Ideas for reducing Human Error during Order Receipt
9
93ramvert
OK we are AS9110, FAR 145 Repair Station, our order entry process is the inspector gathers info off of the customer P.O. such as P/N, S/N, P.O. #, Eng. S/N, and workscope and enters it into our system, which then generates all future paperwork regarding the Part. This entry has to be done by human interface which leaves us open for mistakes, in any of the info mentioned. Now our customer service rep. is supposed to also review the same P.O. to ensure this data is transcribed properly. We then have a sign off by an inspector who releases the part in to work after the customer approves the quote. This steps breaks down check Part, P.O. and company document to verify the correct P/N, sign and date. Check Part, P.O. and company document to verify the correct S/N, sign and date. This goes on for each human entered item. Then the final inspector does the same, and then one last step we have the shipper receiver be one last look and goes over all the paperwork before shipping. Major amounts of redundancy that is not working, we have explained the importance of having this info correct. We ship about 100-120 parts a month and we had been seeing about 5-6% incorrect entries. I implemented the sign for each item review step and we got it down to 0%, but after 3 months it?s starting to creep back up, as those who do the review are getting more complacent with process. Does anyone have any ideas that maybe you do in your shop that will help reduce these order entry issues on a consistent basis, something that cannot just be pencil whipped? It certainly doesn?t help that upper management will not address this poor behavior.
Without understanding the nature of the errors and the risks involved, it's hard to say what the problem might be. Some people are better at data entry than others. Maybe you're a small shop, but it seems odd to have an inspector doing order entry, and then have it checked by a customer service person. It seems backwards.
If order entry errors are causing trouble that results in unnecessary expense, that's one way to get managment's attention. Before beatings commence, though, you should try to determine if there's something about the process that encourages errors.
Michael_M
Can you remove the 'human review'. For example, produce a digital scan of the customer PO and the entered items and have some type of software review it (I am pulling ideas out of thin air here). Have a digital comparison of data?
9
93ramvert
The errors can be just a wrong number entered in to the system whether it be an incorrect P/N, S/N or P.O. # for instance what has caused me to start this thread, is a P.O. came in the P.O. # was SA-28304, the inspector entered SA-38304. Easy enough to make that mistake, but the follow up reviews that are "Checking" these errors are overlooked.
The reason an inspector enters the info into the system is we have to verify the proper modification level of the part prior to entering it into the system, there are a few decisions that are made at the time of entry as well and those are handled by inspectors.
sulkinsf
An ideal solution would be to error proof the data entry through electronic means.
Options:
Consider bar code or OCR entry of the data. This is not terribly expensive, especially considering its importance and inspection costs.
Steve
qualprod Ideas to stop bad practices in daily work ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
C Barcode Labelling - Mistake Proofing Ideas & Systems Manufacturing and Related Processes 2
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
O Inventory control ideas - I have an open stock room with a "sign out" book Manufacturing and Related Processes 9
Ed Panek Ideas to keep quotes for consulting service accurate on not inflated Consultants and Consulting 11
B Practical ideas for information labelling in healthcare environment IEC 27001 - Information Security Management Systems (ISMS) 2
F Ideas for brewery poka-yoke system - Labels that are glued to a bottle Manufacturing and Related Processes 0
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
D Ideas for Poka Yoke or Improvement - Aluminum FOD in Assembly Customer Complaints 3
K Looking for Calibrated Tool Shadowboard Substrate Ideas AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J ISO 17025 Guide and Ideas for a New Calibration Business ISO 17025 related Discussions 18
G Process for Product Safety - Ideas for Documenting Process for 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 3
S New Catchy Quality Policy Ideas Wanted IATF 16949 - Automotive Quality Systems Standard 4
P Need ideas on managing Shelf Life Studies within an organization ISO 13485:2016 - Medical Device Quality Management Systems 1
T Need ideas on Synchronization of Processes Design and Development of Products and Processes 2
D ISO/IEC 17025 Implementation Workshop Ideas ISO 17025 related Discussions 2
B Share ideas to make Management Review more interesting Management Review Meetings and related Processes 4
K Product Ideas for Manufacturing Startup Coffee Break and Water Cooler Discussions 4
Gman2 Scope Ideas? Can our scope contain bullets? Example inside. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Ideas for an Open Source Calibration Database Software Calibration and Metrology Software and Hardware 3
T UK Quality Engineering Courses - Your ideas please Career and Occupation Discussions 3
B Starting a small boutique and looking for business ideas Career and Occupation Discussions 8
S Ideas on QA/RA Company Magazine Other US Medical Device Regulations 4
A "Refreshing" a Company Ideas scheme Lean in Manufacturing and Service Industries 8
C Ideas on Implementing Lean and 5S Methods Lean in Manufacturing and Service Industries 6
B Need ideas for a friendly bet - Year-end food drive Coffee Break and Water Cooler Discussions 6
L Working closer and better with Suppliers - Practical ideas to improve? Supplier Quality Assurance and other Supplier Issues 8
AnaMariaVR2 Developing Innovative Ideas for New Companies: free course Training - Internal, External, Online and Distance Learning 0
K Looking for Ideas to Track Customer Requests and PPAP Data Packages APQP and PPAP 4
F Quality Awareness Sessions - Seeking Ideas and Presentation Material Quality Manager and Management Related Issues 4
A Request for Daily Talking Point and Meeting Ideas Misc. Quality Assurance and Business Systems Related Topics 15
A R&D Design Control - Ideas to Improve the Quality of Drawings Design and Development of Products and Processes 7
T Quality Control System Ideas to stream line the PPAP Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V Ideas, Measures/Metrics for making Quality Proactive? US Food and Drug Administration (FDA) 2
I Looking for Ideas/Tips for Management Review Meeting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
B Ideas on how to differentiate jobs (AS9100 jobs vs. "commercial" jobs) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Let's share ideas about an inspection problem.... Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I Any Ideas To Define The Root Cause of Corrosion Issue? Manufacturing and Related Processes 12
P Scorecard Data Forged - Ideas Please Quality Manager and Management Related Issues 3
Y Ideas of interactive exercises for a Quality Training (ISO 13485) Training - Internal, External, Online and Distance Learning 6
J Keeping Milk for Domestic Consumption Fresh - - Ideas? Coffee Break and Water Cooler Discussions 33
Chennaiite Product Release Risk Assessment - Ideas Wanted Design and Development of Products and Processes 2
A Sustainability 101 Training Ideas and Presentation Materials wanted Sustainability, Green Initiatives and Ecology 2
smryan Seeking Conference Room Name Ideas Coffee Break and Water Cooler Discussions 41
A Seeking Views and Ideas on Procedure related to Project Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Concept Process FMEA examples and ideas wanted FMEA and Control Plans 1
J Would like to remodel our QA Layout Laboratory - Your ideas appreciated Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Management Of Change System or Software - Recommendations and Ideas wanted After Work and Weekend Discussion Topics 2
