tomvehoski
If each bag is already labeled with contents, I would say you don't have to label the pallet or the shelf. As long as you have a method to tell what is what, you are OK. From what I have seen on most food products, they are clearly labeled with lot/date codes. If you have more than one type of flour the type should also be identified.
Ask yourself if lack of labeling shelves will cause problems - is there a chance someone will pull sugar instead of flour, and the wrong ingredient will be used?
Hope this helps,
Tom
Hope this helps,
Tom
