Identification of gage blocks
QAJA1717
Hi All,
I'd like to know if anyone has a solution for the following:
We have a number of gage block sets all of which runs in different calibration cycles, in some cases are of different classes. I'd like to avoid the gage blocks being removed and then placed back in the wrong box. My idea is to color code the blocks. Perhaps painting them in the uncalibrated side (a small dot) - still deciding on the proper paint to use.
Can anyone else throw in any other ideas?
Regards to all,
-J
Golfman25
Yeah. Don't calibrate every set of gage blocks. Verify them prior to use. Have a master set that you calibrate and keep for special uses only.
If you go with identification, Paint can wear off. Maybe have them engraved?
L
locutus
This is a tough question because I had the same problem with not just gage blocks, but pin gages. You could engrave gage blocks, but make sure it does not "impact" the calibration status. Paint can wear off.
It is probably not the best but as mentioned by Golfman we only had certain gages calibrated. We actually kept them in a separate location, in plastic containers/totes/bags with the actual identification. The users went through heavy training that when they used the blocks and pins to take them out of their individual container (that was marked with ID and calibration status) and immediately return them when done.
If they failed to do that, they were subjective to harsh versions of death :tg: haha just kidding. But it could and did impact their employment status if they did not follow the procedure for handling gage blocks. If they don't need to be calibrated but just verified such as using in go/no-go in production, they were just verified on a routine basis. Many of our pin gages were replaced every time anyway because they got bent and scratched - so we never bothered calibrating them, but just had a short time period between verifications - which was really more an inspection of the block/pin for damage or usability.
QAJA1717
Thanks for your feedback, everyone. We opted for marking with paint (Rust-oleum). Although we'll be working hard to instill better discipline on our operators and inspectors, the idea behind paint-marking the gages are to be able to easily identify them as we sweep the shop floor. Simply engraving the gages won't give off the same visual indication. We'll try it out for a couple of months.
- J
Kronos147
Gage pins:
I have long been an advocate for verify before use. I got in trouble for records once so we use a sign up sheet with some measurements on it.
We were always verifying before use, but now we have effective records as well.
We use a calibrated micrometer to check the pins.
Eredhel
Quality Manager
We're a big fan of verify prior to use as well for anything that isn't used for final acceptance.
normzone
Yes, but at least they know to look in the dust pan each day :)
I hadn't thought about the benefits of color - almost as good as a state license plate at a glance. Just renew it as required.
R Gage Identification Methods in a Job Shop Calibration Frequency (Interval) 8
D What is a good way for identification of gage pins - Machining Department General Measurement Device and Calibration Topics 17
T Pin gage identification in a small CNC/Screw machine job shop General Measurement Device and Calibration Topics 9
G Clause 8.5.1 -- Is non Identification evidence of ineffective control of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
M ISO 13485:2016 Identification & Traceability ISO 13485:2016 - Medical Device Quality Management Systems 4
T Use errors identification - based on primary operating functions or use scenarios ? IEC 62366 - Medical Device Usability Engineering 3
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 7
H Resin Identification Code Applicability REACH and RoHS Conversations 1
H Marking of Resin Identification Code CE Marking (Conformité Européene) / CB Scheme 0
C Document Identification Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R IRB Identification US Food and Drug Administration (FDA) 0
J Help needed on clauses identification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Y CE marking with NB identification number EU Medical Device Regulations 0
Q ISO 20417:2021- Regulatory Identification Other ISO and International Standards and European Regulations 3
R UDI Number Identification EU Medical Device Regulations 5
K Identification test in ph.eur. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
S SOP Identification of Special Characteristics IATF 16949 - Automotive Quality Systems Standard 9
I Hazard Identification and Naming ISO 14971 - Medical Device Risk Management 10
C ISO 45001 6.1.2.1 Hazard Identification Occupational Health & Safety Management Standards 1
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Identification of hazards and Risk file IEC 62366 - Medical Device Usability Engineering 15
M Medical Device Identification & Codes - Article 27 Requirements questions EU Medical Device Regulations 1
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
qualprod Monitoring of lead time - Good KPI identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
qualprod Controlled sticker for product identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Watchcat Identification of Test Sample in Test Reports? Design and Development of Products and Processes 22
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Informational EU – Unique Device Identification (UDI) System – FAQs Medical Device and FDA Regulations and Standards News 0
S ISO 14971 Risk Management - Questions for Hazard identification ISO 14971 - Medical Device Risk Management 2
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
M Informational USFDA final guidance – Unique Device Identification: Convenience Kits Medical Device and FDA Regulations and Standards News 0
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S Looking for procedure on UDI (Unique Device Identification) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S UDI (Unique Device Identification) Requirements for Remanufactured devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Quality Management System documentation identification Document Control Systems, Procedures, Forms and Templates 11
K Document Numbering (Identification) System Document Control Systems, Procedures, Forms and Templates 10
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
M RFID (Radio Frequency Identification) Registration in Europe and in MENA countries EU Medical Device Regulations 1
qualprod Identification of Training Needs = People Performance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H European Pharmacopoeia First Identification Requirements Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
Q ISO 9001 Cl. 8.5.2 and 8.5.4 - Identification in Products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Measurement Equipment - Identification of Calibration Status General Measurement Device and Calibration Topics 25
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
M Risk Identification and Risk Assessment for any Process - Is it necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
Edward Reesor UDI (Unique Device Identification): HIBCC or GS1? ISO 13485:2016 - Medical Device Quality Management Systems 39
