ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld
True Position
#11
Re: ID Threads Shrinking due to HT and Weld
That will likely depend on the required hardness. Hardened material does not thread/tap/machine very well.
Stijloor.
While it's not usually appropriate to fast production speeds, you can actually EDM tap threads and that will work basically regardless of material hardness.
Wayne
Gage Crib Worldwide
#12
… [O]ur facility makes a number of cylindrical pins and shafts with I.D. Threads. After we tap the threads many parts will be induction heat treated or welded in an assembly. A number of times we will shrink the threads with the heat being applied and the threads will not gage. This will result in a rework op to retap and gage. Then we run into the issue of the NOGO going after being retapped. Does anyone have a better solution to this. … It seems like we have the worst luck with 1/8-27 NPSF threads. … [T]he threads at weld are caused by adjacent heating of the process.
Heat Treat normally requires a certain depth to be hard, so no matter what the threads will be affected because even if you’re not intending to go as deep as the threads the heat will have to affect the threads in order to meet the depth spec.
… You could try using a tap with a higher "H" value which will give a slightly larger thread and thus be more forgiving after heating.
Another thought is to use a thread forming tap for any retap operation. These will likely last longer since they are not "cutting" material, rather they will "Move" material so should be less likely to gage large after retap.
As is normal, I have several thoughts for you to consider.
1.
If the problem is being caused by weld spatter getting into the threads, then re-tapping is the best way to go, but use a smaller H-size for the re-tap so that you only knock off the spatter and not cut the thread larger. A second thought would to be to use worn-out taps from your manufacturing line. They have been worn smaller and might have the same effect as a smaller H-size. For the reader who does not know: Each H-size = 0.0005” increase in size with H0 being the basic screw thread pitch diameter.
2.
I notice that you are having problem with NPSF thread. This could be a serious problem as this thread is intended to have very specific dimensions held so that the connection made is a dry-seal connection. The dry-seal connection is specified when the chemical passing through the piping will eat away the seal material and then leak. The chemical passing through the piping is usually highly flammable or highly caustic, neither of which you want leaking. Being oversized could compromise the seal, and open up your company for a product liability law suit.
3.
It sounds like you are dealing with a thin-ish wall after tapping. I think JRKH is right; the material is being distorted not shrunk. It sounds like the process of tapping is forcing the tube back to round, while at the same time cutting some material out of the thread, making the final screw thread oversized. I really like JRKH’s idea of using a forming tap. This may solve your problem.
4.
I have some customers who, to compensate for heat treat distortion, cut the initial thread oversized. This again is the same as JRKH’s first suggestion. They use an oversized BHT (Before Heat Treat) GO/NOGO screw thread gages. This reduces the final rework, but the thread is really oversized and weaker. I would not advise this with an NPSF thread because it will not seal; but for a ¼”-20 UNC it might be an option.
5.
If weld spatter is not an issue, and you are only dealing with distortion, you may rewrite your acceptance requirements to require acceptance by standard GO/NOGO gages only pre-heat treatment. If you want to set a low limit to the amount of distortion, an undersized AHT (After Heat Treat) GO screw plug gage could be used to test the limit of the distortion. The final product will have distorted threads, but being that they are in a thin-ish walled part the thread will reform to round as the bolt is inserted. The NPSF is designed to have a tapered NPTF male thread inserted, so getting the male thread into the hole may be easy. The UN-series threads, if class 2B, are designed to assemble with 2A, which has an allowance (about -0.002”). The smaller size might allow it to enter the warped internal screw thread. This is something that should be tested in your facility before implementing.
