IATF Calibration
Currently we are doing code 00 on our calibration process but we are working with IATF certification . Is code 05will be applicable to equipment, like calipers, counting scales, gage blocks etc. how about multimeter?
Sorry not to mention the code description : please see below
Code 00: Standard calibration – data is not recorded. Unit is tested to meet manufacturer's or customer's
specification. Any points found out of tolerance are reported as tabulated data on a data report along with the
associated tolerances.
Code 01: Calibration with data – All of the above requirements for the Standard Calibration plus a data report that
includes tabulated data for all the points in the performance test procedure is issued whether they are found out of
tolerance or not.
Code 02: Calibration with range and accuracy – Range and accuracy of the equipment being calibrated is recorded
on the Calibration Certificate or attached to the Certificate. Tabulated data for all the points in the performance test
procedure is not recorded for parameters tested.
Code 03: Functional/Operational Test – data is not recorded. PMI will verify all functions of an instrument are
working properly. This unit does not require a check of accuracy a Service Report describing the Operational
Check is issued.
Code 04: Calibration with data and uncertainty – This service includes all tabulated data points in the calibration
procedure. Each data point is accompanied by an uncertainty of that measurement, as well as the limits of the
tolerance at that point. An analysis of all parameters tested is performed using standards that are not accredited.
Code 05: Accredited calibration – This is a calibration for which all data points tested within the Accreditation Scope
of PMI are reported with stated uncertainties and tolerance limits. The technician performing the calibration must be
specially qualified. The Standards utilized must be traceable through an unbroken chain of Accredited calibrations.
This service includes all tabulated data points in the calibration procedure. Any data points outside the
Accreditation Scope are annotated as such on the report and reported without uncertainty data. In addition to the
Standard PMI Certification, the customer also receives an Accredited Certification/Data Report. This special report
meets all the criteria set forth in ISO/IEC 17025:2017. It includes the Accrediting Body’s logo. Decisions on
conformance with specifications will be based on “As Found” measurements appearing within tolerances without
guard bands.
Code 06: Customer Controlled equipment -
was named killer
You have it good. It's tough to get my owner to get any hand tools calibrated. He wants to make all the tools on the floor reference and only Final Inspection tools get calibrated. UGH.
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Casana IATF 16949 7.1.5.3.2 External Laboratory - On Site Calibration IATF 16949 - Automotive Quality Systems Standard 8
N IATF 16949 7.1.5.3.2 External Laboratory - Calibration of Nikon machine in factory IATF 16949 - Automotive Quality Systems Standard 24
I IATF 16949, accredited logos, calibration capabilities, etc. IATF 16949 - Automotive Quality Systems Standard 17
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
sswaim IATF 16949 7.1.5.3.2 External Calibration Laboratory Requirelents IATF 16949 - Automotive Quality Systems Standard 15
J Calibration/Verification Records (IATF 16949 7.1.5.2.1) IATF 16949 - Automotive Quality Systems Standard 5
J IATF 16949 Calibration Laboratory Scope IATF 16949 - Automotive Quality Systems Standard 22
E IATF 16949 Cl. 7.1.5.2.1 - Calibration and Verification Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
M Producing IATF 16949 compliant calibration certificates IATF 16949 - Automotive Quality Systems Standard 24
B IATF 16949 - 7.1.5.3.1 Internal calibration laboratory requirements IATF 16949 - Automotive Quality Systems Standard 9
J IATF 16949 Cl. 7.1.5.2.1 - Gauges (Measuring Jigs) Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
M Clarification on Calibration/Verification Records 7.1.5.2.1d (IATF 16949) General Measurement Device and Calibration Topics 11
B Calibration/Verification Records - IATF 16949 section 7.1.5.2.1 f) IATF 16949 - Automotive Quality Systems Standard 6
P IATF 16949 Cl. 7.1.5.2.1 "Calibration/Verification Records" Interpretation IATF 16949 - Automotive Quality Systems Standard 12
P IATF 16949:2016 Letter of conformity IATF 16949 - Automotive Quality Systems Standard 1
D IATF PROCESSES IATF 16949 - Automotive Quality Systems Standard 2
D IATF 16949 SI 10, External non-accredited lab IATF 16949 - Automotive Quality Systems Standard 4
A Control plan for IATF - example? FMEA and Control Plans 1
J IATF CB Auditor questions Internal Auditor Competence IATF 16949 - Automotive Quality Systems Standard 19
A IATF MSA study Type 1 General Measurement Device and Calibration Topics 5
S IATF 16949 - Summary at a glance Clause wise - changes from ISO TS IATF 16949 - Automotive Quality Systems Standard 4
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
W Do Reference materials for IATF need to be 17025? IATF 16949 - Automotive Quality Systems Standard 15
D Special IATF audit of sub-supplier IATF 16949 - Automotive Quality Systems Standard 18
R IATF and ASPICE level 2 Design and Development of Products and Processes 9
T IATF 16949 Recording inspection results IATF 16949 - Automotive Quality Systems Standard 2
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
G Remote support - IATF allowed words defined? IATF 16949 - Automotive Quality Systems Standard 11
D "certified" in ISO 19011, as well as IATF required? IATF 16949 - Automotive Quality Systems Standard 6
D IATF 16949 M&TE Laboratory scope IATF 16949 - Automotive Quality Systems Standard 4
B IATF Certification Body Recommendations Registrars and Notified Bodies 3
K IATF audit day requirements table 5.2 IATF 16949 - Automotive Quality Systems Standard 6
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
M IATF - Internal Audit 3 year span Internal Auditing 4
D Bulk Materials (Greases) and IATF 16949 IATF 16949 - Automotive Quality Systems Standard 11
M New IATF Sanctioned Interpretations April 2021 IATF 16949 - Automotive Quality Systems Standard 4
L Eligible for IATF or eligible for LOC ? IATF 16949 - Automotive Quality Systems Standard 4
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 27
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 18
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 4
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
M IATF Icon pack /PNG IATF 16949 - Automotive Quality Systems Standard 0
