Identifying Hazards - Risk management process
mf389
I have a question as it related to the risk management process.
For instance,
Say I have a sequence of events which results in harm. (we include not being able to use the device as harm)
The sequence of events is:
(1) User applies heat to device in order to reshape it (normal use)
(2) user accidentally applies heat for too long
Hazardous Situation:
The device melts and is damaged
Harm: The user is prevented from effectively using the medical device to achieve its intended purpose
My QUESTION is:
What would be the appropriate hazard here? What is the true source of the harm? The use error is what results in the device not being functional but without the heat, the Use error cannot happen?
(1) Energy Hazards/ Thermal Energy: High Temperatures
(2) Operational Hazards / Use Error: Attention Based Failure
The appropriate hazard would be operational Hazards / Use Error: Attention Based Failure. Energy Hazards is a byproduct of the use error. You would normally define a risk control to cut out the heating mechanism at certain temperatures.
mf389
Are you looking at the hazards that lead to harm to the patient AND the hazards that lead to harm to the device (damage)?
yodon
It's always helpful for me to refer back to the definitions. Per 14971:
harm - physical injury or damage to the health of people, or damage to property or the environment
You could include damage to the device but it seems like, in your case, the focus would be on the patient and the device not being available. The control, as @Hemanth Kumar points out, might be to prevent melting the device - which would cover both the patient harm (unavailability) and the device harm.
Ronen E
Problem Solver
Moderator
I look at that scenario in this way:
Hazard = potential source of harm. At the most basic level it is the need to reshape the device. Maybe that's part of the intended use and nothing can be done about it, but we don't know because we have very limited information here. One of the prerequisites for effective risk management is full access to design information (including the design input). At the next level, the hazard can be seen as the need to reshape the device through application of heat. Is there a design alternative to achieve the same without applying heat? That would be an elimination of the hazard (potential source of harm) - Inherently Safe Design (ISD). Next up, the hazard can be seen as the material being sensitive to the duration of heating (i.e. requires a certain duration, tolerates an extra t1 without damage, irreversibly destroyed after t2). An ISD in that frame of thinking would be a different material that doesn't have such a sensitivity at all. Etc. etc.
Everything and anything to do with use errors in the presence of the hazard (i.e. the potential source of harm is not eliminated) is Protective Measures (PM), which is a less favourable course of action. Any PM that would break an identified chain / combination of events / circumstances is worth considering as a risk control.
Tidge
"Not being able to use a device" is not a harm. In some circumstances it could possibly lead to a harm, but no one is being harmed right now by not using your device.
M Identifying Applied Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Identifying and Controlling External Documents Document Control Systems, Procedures, Forms and Templates 3
O Identifying KPI for AS9100 8.1.4 - Prevention of Counterfeit Parts - PCB assembly contract manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Identifying internal issues.. at what level? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Identifying externally provided services referenced by IATF16949 IATF 16949 - Automotive Quality Systems Standard 2
Marc ISO 9001:2015 - Identifying interested parties, or stakeholders ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Identifying AS9100 for a Legacy Product Manufacturing and Related Processes 11
Highground Identifying Guidance on Medical Device Software Level of Concern for the EU EU Medical Device Regulations 2
S Identifying Objectives & Targets for Quality Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J API Q1 5.6.1.2 (iii) Identifying how the supplied product conforms Oil and Gas Industry Standards and Regulations 1
A Identifying context for every process in an organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
T "Indication for Use" Identifying Specific Procedures US Food and Drug Administration (FDA) 2
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
Y Identifying lighting requirements for in house Calibrations General Measurement Device and Calibration Topics 8
A Identifying and Tracking Customer Specific Requirements Customer and Company Specific Requirements 1
P Identifying Medical Device Class and Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Identifying gaps over ISO 13485 to be compliant to MDD 93/42/EEC requirements EU Medical Device Regulations 5
A Please suggest analysis for identifying the warranty Reliability Analysis - Predictions, Testing and Standards 1
P Renault CSR - Identifying the difference between an ASES and ASAS-P Audit IATF 16949 - Automotive Quality Systems Standard 4
Q Identifying Critical Items and Key Characteristics - Product Realization Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Procedure for Maintaining Industry Standards and Identifying Revisions Document Control Systems, Procedures, Forms and Templates 1
S Identifying Processes in a Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Risk Factors Checklist identifying the Risks for meeting the Customer Indent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Identifying version of Standards in Functional Specification of a New Device ISO 13485:2016 - Medical Device Quality Management Systems 6
K Identifying Required Testing to comply with IEC 60601 EU Medical Device Regulations 4
C Document Control and Identifying Distribution ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Identifying Potential Automotive Suppliers before Developing New Products Supplier Quality Assurance and other Supplier Issues 2
R Identifying procedures that are NOT required by ISO 9001 Quality Manager and Management Related Issues 17
N Identifying Changes and Revisions in QMS Documents - 4.2.3.c Requirements Document Control Systems, Procedures, Forms and Templates 13
J Help in identifying Legal and other requirements for Indian localisation Miscellaneous Environmental Standards and EMS Related Discussions 4
A Audit NC - Not identifying our Customer Specific Requirements - TS16949 (7.3.6.3) General Auditing Discussions 7
8 Introducing a Balance Line - Identifying potential future pitfalls etc. Lean in Manufacturing and Service Industries 2
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
F Requesting Help in Identifying Ford Suppliers Supplier Quality Assurance and other Supplier Issues 6
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
A Identifying the Clean Room Requirements for a Medical Device in US and EU ISO 13485:2016 - Medical Device Quality Management Systems 3
M Identifying Routine and Non-Routine Activities: OSHA OHSAS 18001 Occupational Health & Safety Management Standards 6
E Developing the Essential Requirements Checklist - Identifying Requirements Other US Medical Device Regulations 3
E Identifying the Elements of Informed Consent expected by the IRB and FDA Other US Medical Device Regulations 4
F Identifying Calibration on Small Tools (Measurement Equipment) General Measurement Device and Calibration Topics 2
C Identifying Response Times for CAPAs (Corrective and Preventive Actions) Nonconformance and Corrective Action 2
J Need help identifying nonconformities in internal audits Internal Auditing 2
A Identifying trends in QMS Nonconformities Quality Manager and Management Related Issues 1
B Looking for a Standard identifying SME's (Standard Measuring Equipment) General Measurement Device and Calibration Topics 1
C CB Client Contract Agreement - Identifying nonconformances - AS9100 Registrars and Notified Bodies 7
M Identifying Rework in Maintenance or Craftsman Operations Lean in Manufacturing and Service Industries 12
R Identifying "or equivalent" Test Equipment when written in a Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Sheet Metal Identification Ideas - Best Practices for Identifying Raw Material Document Control Systems, Procedures, Forms and Templates 8
