Ideas on how to differentiate jobs (AS9100 jobs vs. "commercial" jobs)
bear4489
We are a "job shop" first and foremost and we are AS9100 certified. By this I mean, our aerospace related jobs account for around 4% of our annual work load. My problem is trying to determine a good and legitimate way to differentiate between the two job types within our quality system. It is difficult to justify, and often times virtually impossible, to treat our non-aerospace jobs with the delicate and thorough nature that we do aerospace jobs. Does anyone have plausible advice on how to spell out such a situation in our systems manual, etc.?
Thanks in advance!:frust:
Jen Kirley
Quality and Auditing Expert
Re: Ideas on how to differentiate in quality system
Good morning,
Aside from the system requirements involved with AS9100, there are indeed specific product related requirements.
You are a job shop: do you use travelers or some other means to show what treatments each product run requires? In automotive this could amount to a control plan, but the aim is the same for these two industries: to make sure the needed controls are identified and then carried out. In job shops these controls, including inspection steps, are planned and laid out per product. Repeat runs may refer to earlier versions of the Traveler, with appropriate change control to ensure that only current requirements are listed.
The quality manual could describe the process in this manner, and in my view doesn't need to specifically say there's a difference in treatments for AS9100 products and the others. The manual could just say that process controls are planned and carried out per customer requirements.
I welcome other people's input on this. From what I can tell the subject has been made overly complex.
Good morning,
I think you've hit it on the head. There should be a "quality plan" (whatever form that takes, and whatever it's actually called) that spells out the requirements for each part/product. The plan should always take customer (and other) requirements into account, so if the planning is done right in the beginning, there's no need to go overboard.
bear4489
Good morning,
Thanks for your input Jennifer!
The job traveler example you used is a good one. We do, in fact, use travelers but not on all jobs. (of course we do use a traveler(s) on all aerospace jobs and/or when required) Case in point, we may have a "tooling type job" that can have in excess of 100 line items in which case we would require in excess of 100 travelers and that just doesn't seem feasible when the customer doesn't require it and our operators simply make the part(s) to print.
Jen Kirley
I think that the Traveler you are most interested in, in this case would be the one for AS9100 parts. If this method is how you define process control for these customers, is used consistently and the results are as desired, it looks like control to me. Note that the traveler doesn't need to be on paper. It could be electronic if the run is identified in a way that ties to the control plan (traveler/etc) during production and inspection. The medium is less important than that the control is in place - EXCEPT where customers have specific requirements. For example if hand-signed records with black/blue ball point pen ink are required, you'd need an appropriate medium to get it done.
Other jobs such as the tooling type job should have controls to suit them. There's no expectation that every run have its own Traveler. What works is what's right for you.
DannyK
Describe in your quality documentation how you differentiate aerospace from commercial jobs. Some companies use different color travelers or a special area where aerospace product is produced. What is important is that it is evident to everyone what is an aerospace part and what is not.
dsanabria
Keep in mind that the AS9100 auditor is looking for compliance of your shop to AS9100 requirements. Having said that... Try using different color folders, tags, paper to visually identify which jobs is aerospace and which jobs are not.
During contract review and planning of you process, don't forget to identify customer requirements in your process - (specially for non- aerospace products. Each one of your processes must meet as a minimum the ISO requirements - so be careful in the process.
NOTE: must of the AS 9100 will be verified by the auditor and that includes 100% of the scope on your certification. However, in your procedure / work instructions / shop travelers / etc... you need to clarify to the workforce what to do and not do to AS9100 product.
In reality... you could be confusing the work force with too much info (AS9100 requirement vs non AS9100) because ... the workforce will apply the wrong criteria at the wrong time and BAMG! - it will bite you at the end.
Keep it simple... meet the highest requirement on the floor, keep the information (Shop traveler) of non aerospace product concise, clear of customer requirements and to the pointshort.