I do hope you find some tidbit in the above pile of thoughts that will help solve your problem. :agree1:
B Traceability to the Thimble of ID (inside diameter) Micrometers and Depth Micrometers Calibration Frequency (Interval) 2
J Using Gage Pins - Inside diameter - Interference fit General Measurement Device and Calibration Topics 4
J Measuring Method - Inside diameter is off set from the outside diameter General Measurement Device and Calibration Topics 11
A 60601-1 : Integrated Dry ECG Electrodes = 2 Patient connections inside 1 applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Measuring FIM (TIR) - Two inside diameters - Conflicting readings between inspectors Manufacturing and Related Processes 1
Watchcat Inside the Bubble 2019 Other US Medical Device Regulations 8
S Tracking laptop movement inside the office IEC 27001 - Information Security Management Systems (ISMS) 7
D Use of hand cream inside gloves in the cleanroom for medical devices Occupational Health & Safety Management Standards 7
A Concentricity of two ID's (Inside Diameters) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Regulations for oxygen/air-tubing and connectors inside of ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T Can incoming and outgoing areas be allocated inside the store? Other ISO and International Standards and European Regulations 1
Gman2 Scope Ideas? Can our scope contain bullets? Example inside. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Electronic Components inside a Wooden Case Manufacturing and Related Processes 4
B Temperature/Humidity inside a store Human Factors and Ergonomics in Engineering 7
M Using STERILE symbols on outside and inside packaging EU Medical Device Regulations 1
rob73 A "sieve" inside a pot for seperating Tissues from Fluids - IVD or not? EU Medical Device Regulations 6
N Customer Service/Inside Sales Will Not Leave Us (Quality Assurance) Alone! Document Control Systems, Procedures, Forms and Templates 3
K Desiccants & Humidity Control inside ocean going Shipping Containers Supplier Quality Assurance and other Supplier Issues 5
B Propagation of Errors in Calculations - Thickness of a coating material inside a tube Using Minitab Software 6
Marc Automobile 'Black Box' Data - An Inside Look World News 0
A When does a project end inside a software product? Life Cycle issue IEC 62304 - Medical Device Software Life Cycle Processes 5
K Is it a nonconformity if an auditor saw ant trails on wall inside the plant? Food Safety - ISO 22000, HACCP (21 CFR 120) 22
M IPC-A-610C/D Question Inside Other ISO and International Standards and European Regulations 2
D Flame Rating for Internal Plastic Support inside of a Fire Enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
Q No Work Instruction inside Ambulance - Is it an NC? Nonconformance and Corrective Action 15
J IFU inside or outside Ortho Implant Sterile Device EU Medical Device Regulations 3
S High Voltage inside Ultrasonic Probes - Do SIP/SOP ports require isolation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T What is the significance of a drawing note number appearing inside a box Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
T Vernier Caliper Accuracy Issue - Inside measurements were slightly off General Measurement Device and Calibration Topics 7
somashekar Lead acid Batteries inside DG set acoustic enclosure - What Hazard and Risk and how ? Occupational Health & Safety Management Standards 5
S Looking for Aerospace Specs - see inside AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Is a sewer line inside the production house a Major or Minor NC? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
J Clarification of ISO 2768-1 - Inside bend radius tolerance - Metal stamped part Various Other Specifications, Standards, and related Requirements 2
K Do I need to calibrate inside tri-mics? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Paul Simpson Inside track on the UKAS accreditation pilot programme for OHSAS 18001 Occupational Health & Safety Management Standards 3
K Could a good Design FMEA have prevented this? Death inside centrally locked car FMEA and Control Plans 6
B Inside The Actors' Studio... Coffee Break and Water Cooler Discussions 1
C Number of processes identified inside your QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Customer Quality Objective - Mandatory to have documented inside QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Internal Audits must be inside of the continuous improvement cycle Internal Auditing 3
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Repeatability issue in Gage R&R study for inner diameter of a bushing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
kedarg6500 How to calculate Thread Pitch Diameter for non standard TPI like 5/8" 17.75 NF3 Manufacturing and Related Processes 3
I 3 legged 5 Why - Hole diameter Oversize caused by Gauging Problem Solving, Root Cause Fault and Failure Analysis 9
