IATF 16949 Internal Audit question - Auditor's responsibility
John H
I recently completed an internal process audit. A certified operator did not complete all required Control Plan quality checks and was not able to complete certain measurement checks/did not know how. I deemed that work order as suspect product and informed the quality manager as well as the manufacturing manager. The QM stated she would take care of the issue by quarantining the product. I decided to audit the control of suspect product. The QM never quarantined the product and it made it to the customer. At that point I stated she had to contact the customer and that the process of control of suspect product failed. Customer was never notified. During the same audit a temporary operator made product with no oversight - could not answer any questions related to the Control Plans - that also became suspect product. Same outcome - no reaction from the quality manager or operations manager and that customer was never notified as well. I was blamed for not quarantining product even though I was the auditor and I informed the correct parties - quality manager and manufacturing manager. Any thoughts?
Sidney Vianna
Post Responsibly
Based on your description of the dysfunctional approach to systems at your organization (Customer Complaint & SCAR, false data), with special emphasis to the apparent total disregard to prevention of recurrence of negative events, it seems to be hopeless. You are doing your job well, as an internal auditor, uncovering issues of significance, of relevance, but the people with the authority and responsibility to ensure the system is being followed don't seem to care. I can only think the cultural organizational mismatch towards process discipline comes from the top.
Once again, I ask: How come your IATF CB auditor never finds these "atrocities"? Is s/he this incompetent?
John H
You ask a very interesting question. From my perspective the CB auditors (new auditor this year) are surface auditors figuratively speaking. Handful of years ago two witness auditors were with the CB auditor and major non-conformances were written. Is it typical for CB auditors to only touch the surface? It just seems like everything is rushed - if it looks ok - move on to next area. If you are open to questions - can you give your opinion on variable x-bar and range Control Charts - the company I work for has it setup as fixed for both the specification (which is expected) and the UCL & LCL. I have never heard of the UCL and LCL being fixed but I am also not an expert. Is this a somewhat common practice - are there benefits to this? It seems that issues would significantly out weigh the benefits. I also have another questions on training for Control of Suspect Product - do you know of any articles I can read through for the best approach on how to train operators on this subject?
Randy
I don't do 16949 but I do audit. CB's auditors very seldom have enough time to get really down to the grassroots because of the total amount of a MS (& organization) that has to be sampled during an audit, and that's a fact of life. You make a basic plan that covers the "required stuff" that has to be seen every audit, and then work out from there. On a 1 day (8 hour) annual audit, how much do you think can be looked at and how deep can one go? (One day annual audits do happen as do 1.5 and 2 day audits). Even during a recertification audit (which is 2/3rds the duration a completely new certification) how much and how deep can you go in 2 days, when a percentage of the time must be set aside for opening & closing meetings, planning and report writing? At times you do have to get down and dirty so to speak, there's no way around it, and when that happens your plan can go down the toilet really complicating that audit and most likely the next with trying to squeeze everything in, reducing the amount of time across the MS and therefore reducing sample size and so on. It's challenging and it's tough. No excuses, just fact that most outsiders don't know.
Interesting, 2 witness auditors? My last AB witness audit was not too long ago for 5 days during a RC14001 recertification (headquarters of a multi-site) and I only had one auditor, excellent person, non-intrusive, a couple OFI's for our internal procedural stuff, and nothing negative to report.
John C. Abnet
Teacher, sensei, kennari
Good day @John H .
You have received good feedback thus far. If it helps, remember that the requirement of an internal auditor is to ...
"...provide information..." (ISO 9001 9.2).
I can only hope you do not have responsibilities related to quality performance/customer satisfaction beyond your duties as an internal auditor. If you do not, then you are doing your job and your conscience should be clear. If you DO have those additional responsibilities, then...well, it sounds like a heart to heart with sr. Leadership and/or a potential move to an organization that has Top Management taking responsibility for the QMS (as is required by the standard).
Hope this helps.
Be well.
If the control limits are fixed, they're not control limits, statistically speaking. Control limits are mostly useless unless they're calculated from the data, and the data has been collected in a canonical manner.
It's a relatively simple matter:
  • Do containment--makes sure you locate all of the potentially suspect product, including whatever might have been shipped or might already have reached a customer;
  • Segregate and identify (mark) all suspect material;
  • Notify customers, if necessary;
  • Review the segregated material for disposition.
For the future, it's best not to mix questions on different topics. Starting a new thread for each topic, in the appropriate forum, will render the best results.
John H
Well understood. Thank you for your reply.
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
R IATF 16949 - Outsourcing of internal audits Internal Auditing 11
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
S IATF 16949: Is "Certified" Internal Auditor mandatory? IATF 16949 - Automotive Quality Systems Standard 9
Ashland78 IATF 16949 Internal Audit Checklist Manufacturing and Related Processes 11
J IATF 16949 CAR - Internal Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 15
T Example wanted - Template for internal audit IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
F IATF 16949:2016 transition audit - Internal Audit Closures IATF 16949 - Automotive Quality Systems Standard 13
H Internal laboratory scope requirements - IATF 16949 Cl. 7.1.5.3.1 IATF 16949 - Automotive Quality Systems Standard 1
B Going into IATF 16949 transition without Internal Audits IATF 16949 - Automotive Quality Systems Standard 4
A IATF 16949 - 9.2.2.1 Internal Audit Programme - looking for example IATF 16949 - Automotive Quality Systems Standard 5
B IATF 16949 - 7.1.5.3.1 Internal calibration laboratory requirements IATF 16949 - Automotive Quality Systems Standard 13
B IATF 16949 Cl. 9.2.2.1 - Internal audit program - Types of evidence Internal Auditing 1
D IATF 16949 - Internal Auditor Training/Certification Requirements Training - Internal, External, Online and Distance Learning 2
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
D Please share your IATF 16949 Internal Audit Plan and Schedule Internal Auditing 13
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 10
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
P IATF 16949 - Internal Audit Frequency Requirements Internal Auditing 2
B Competency of Trainer for Internal Auditor Training (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 11
tony s TS 16949 Internal Audit Trainer Traceability to IATF General Auditing Discussions 6
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 3
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 19
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