P Training department ideas and development for automotive supplier Training - Internal, External, Online and Distance Learning 6
C Barcode Labelling - Mistake Proofing Ideas & Systems Manufacturing and Related Processes 2
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
O Inventory control ideas - I have an open stock room with a "sign out" book Manufacturing and Related Processes 9
Ed Panek Ideas to keep quotes for consulting service accurate on not inflated Consultants and Consulting 11
B Practical ideas for information labelling in healthcare environment IEC 27001 - Information Security Management Systems (ISMS) 2
F Ideas for brewery poka-yoke system - Labels that are glued to a bottle Manufacturing and Related Processes 0
D Error proofing ideas sheet metal punches Manufacturing and Related Processes 8
D Ideas for Poka Yoke or Improvement - Aluminum FOD in Assembly Customer Complaints 3
K Looking for Calibrated Tool Shadowboard Substrate Ideas AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J ISO 17025 Guide and Ideas for a New Calibration Business ISO 17025 related Discussions 18
G Process for Product Safety - Ideas for Documenting Process for 4.4.1.2 IATF 16949 - Automotive Quality Systems Standard 3
S New Catchy Quality Policy Ideas Wanted IATF 16949 - Automotive Quality Systems Standard 4
P Need ideas on managing Shelf Life Studies within an organization ISO 13485:2016 - Medical Device Quality Management Systems 1
T Need ideas on Synchronization of Processes Design and Development of Products and Processes 2
D ISO/IEC 17025 Implementation Workshop Ideas ISO 17025 related Discussions 2
B Share ideas to make Management Review more interesting Management Review Meetings and related Processes 4
K Product Ideas for Manufacturing Startup Coffee Break and Water Cooler Discussions 4
Gman2 Scope Ideas? Can our scope contain bullets? Example inside. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Ideas for an Open Source Calibration Database Software Calibration and Metrology Software and Hardware 3
T UK Quality Engineering Courses - Your ideas please Career and Occupation Discussions 3
9 Ideas for reducing Human Error during Order Receipt Quality Manager and Management Related Issues 4
B Starting a small boutique and looking for business ideas Career and Occupation Discussions 8
S Ideas on QA/RA Company Magazine Other US Medical Device Regulations 4
A "Refreshing" a Company Ideas scheme Lean in Manufacturing and Service Industries 8
C Ideas on Implementing Lean and 5S Methods Lean in Manufacturing and Service Industries 6
B Need ideas for a friendly bet - Year-end food drive Coffee Break and Water Cooler Discussions 6
L Working closer and better with Suppliers - Practical ideas to improve? Supplier Quality Assurance and other Supplier Issues 8
AnaMariaVR2 Developing Innovative Ideas for New Companies: free course Training - Internal, External, Online and Distance Learning 0
K Looking for Ideas to Track Customer Requests and PPAP Data Packages APQP and PPAP 4
F Quality Awareness Sessions - Seeking Ideas and Presentation Material Quality Manager and Management Related Issues 4
A Request for Daily Talking Point and Meeting Ideas Misc. Quality Assurance and Business Systems Related Topics 15
A R&D Design Control - Ideas to Improve the Quality of Drawings Design and Development of Products and Processes 7
T Quality Control System Ideas to stream line the PPAP Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V Ideas, Measures/Metrics for making Quality Proactive? US Food and Drug Administration (FDA) 2
I Looking for Ideas/Tips for Management Review Meeting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
T Let's share ideas about an inspection problem.... Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I Any Ideas To Define The Root Cause of Corrosion Issue? Manufacturing and Related Processes 12
P Scorecard Data Forged - Ideas Please Quality Manager and Management Related Issues 3
Y Ideas of interactive exercises for a Quality Training (ISO 13485) Training - Internal, External, Online and Distance Learning 6
J Keeping Milk for Domestic Consumption Fresh - - Ideas? Coffee Break and Water Cooler Discussions 33
Chennaiite Product Release Risk Assessment - Ideas Wanted Design and Development of Products and Processes 2
A Sustainability 101 Training Ideas and Presentation Materials wanted Sustainability, Green Initiatives and Ecology 2
smryan Seeking Conference Room Name Ideas Coffee Break and Water Cooler Discussions 41
A Seeking Views and Ideas on Procedure related to Project Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Concept Process FMEA examples and ideas wanted FMEA and Control Plans 1
J Would like to remodel our QA Layout Laboratory - Your ideas appreciated Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Management Of Change System or Software - Recommendations and Ideas wanted After Work and Weekend Discussion Topics 2
P Floor Supervisor End of Shift Report ideas and/or template wanted Manufacturing and Related Processes 7
