes customer notification.
Ensure implemented bypasses/deviations are reviewed in Fast Response with the goal to reduce or eliminate bypassed/deviated operations. Look for evidence of the bypass / deviation checklist being used for processes/devices in bypass.
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
QChas IATF 16949 Clause 8.5.1.2 - C -Standardized Work IATF 16949 - Automotive Quality Systems Standard 1
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 clause 8.3.4.3 Prototype programme IATF 16949 - Automotive Quality Systems Standard 0
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 9.2.2.2 - Which QMS Processes are Included IATF 16949 - Automotive Quality Systems Standard 1
J What are sample documents of IATF 16949 Clause 8.6.4 a? IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable IATF 16949 - Automotive Quality Systems Standard 64
M IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition Compliance IATF 16949 - Automotive Quality Systems Standard 38
M Exclusion of IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 13
M Compliance with IATF 16949 Clause 8.3.4.4 Product Approval Process IATF 16949 - Automotive Quality Systems Standard 2
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
P IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls IATF 16949 - Automotive Quality Systems Standard 21
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 Clause 10.2.4 - Error Proofing IATF 16949 - Automotive Quality Systems Standard 25
P IATF 16949 Clause 8.5.1.4 - Verification after Shutdown IATF 16949 - Automotive Quality Systems Standard 27
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
J How to understand IATF 16949 Clause 8.5.2.1 - Traceability IATF 16949 - Automotive Quality Systems Standard 5
