IATF 16949 Section 8.5.1.5 (Total Productive Maintenance)
bkirch
Section 8.5.1.5, Total Productive Maintenance, of the IATF 16949 standard has a requirement that states that the total productive maintenance system shall include f) documented maintenance objectives, for example: OEE, MTBF, MTTR, and Preventive Maintenance compliance metrics.
Since the requirement states "for example" for the maintenance objectives, does this mean that these are suggested metrics but not required metrics?
Sebastian
You are right, but if they were worth to mention there, so we should treat them as "state of art" metrics. Probably our own metrics (if other than these one) may not be "better", so we should consider switching to these mentioned by IATF 16949.
Marc
Fully vaccinated are you?
IATF is giving some expected metrics - Note: "... system shall include ...". In short, those and other metrics each company must determine is applicable to their equipment. It would be good for an IATF 16949 player to say, but I *assume* OEE, MTBF, MTTR, and Preventive Maintenance compliance metrics are minimum mandatories.
My introduction to automotive was the late 1980's. Over the years so much as changed, so much has been learned, and so much is available to companies (such as good software) that, for example, OEE, MTBF, and MTTR are better understood and easier for companies of all sizes to compute and track.
I pretty much agree with Sebastian - Companies should treat them as "state of art" metrics. That's not to say in some cases various metrics are not of significance - That is something each company has to decide.
tongxiaozhi
It is not a must because these are just examples. You can set you own objectives based on your own needs. We have OEE, maintenance cost as our key objectives.
David J Quality
IATF 16949 Interpretation - 8.5.1.5 "Total Productive Maintenance"
I am confused. IATF 8.5.1.5 "Total Productive Maintenance"
"At a minimum, the system shall include the following...f) documented maintenance objectives, for example: OEE, MTBF and MTTR and preventive maintenance compliance metrics." Can I infer that if we are already tracking objectives such as unplanned downtime, PM completions to schedule, plant improvements, etc., that we are not required to do OEE, MTBF and MTTR?
Also, item j) refers to "periodic overhaul". What is this refering to?
:thanx:
Golfman25
That is correct! Maintenance, the red-haired stepchild in many organizations.
Predictive and Preventive maintenance, still NOT effective.
Well in my dealings with auditors, both good and bad, they don't know the first thing about actual maintenance. They have read it in a book or learned it a seminar, but have no practical experience. I had one try to tell me that monitoring our bearing clearances and parallelism on a punch press was not getting it done, when that is the most important thing you can do on that equipment.
My company had a non conformity at this item.
The auditor saw all documents that evidence compliance to 8.5.1.5, but reported that we had no evidence of a documented process.
In other words ...he wants to see a procedure or, as a minimum, a flowchart for this section!
Can anybody help me with this, have you an exemple of a procedure or a flowchart that can be shared?
C IATF 16949:2016 Section 8.5.1.2 item d) accessible for use at the designated work area(s) IATF 16949 - Automotive Quality Systems Standard 5
C AIAG's IATF 16949 section 7.1.5.1.1 - Torque MSA Requirement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
H Documented processes required by IATF 16949 section 4.4.1 IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 Section Clause 8.3.4.1 - Monitoring - Design and Development Input(s) IATF 16949 - Automotive Quality Systems Standard 3
B Calibration/Verification Records - IATF 16949 section 7.1.5.2.1 f) IATF 16949 - Automotive Quality Systems Standard 6
D AS9100 VS IATF 16949 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
T Justification of "Design Excluded" in IATF 16949 Design and Development of Products and Processes 5
Sidney Vianna Job Opening in the USA - IATF 16949 Lead Auditor Position Job Openings, Consulting and Employment Opportunities 0
Ron Rompen IATF 16949 8.5.1.4 IATF 16949 - Automotive Quality Systems Standard 7
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 5
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 7
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 11
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
