IATF & Attribute Study requirements
KyleB
Quality Engineer
We are doing some R&R studies on some gages we have prioritized. I've looked on page 131 of the MSA manual in reference to the attribute study. We did a study on the use of a go no go gage from 3 operators, 20 samples each 3 x. Would the attached Attribute study satisfy IATF requirements? Looking for any input. Thanks.
KyleB
Quality Engineer
Jim, Thanks. I agree, just wanted to see if it would suffice with the way it's laid out with appropriate content etc..
You're welcome. You should be aware that although you think it makes sense and I think it makes sense, you might have benighted customers who don't.
For me, most of them want to get pass in the study for audit in purpose and may forget the room for the improvement in the study results.
We can further check with appraiser 1 whether there is any special cause when checking the trial number#3.
This information can be turned to the knowledge or input on further improvement. :D
John Predmore
If I was reviewing your study, I would ask how were the 20 parts selected. The legitimacy of the result doesn't matter whether calculations were done correctly if the samples were not chosen appropriately.
AIAG (2nd edition section 6) says in a short study of 20 parts, some of the parts should be slightly below and some slightly above acceptance limits. You have not explained whether both directions are represented in this study, and how far out of limits are the NoGo parts. It is recommended that this determination (how far out of limits) be made using variable measurements.
Making Sense of Attribute Gage R&R Calculations - iSixSigma
"Practically speaking, if 'clearly good' parts and 'clearly bad' parts are chosen, the ability of the measurement system to accurately categorize the ones in between will not be tested."
A better approach (the long method study) involves 8 sample parts which are known to reflect the full range of variation, equally spaced. The 8 parts are measured 20 times, and what you want to see are one part accepted by the attribute gauge 20 times out of 20 and one part rejected 20 out of 20. The other six parts should be accepted 1 < a < 19.
The Minitab support website has good explanations of how the long or default study methods are conducted. You don't have to be a user of the software to learn from their website.
One of the problems with attribute studies is that it's sometimes very difficult to come up with "bad" parts, and asking for ones that are "bad" on both ends of a bilateral tolerance can be too much to ask. Sometimes the efficacy of a gage can be deduced simply by measuring it, and other times it's not so easy, such as in the case of gages used for verifying GD&T callouts. Let's not forget that the OP was asking about the format of his template and not a tutorial on attributes gage studies.
KyleB
Quality Engineer
Yes, Both above the upper limit & below the lower limit were used.
joekirk
You should also refer to your CSR's and see if they have any specific requirements that you need to be meeting as well.
optomist1
A Sea of Statistics
I vote for continuous or variable data vs discrete Go/No - Go events...Why? If one only collects binary events, how do you know if the process if shifting out of spec? When you do its already too late you're SOL....rejecting 10 parts out of say 40, its already too late, you have lunched 10 parts or at least have to rework the same. Be proactive rather than reactive....my 5Euros worth
B IATF 16949 Cl. 8.6.6 - Acceptance Criteria - Zero Defects Attribute Data Sampling IATF 16949 - Automotive Quality Systems Standard 2
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 2
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
earl62 What is the best way to control special characteristics in Control plan? Is it Mandatory to have SPC for IATF 16949? IATF 16949 - Automotive Quality Systems Standard 7
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B IATF 16949 News Six month extension on all valid IATF 16949 certs IATF 16949 - Automotive Quality Systems Standard 10
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
S Can assembly manufacturing sub-supplier be certified IATF 16949? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 Requirement for CMMI in a Global Company Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
G Logistic organization and controls - IATF/ISO 9001 audit Nonconformance and Corrective Action 2
M Tips on preparing for IATF 16949 Internal Lead Auditor exam Manufacturing and Related Processes 1
Sidney Vianna IATF 16949 News Latest news from IATF - August 2020 IATF 16949 - Automotive Quality Systems Standard 1
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
S Definition of "worldwide" in view of IATF 16949 and Product conformity IATF 16949 - Automotive Quality Systems Standard 3
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
H Remote product audits in Coivd-19 - IATF 16949 9.2.2.4 IATF 16949 - Automotive Quality Systems Standard 3
S IATF 16949 - Partial traceability of Aftermarket products IATF 16949 - Automotive Quality Systems Standard 5
I IATF 2016 - 8.5.1.4 Verification after shutdown due to COVID19 Process Maps, Process Mapping and Turtle Diagrams 1
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
Sidney Vianna IATF 16949 News IATF opens channel for whistleblowers (21 April 2020) IATF 16949 - Automotive Quality Systems Standard 0
V Informational SMMT IATF Oversight - OEM KPI Process IATF 16949 - Automotive Quality Systems Standard 4
C Industrial scales and MSA (IATF 16949 requirement 7.1.5.1.1) IATF 16949 - Automotive Quality Systems Standard 30
V Generic IATF 16949 Audit Checklist wanted IATF 16949 - Automotive Quality Systems Standard 3
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Postpone IATF 16949 audit due to COVID-19 IATF 16949 - Automotive Quality Systems Standard 41
D Do non-IATF customers need to be included in audit scope? IATF 16949 - Automotive Quality Systems Standard 23
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
T Reaction Plan To Drive suppliers to IATF 16949 registration IATF 16949 - Automotive Quality Systems Standard 4
R IATF/IAOB Red Supplier Pilot Program IATF 16949 - Automotive Quality Systems Standard 1
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
C IATF 16949 - Scope or not? IATF 16949 - Automotive Quality Systems Standard 2
L "IATF-Compliant" IATF 16949:2016 certification? What does this mean? IATF 16949 - Automotive Quality Systems Standard 13
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
W Certification for IATF Lead Auditor will expire in 2020 IATF 16949 - Automotive Quality Systems Standard 2
B IATF certificate suspended - Who do we notify? IATF 16949 - Automotive Quality Systems Standard 6
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
C Design and implementation of process audits as defined within IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 2
M IATF 16949 (6.1.1 - Planning and Risk Analysis for a remote site) Process Maps, Process Mapping and Turtle Diagrams 5
