Identification of Test Sample in Test Reports?
Watchcat
I have noticed that engineering test reports often do not identify the test sample(s).
By "identify," I mean by something like a batch/lot number that would allow traceability to the sample's manufacturing methods and materials, rather than by a brand/model name and number (e.g. Craftsman 1/4-in slotted screwdriver, Model#123) or a physical description (e.g., 1/4-inch slotted screwdriver 12 inches long with acetate handle, etc).
I would be interested to know other people's experience and perspective on this, especially:
If you frequently read/review test reports, what is your experience with test sample identification? Do the reports you read always/usually/sometimes/rarely identify the test sample(s)?
If you routinely prepare test reports, do you typically identify the test sample(s)? Why or why not?
Are there circumstances in which you think test sample identification is critical? Circumstances in which you think it isn't necessary?
Do you know of any authoritative sources for the format and content of an engineering test report?
In general, the requirements for test reports will vary with the circumstances. An in-house report might have different requirements from one that's being provided to a customer, or a report from a contracted independent lab. There are no "authoritative" sources for content that I know of; requirements become authoritative when prescribed or agreed to between parties.
Again in general, reports should identify the specimen(s) tested to the extent that identification is germane to the party that ordered the testing. It's important to define what the output should include when testing is ordered.
Ronen E
Problem Solver
Moderator
Usually.
I always identify the test samples to the extent I can. Sometimes the information available to me for the preparation of the report is partial.
Why? To "allow traceability to the sample's manufacturing methods and materials", as well as unambiguous specificity of the design that was evaluated.
Define Critical please.
There are no circumstances in which I think it isn't necessary.
Applicable regulations (I'm answering from the narrow perspective of medical devices).
Having said all that, it's important to note that "identification of the test specimen" is typically not binomial. Even just stating the model is some level of identification (higher than just "A screwdriver", or naming the manufacturer and providing some descriptors). Some products are manufactured in lots and are also assigned individual serial numbers, so in such instances calling out a lot number is a more precise identification than just the model number, but it's not as precise as specifying individual serial numbers of the evaluated units. What level is necessary is context-dependent.
Ronen E
Problem Solver
Moderator
Yes, but as this post illustrates, even providing the necessary information can get you in trouble if a person who reads the report doesn't know what he's reading.
In that case the amount and type of information didn't best address the report's purpose (in that specific context), which would have been easily appeasing even a mediocre auditor lacking the necessary background, without having to waste 45 minutes in educating them :)
It absolutely suited the purpose, unless you think that the purpose was to dumb down the report. Each of the specifications were cited in the report, including the one that said that one of the criteria for passing was cohesion failure of the vinyl. After the initial explanation, I should not have had to explain further. The auditor was an idiot, and I for one won't ever aim that low.
Watchcat
If I may be so bold, to me this illustrates the difference between seeking regulatory clearance for a medical product and certification for other kinds of products, as well as the role of regulatory (as opposed to compliance) in the former.
In many industries, the extra time and effort that would be required to lay out the rationale for the various tests and carefully explain the link between the results and the performance of the product under conditions of actual use (e.g., why it was a good thing that foam would come apart before the glue would fail) simply isn't worth it from a business perspective. The reasons why not vary with the business and the product, but if you have to do a lot of testing and invest this effort for every test, the value of the product itself, in terms of ROI on that investment in the form of profit, the cost will make the product unattractive as a business venture. On the whole, products with medical application offer a higher ROI than many other products, and therefore are more likely to be worth this investment.
There is also a time pressure, especially for pharma/device startups, which frequently report that they failed because "they ran out of money," a high-level reason that covers a multitude of sins. Nonetheless, it is true that many medical startups run at a crazy burn rate, and, by the time they submit their product to the regulators, they may be looking at the edge of a cliff. If their market clearance gets bogged down, they can run out of the money needed to see it through, and investors, who expect not only a certain return, but within a certain period of time, will decide to write off sunk costs and direct future investments elsewhere. In contrast, a "going concern" with a catalog of products has money coming in on an ongoing basis, and one product getting hung up in certification is unlikely to put them under.
Finally, in most cases, the relationship between test results and conditions of use is much more straightforward with non-medical products (even I got it about the glue and the foam) than with medical use/indication. I don't think it is unreasonable to expect most reviewers to be able to grasp the former relationship with reasonable ease most of the time, where I think it is unrealistic to expect any regulatory agency to have enough reviewers with the range of knowledge, coupled with experience, needed to figure out these links for all the testing done on all the many medical products put before them. And certainly not quickly and easily.
