IATF 16949: Difference between rework and repair.
Unlike the old standard the new standard makes a clear distinction between "Repair" and "Rework".
We're having an internal discussion here how we should define these. We've referred to several of our customers' SQE and they are also clueless.
For your convenience this is what the new standard states
8.7.1.4 Control of reworked product
The organization shall utilize risk analysis (such as
FMEA) methodology to assess risks in the rework process prior to a decision to rework the product. If required by the customer, the organization shall obtain approval from the customer prior to commencing rework of the product.
The organization shall have a documented process for rework conformation in accordance with the control plan or other relevant documented information to verify compliance with original specifications.
Instruction for disassembly or rework, including re-inspection and traceability requirements, shall be accessible to and utilized by the appropriate personnel.
The organization shall retain documented information on the disposition of reworked product including quantity, disposition, disposition date and applicable traceability information.
8.7.1.5 Control of repaired product
The organization shall utilize risk analysis (such as FMEA) methodology to assess risks in the repair process prior to a decision to repair the product. The organization shall obtain approval from the customer before commencing repair of the product.
The organization shall have a documented process for repair conformation in accordance with the control plan or other relevant documented information.
Instruction for disassembly or repair, including re-inspection and traceability requirements, shall be accessible to and utilized by the appropriate personnel.
The organization shall obtain a documented customer authorization for concession for the product to be repaired.
The organization shall retain documented information on the disposition of repaired product including quantity, disposition, disposition date and applicable traceability information.
My argument is that
rework is done using IN-PROCESS methods. I.e. going back a step (or several) in the production process and re-processing the part or sub-component. Rework on the other hand is using OUT-PROCESS methods. I.e. taking the part of sub-component out of flow and bringing it to standard using an out of standard method.
How would you interpret/define repair/rework?
