IATF 16949 Process Map
Der All,
I would like to ask you for some help.
When I am making the Process Map, and I have to choose the main processes in it and how are they connected, basically I have to insert all existing processes and just connect them?
I just need some guidance to prevent future mistakes when I am making a draft, what I have to pay attention to.
Thank you in advance for all the help.
Kind regards,
David
Jen Kirley
Quality and Auditing Expert
Der All,
Kind regards,
David
Hello David,
I am sorry for the delay in this response.
I have seen many process maps and found most of them to be of very little (if any) value. I don't have a copy of IATF 16949 so I want to ask our colleagues here: does that standard require a process map? I can offer that ISO 9001:2015 does not include the words "process" and "map" next to each other anywhere. It does say that process sequence and interaction needs to be identified. People just assume that means a pictoral display is required.
What say you, Automotive people? Is a process map required?
If Yes, I can offer that the best maps I have seen show production process flow, but do not leave out indicators where sales and design inputs, and don't forget to show that support processes like document control, personnel management and maintenance/infrastructure management are recognized as support for production. I have seen that done in various ways; the "how" was less important to me than the fact this recognition took place.
Ron Rompen
although the standard doesn't specify 'process map', it does require that you demonstrate the interaction between processes - a pictorial display (of some kind) is generally the easiest way to do this.
David, it doesn't have to be highly detailed - this is intended to be a '30,000 foot view' of your processes, and how they interact with each other, providing inputs/outputs back and forth.
Your individual process maps will provide more 'focused' information on the specifics of the information sharing.
I have attached a couple of different examples to try and illustrate this more clearly. 1642693519819.png 1642693584387.png
Hello All !
I would like to share the kinda final Process Map what I have created. Our consultancy guys told me that its not necessary to include here the process flow, because we will make some kind of Process Analysing sheets for each process.
I just want some feedbacks if I should change anything or something doesn't add up.
Our situation as you can see is not normal, there are a lot of processes from our Customer and we only assemble parts except the Foam Sealing which we do with a robot.
I tried to use 5 main colours for the 5 main processes but for Quality and Accounting I wanted to use some other shades of that given color.
I am still quite confused how to do and what to do.
Thank you in advance for all the (constructive) feedbacks / criticisms :D !
-David-
Ron Rompen
Overall I like it. The only suggestion I would make (and it's picking nits) is that you don't showhow management support and external processes feed into factory processes, and how factory processes feed back to them. Just add a couple of arrows (double-headed) to indicate this and I think it's good to go.
morteza
Hi David,
Some comments:
1- It is better to change the left box with "interested parties requirements (or needs and expectations)" instead of "customer requirements. Do so for right box.
2- I think that "external processes" are "out sourced processes". If so, it is better the change the name.
3- Can you explain more about "Customer (remote) processes"?
4- The system boundary in your map is not clear. Customer requirements should be out of the boundary and the customer (remote) processes should be within the boundary
DeKamp
I have a question regarding Process Maps.
Do you have to have a Process Map for each and all individual Procedures?
For example, my company has 30 separate procedures, do I need 30 separate Process Maps?
Thank you in advance.
30 procedures? Wow. What's your QMS scope?
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
Cats Clause Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 6
J IATF 16949 8.4.1.2 Supplier selection process IATF 16949 - Automotive Quality Systems Standard 4
J Manufacturing Process Auditor Requirements - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
H IATF 16949 9.2.2.3 - Manufacturing process audits IATF 16949 - Automotive Quality Systems Standard 20
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
N Looking for input on the attached Process / IATF 16949 Clause Matrix IATF 16949 - Automotive Quality Systems Standard 4
A IATF 16949 Cl. 8.4.1.2 Supplier Selection Process - assessment example IATF 16949 - Automotive Quality Systems Standard 11
P Interesting Discussion IATF 16949:2016 Clause 9.2.2.3 and Layered Process Audits IATF 16949 - Automotive Quality Systems Standard 18
M IATF 16949 Clause 8.3.5.2 sub-clause (l) - Process maintainability requirements IATF 16949 - Automotive Quality Systems Standard 15
V IATF 16949 Manufacturing Process & Product Audits IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 - Cl. 8.3.3 - Product design inputs, manufacturing process design inputs IATF 16949 - Automotive Quality Systems Standard 4
C IATF 16949 - Product Safety Escalation Process Timeliness IATF 16949 - Automotive Quality Systems Standard 8
D IATF 16949 Process Measurement and Efficiency Measures Requirements IATF 16949 - Automotive Quality Systems Standard 2
A IATF 16949 - Non-conformity on 5.1.1.2 Process effectiveness and efficiency IATF 16949 - Automotive Quality Systems Standard 5
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Cl. 7.3.2 - Documented Process (Effectiveness & Efficiency) IATF 16949 - Automotive Quality Systems Standard 10
E IATF 16949 Cl. 9.1.2 - Monitoring Process Performance IATF 16949 - Automotive Quality Systems Standard 1
A Escalation Process - IATF 16949 Clause 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 11
T Example System & Process Audit Check Sheet for IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
J IATF 16949 Cl. 8.4 - Externally provide process not for automotive part IATF 16949 - Automotive Quality Systems Standard 3
Q IATF 16949 Cl 5.1.1.3 - Requirements related to the Process Owner IATF 16949 - Automotive Quality Systems Standard 1
D Our company is considering generating a QMS Process to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
A IATF 16949 Cl. 8.3.5.2 e) - Manufacturing Process Flow Charts & Layout IATF 16949 - Automotive Quality Systems Standard 5
J Process Effectiveness and Efficiency (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 29
B IATF 16949 Cl. 9.3.2.1 - Management Review Inputs - Process Effectiveness and Efficie IATF 16949 - Automotive Quality Systems Standard 14
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 25
T Temporary Change of Process Controls - IATF 16949 Clause 8.5.5.1.1 IATF 16949 - Automotive Quality Systems Standard 16
T IATF 16949 Control Plan and Process Monitoring Requirement(s) IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Clause 8.4.1.2 - Supplier Selection Process - Service Providers IATF 16949 - Automotive Quality Systems Standard 13
M Compliance with IATF 16949 Clause 8.3.4.4 Product Approval Process IATF 16949 - Automotive Quality Systems Standard 2
P IATF 16949 Clause 8.5.6.1.1 - Temporary Change of Process Controls IATF 16949 - Automotive Quality Systems Standard 21
J How to understand IATF 16949 Clause 8.5.6.1.1 - Process Controls IATF 16949 - Automotive Quality Systems Standard 2
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
W Looking for IATF 16949 (and ISO 17025) QMS software Suggestions Quality Tools, Improvement and Analysis 8
Sidney Vianna IATF 16949 News IATF News - Top 10 IATF 16949 nonconformities and more..... IATF 16949 - Automotive Quality Systems Standard 7
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
O IATF 16949 News Upcoming Changes to IATF 16949? IATF 16949 - Automotive Quality Systems Standard 4
V IATF 16949 GM CSR 10.2.4 Error-proofing requirement IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 Clause 7.2.2 - On the job training IATF 16949 - Automotive Quality Systems Standard 2
L IATF 16949 8.3 Exclusions Manufacturing and Related Processes 5
D IATF 16949 7.3.1 Awareness- Supplemental IATF 16949 - Automotive Quality Systems Standard 2
Q IATF 16949 8.4.2.4 Supplier Monitoring IATF 16949 - Automotive Quality Systems Standard 2
J Implementation, establishment and certification of IATF 16949. IATF 16949 - Automotive Quality Systems Standard 6
