IATF 16949 - Manufacturing and Product Audit Approach
santiko
Hi all,
In IATF 16949 the requirement state
9.2.2.3 Manufacturing process audit
The organization shall audit all manufacturing processes over each three-year calender period to determine their effectiveness and efficiency using customer-specific required approaches for process audit. Where not defined by the customer, the organization shall determine the approach to be used
9.2.2.4 Product audit
The organization shall audit products using customer-specific required approaches at appropriate stages of production and delivery to verify conformity to specific requirements. Where not defined by the customer, the organization shall define the approach to be used
Our customer not defined the audit approach. My question is What kind of approach our organization need to be defined for each type of audit? Or how we should implement this "shall" in our organization?
Thank you in advance.
Golfman25
So I look at it this way:
Product audit is the old dock audit. We take a part sitting on our dock ready for shipment and check it for compliance to customer requirements. We have a simple checklist form we use.
Manufacturing process audit we hit two ways: First is basically a part audit to the control plan. We follow all the way thru from purchasing to final inspection. Again we have a checklist we use.
Then we also do a global system audit of our manufacturing processes/procedures. This is less part specific and more of an overall view.
joekirk
Product audits could be the old dock audits, but it could also be in-process audits done on a regular basis at various inspection points in your process. Most companies are already doing this.
Manufacturing process audits should be looking at the control plan, FMEA and procedures, past corrective actions and customer complaints associated with the process being audited. This should be used to make sure your FMEA, CP and procedures are current.
Marc
Fully vaccinated are you?
Good points, joekirk. None of this is really "new". It reminds me of the old "Dragnet" disclaimer: "Only the words were changed to confuse people".
santiko
Thanks for the feedback.
Yes, i understand the audit approach is should be like that like the old one. But, what i mean is, how i put it on our procedure.
"Where not defined by the customer, the organization shall determine the approach to be used"
replace with,
"Where not defined by the customer, the organization shall be looking at the control plan, FMEA and procedures, past corrective actions and customer complaints associated with the process being audited"
is something like that? do you all agree?
mgucia
You can find strict guidelines for both audits in publications of german VDA:
"VDA 6.3 Process audit"
"VDA 6.5 Product audit"
Draft of "VDA 6.3 Process audit" is available online.
In attachment B to IATF you can find list of suggested "approaches"
Internal audit
AIAG
CQI-8 Layered Process Audit
CQI-9 Special Process: Heat Treatment System Assessment
CQI-11 Special Process: Plating System Assessment
CQI-12 Special Process: Coating System Assessment
CQI-15 Special Process: Welding System Assessment
CQI-17 Special Process: Soldering System Assessment
CQI-23 Special Process: Molding System Assessment
CQI-27 Special Process: Casting System Assessment
ANFIA
AQ 008 Process Audit
FIEV
V2.0 Production Process Audit Manual
IATF
Auditor Guide for IATF 16949
VDA
Volume 6 part 3 Process Audit
Volume 6 part 5 Product Audit
Mikey324
If it helps, we changed very little about our I/A procedure. TS already required product, process, and system audits.
We really only looked through our competency requirements to make sure they met the requirements of 7.2.3 / 7.2.4 (see latest IATF sanctioned interpretations, this was clarified).
From 9.2.2.1, you are most likely already creating your schedule based on priority. Your priorities should already be risk based. Example, you will increase the frequency of audits if the process has let NG parts flow out. You would not increase the frequency for a process with little impact on the customer that has had no past corrective actions, audit findings, ect. This is already risk based thinking.
Some "new" requirements in the standard are not really new. Just the wording in my opinion.
For reference, we have completed our transition audit with no findings for the internal audit system. Trust me, they looked at it hard.
Vader22 IATF 16949 extended manufacturing site help IATF 16949 - Automotive Quality Systems Standard 4
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 6
J Manufacturing Process Auditor Requirements - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
H IATF 16949 9.2.2.3 - Manufacturing process audits IATF 16949 - Automotive Quality Systems Standard 20
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
B IATF 16949 - Different Registrars for remote and manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 2
V IATF 16949 Manufacturing Process & Product Audits IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 - Cl. 8.3.3 - Product design inputs, manufacturing process design inputs IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
A IATF 16949 Cl. 8.3.5.2 e) - Manufacturing Process Flow Charts & Layout IATF 16949 - Automotive Quality Systems Standard 5
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Sidney Vianna IATF 16949 News IATF News - Top 10 IATF 16949 nonconformities and more..... IATF 16949 - Automotive Quality Systems Standard 7
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
V IATF 16949 GM CSR 10.2.4 Error-proofing requirement IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 5
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
xfngrs 3 year audit cycle IATF 16949 IATF 16949 - Automotive Quality Systems Standard 10
D IATF 16949 Process Map IATF 16949 - Automotive Quality Systems Standard 19
D IATF 16949 Certification and Letter of Conformance expiry (Help!!!) IATF 16949 - Automotive Quality Systems Standard 8
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 20
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