When it comes to putting together a regulatory submission, I've always described my role as writing "the glue that holds the submission together," including, in particular, carefully explaining the links between intended use/indication and test results. I work from the assumption that the reviewers will not see these links unless I explain them to them, and, even if they do, it will take them longer to figure out at least some of the links on their own than it will take them to read through a (hopefully) succinct and cogent explanation. My job is to do whatever I can do to make the review go like butter.
What is not different is that you will come across reviewers in both environments who, having missed the point the first time, will stubbornly dig in their heels, sigh. The ensuing efforts to resolve this kind of impasse can easily lead to delays that a medical startup can literally not survive.
Ed Panek
QA RA Small Med Dev Company
Depending on the test I keep samples. For shelf life extension we store the actual samples used in our red tag storage area on a special shelf. If a regulator could question the results ata later date I usually try to ID and retain the samples used.
Also...
F PPAP Material Test Results Requirements - Material Supplier Identification QS-9000 - American Automotive Manufacturers Standard 1
G Identification of Product Status in Assembly and Test Areas ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Plastic Identification/Test - Melt Flow Index to Determine Correct Material? Manufacturing and Related Processes 16
L Identification of Inspection and Test Status Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
I Hazard Identification and Naming ISO 14971 - Medical Device Risk Management 10
C ISO 45001 6.1.2.1 Hazard Identification Occupational Health & Safety Management Standards 1
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Identification of hazards and Risk file IEC 62366 - Medical Device Usability Engineering 7
M Medical Device Identification & Codes - Article 27 Requirements questions EU Medical Device Regulations 1
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
qualprod Monitoring of lead time - Good KPI identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
qualprod Controlled sticker for product identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Informational EU – Unique Device Identification (UDI) System – FAQs Medical Device and FDA Regulations and Standards News 0
S ISO 14971 Risk Management - Questions for Hazard identification ISO 14971 - Medical Device Risk Management 2
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K Identification and Traceability with an ERP system - Barcode Labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
M Informational USFDA final guidance – Unique Device Identification: Convenience Kits Medical Device and FDA Regulations and Standards News 0
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
S Looking for procedure on UDI (Unique Device Identification) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S UDI (Unique Device Identification) Requirements for Remanufactured devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Quality Management System documentation identification Document Control Systems, Procedures, Forms and Templates 11
K Document Numbering (Identification) System Document Control Systems, Procedures, Forms and Templates 10
N Requirements for the identification and traceability of demo product for sales force US Food and Drug Administration (FDA) 1
M RFID (Radio Frequency Identification) Registration in Europe and in MENA countries EU Medical Device Regulations 1
qualprod Identification of Training Needs = People Performance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H European Pharmacopoeia First Identification Requirements Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Q Identification of gage blocks General Measurement Device and Calibration Topics 8
DeeDeeM IATF16949, clause 8.5.2.1 Identification and traceability-supplemental IATF 16949 - Automotive Quality Systems Standard 1
DeeDeeM IATF 16949 - Clause 8.5.2 Identification and Traceability IATF 16949 - Automotive Quality Systems Standard 7
Q ISO 9001 Cl. 8.5.2 and 8.5.4 - Identification in Products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Measurement Equipment - Identification of Calibration Status General Measurement Device and Calibration Topics 25
J Customer Identification and Traceability in Manufacturing Plans Manufacturing and Related Processes 5
M Risk Identification and Risk Assessment for any Process - Is it necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
Edward Reesor UDI (Unique Device Identification): HIBCC or GS1? ISO 13485:2016 - Medical Device Quality Management Systems 39
R Identification of Medical Devices in MDD 93/42 Certificate EU Medical Device Regulations 2
L Managing Finance Processes - Identification of Sub Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Informational Is Identification of Risks and Opportunities required for QMS Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 96
dubrizo Initial Supplier Identification, Review and Controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
H UDI (Unique Device Identification) Requirements for IVD Software EU Medical Device Regulations 2
A Receiving Goods Inwards - Identification Records and Data - Quality, Legal and Other Evidence 8
Pmarszal UDI (Unique Device Identification) Transition Period - Packaging Labeling Other US Medical Device Regulations 5
Q RFID (radio frequency identification) registration for Medical Device Other Medical Device Regulations World-Wide 6
B Class II Medical Device UDI (Unique Device Identification) Question(s) Other US Medical Device Regulations 8
A Is Risk Identification and Treatment a Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
D 820.120 UDI (Unique Device Identification) Labeling Verification Requirements Other US Medical Device Regulations 11
M Identification of Glass Instruments and Measurement Devices General Measurement Device and Calibration Topics 2
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
