Identification & Traceability Application Differences
MDWEEK
1-What is the difference in application between identification& tracibility?:thanx:
2- in d&d shall i mention only what the company is doing in design process ?
GStough
Re: What is the Difference in Application between Identification & Traceability
Identification pertains to labeling of product during all stages of production to prevent mix-up, etc. Traceability pertains to tracing components/finished product from the beginning of the production process (raw materials, bill of materials, etc.) through to delivery of product (including customer's name/address) so that in case of recall all product can be traced forward (to the customer and/or end user) and backward (all the way back to the supplier of raw materials).
Hope this helps. :bigwave:
MDWEEK
SO
Identification is for product
tracibility is for components of product
thank you:thanks:
Ted Schmitt
Just to help abit on the clarification (or not) :notme:
ISO 9000:2005
3.5.4
traceability
ability to trace the history, application or location of that which is under consideration
NOTE 1 When considering product (3.4.2), traceability can relate to
— the origin of materials and parts,
— the processing history, and
— the distribution and location of the product after delivery.
MDWEEK
thank you
i understood thank you
what about the rest of my question
for D&D shall i mention& describe only what the company is doing in her design process or shall i do more than that:thanks:
Ted Schmitt
Sorry, but not quite sure what you are asking... could you clarify ?
MDWEEK
I need to prepare design and development procedure for my construction company and i`m asking shall i write what they do in design only or do more?:thanks:
Ted Schmitt
Since you are the implementation phase of you quality management system, I would document what exactly is done today... if you want to improve your D&D department and outputs later, go for it... keep it simple and functional.
Colin
Are you asking whether only clause 7.3 is applicable because they are a design company?
If so, you also have to address the other clauses of the standard as well. It just happens that design is 1 of their processes.
