IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unusable
joekirk
How do companies address the following requirement?
"the organization shall verify that the product to be scrapped is rendered unusable prior to disposal."
How would you do this without cutting up / destroying the part?
Example would be bearing supplier. Would they be required to cut the raceways?
Example would be a shaft supplier. Would they be required to melt or cut the shafts prior to disposal?
Any suggestions other than buy a saw to cut the parts?
Re: IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition - Scrap Rendered Unus
Further thoughts are appreciated as well as solutions which are applied to high volume batch processes of Section 8.7.1.7: Nonconforming product disposition:
If the clause applies to disposition outside the manufacturing batch process, which our organization terms as MRB (Material Review Board), then meeting the clause seems reasonable. A reject is already dispositioned as part of the manufacturing process and thus not awaiting a disposition through a formal MRB process. For our organization, rendering rejects (start-up and troubleshooting) unusable from a batch process would be costly, as methods would need to be defined as well as additional equipment and labor added to the process flow.
If I read from an AIAG upload (pasted below), would a robust procedure defining manufacturing rejects as a separate process from which disposition as scrap are made through the formal MRB process meet the intent of the clause? We would also demonstrate we contain and do not pass rejects on within the manufacturing process.
• Strengthen the requirement of disposition of nonconforming product by clarifying that organizations must also have a documented process for disposition of nonconforming product not subject to rework or repair.
• Planned activities need to be managed and the results considered to improve this process.
• Contamination control practices should be applied to avoid any risk of unintended use of this type of nonconforming products.
• Customer approval is required before nonconforming products in this category can be diverted for service or any other use.
Thanks,
Carl
Sebastian
For me this is clearly off-line activity.
During on-line inspection activities we determine nonconforming part.
We separate nonconforming part from conforming parts and then we have three options, what to do with it:
rework,
repair,
scrap.
So last option is a final stage of nonconforming product life and must include activities preventing it from appearing somehow on field and usage against organizational/OEM intention.
normzone
Somewhere there exists a video of a large truck, somewhere in Japan, slowly rolling back and forth over a large volume of small boxes, filled with nonconforming cell phone displays. I've heard the tale, seen the video, but can't recall where.
:bonk:
Canoehead79
So in the case of metal product NCP, our process moves material to Scrap Bins at our dock, which are then picked up by a Scrap Metal service. Provided they give us a document indicating a flow which includes 'rendering unusable' which we approve, are we clear?
delorfra
The answer to the question 3 adds «*provided you check regularly at your service provider’s that the products are actually rendered unusable*».
E
EmillyWilson
Bad News... I just received a NC in my IAFT audit written to this requirement:(
We are a tier 3, small component metal stamper. In no way can my product be used for it's intent without additional assembly by our customer and usually their customer. Our process stated regular inspections of our Scrap Yard's process (5 miles) away.... Long story short the NC was written based on our start up parts going into a red bin > into the hopper. The auditor is saying we must rendered scrap unusable prior to disposal, ie going in the hopper. He feels this must happen at the stamping presses immediately. This requirement is a bunch of BS, at our level and is going to cause me to disposition the parts as suspect instead of immediately calling them scrap. Then introduce something like paint, great for my 14001 certification or a manual smashing process, great for my Safety Program. WTF
delorfra
As a certification auditor, I can confirm that you are entitled to contest a non conformity, in this case based on the IATF FAQ No.11 published in October 2017 :
http://www.iatfglobaloversight.org/...9-Frequently-Asked-Questions_October-2017.pdf
QUESTION
3:Can the organization use a service provider to render the product unusable ?
ANSWER
3: Yes, it is acceptable to contract the process of rendering the product unusable to a service provider.
If a service provider is used, the organization needs to approve, and periodically verify, how the supplier is rendering the product unusable.
François
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
P IATF 16949 Clause 8.4.2.3 - Justification for non-certified suppliers IATF 16949 - Automotive Quality Systems Standard 14
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
R IATF 16949 Clause 8.5.1.6 a) maintenance and repair facilities - Production tooling management and personnel IATF 16949 - Automotive Quality Systems Standard 4
QChas IATF 16949 Clause 8.5.1.2 - C -Standardized Work IATF 16949 - Automotive Quality Systems Standard 1
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
R IATF 16949 Clause 6.1.2.1 - Lessons Learned and Risk Analysis IATF 16949 - Automotive Quality Systems Standard 6
L IATF 16949 Clause 9.2.2.2 Quality Management System Audit IATF 16949 - Automotive Quality Systems Standard 9
H IATF 16949 Clause 9.2.2.2 Audit System / CSR IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 clause 7.1.5.1.1 - Statistical studies shall be conducted IATF 16949 - Automotive Quality Systems Standard 3
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
J IATF 16949 Clause 9.3.2.1 - How to understand "measures" IATF 16949 - Automotive Quality Systems Standard 4
J How to address IATF 16949 clause 5.1.1.1 in my Quality Manual IATF 16949 - Automotive Quality Systems Standard 6
B IATF 16949 clause 8.3.4.3 Prototype programme IATF 16949 - Automotive Quality Systems Standard 0
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
W IATF 16949 Clause 6.1.1 - My first Major NCR (Management Review) IATF 16949 - Automotive Quality Systems Standard 57
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
E IATF 16949 Clause of 8.4.3 - Approvals - Can you explain to me IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 9.2.2.2 - Which QMS Processes are Included IATF 16949 - Automotive Quality Systems Standard 1
J What are sample documents of IATF 16949 Clause 8.6.4 a? IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Clause 8.3.3.3 - Documentation of all Special Characteristics in Drawings IATF 16949 - Automotive Quality Systems Standard 2
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B IATF 16949 Clause 8.6.2 - Layout Inspection and Functional Testing IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Clause 9.3.2.1 - Management Review Inputs IATF 16949 - Automotive Quality Systems Standard 1
T Customer Authorization for Concession - IATF 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 3
W IATF 16949 Clause 8.4.2.4.1 Second Party Audits (Supplier Management) IATF 16949 - Automotive Quality Systems Standard 45
T Record Retention Requirements - IATF 16949 Clause 7.5.3.2.1 Records and Data - Quality, Legal and Other Evidence 15
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 25
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
M IATF 16949 Clause 4.4.1.2 - Product Safety - Concept of the Title IATF 16949 - Automotive Quality Systems Standard 4
M IATF 16949 Clause 7.1.5.1.1 - What are "inspection equipment systems"? IATF 16949 - Automotive Quality Systems Standard 4
P Setup Verification in IATF 16949 Clause 8.5.1.3 IATF 16949 - Automotive Quality Systems Standard 6
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
J IATF 16949 Clause 8.7.1.7 Nonconforming Product Disposition Compliance IATF 16949 - Automotive Quality Systems Standard 38
M Exclusion of IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 2
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 4.4.1.2 - Product Safety IATF 16949 - Automotive Quality Systems Standard 13
M Compliance with IATF 16949 Clause 8.3.4.4 Product Approval Process IATF 16949 - Automotive Quality Systems Standard 2
dubrizo IATF 16949 Clause 8.7.1.6 - Customer Notification - Your Inputs Requested IATF 16949 - Automotive Quality Systems Standard 4
P IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls IATF 16949 - Automotive Quality Systems Standard 21
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 Clause 10.2.4 - Error Proofing IATF 16949 - Automotive Quality Systems Standard 33
P IATF 16949 Clause 8.5.1.4 - Verification after Shutdown IATF 16949 - Automotive Quality Systems Standard 30
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
