Identifying procedures that are NOT required by ISO 9001
R. Harris
This is my first post so I hope I am doing this properly.
I am in the prcoess of implementing ISO 9001 (to become certified). I have developed many quality system procedures for various departments to identify responsibility and authority as well as identify what is required by ISO 9001.
My question is how do I identify these procedures that are not required by ISO 9001 (ex: Design and Development Control)? Do I still identify them as quality sytem procedures or do most companies refer to them as work instructions? I am avoiding any reference to them in the Quality Manual.
insect warfare
QA=Question Authority
Re: Quality System Procedures
Most people that I know like to address the requirements of 5.5.1 (Responsibility and Authority) through the use of an organization chart, also in conjunction with documented job descriptions which address more specific roles. These 2 documents are not required by the Standard, though they do make good business sense in most cases.
Can you tell us a little more about what you do? Like:
1) What type of work do you do?
2) What industry do you work in?
3) Do you develop and design your company's product(s)? If no, you may be able to claim an exclusion to the requirements of 7.3
Brian
Chance
The key is to document the vital elements of how the business operates. This can be documented in a form of a work instruction. You can indicate in your work instruction the purpose, scope, responsibilities, then action steps...
The standard ISO requirements can be documented in a separate work instruction for each of the following items:
1. control of documents
2. control of nonconfomity
3. internal audits
4. corrective action
5. preventive action
6. control of records
Sidney Vianna
Post Responsibly
Welcome to The Cove. Despite the fact that you can "identify" those documents any way you like, don't try to find a loophole in the standard. If you deem necessary a document to describe and control your product design and development process, EVEN if you call that document a work instruction, it falls under the auspices of a procedure (for 4.2.2 b) purposes); pay close attention to the following ISO 9001:2008 requirement
The quality management system documentation shall include documents determined by the organization to be necessary to ensure the effective planning, operation and control of its processes.
Such documents include the ones referred to in 4.2.2 b). So, do NOT avoid including/referring to them in the Quality Manual. You would be doing yourself a big disservice.
ssz102
i think you need to more read the standard of ISO9001, most of people mentioned only you development 6 documents to establish QMS, so except for these documents, other you can as WI to develop
somashekar
When you identify your processes that interact in your QMS operation, which is a requirement in ISO9001, and shows up in the quality manual, you will see clarity of what procedures applicable to the various processes are required by you. The rest are not required.
As a crude example.,
The maintaining procedure of your motor that runs your air compressor required for your manufacturing line is a requirement, while the maintaining procedure of your motor that operates your landscape fountain is not a requirement.
Since QMS is dynamic, your constant review and update of your process and interactions is required.
Richard Davison
As we do not engage in any Design & Development activities we have excluded clause 7.3 from our QMS which is totaly acceptable. We have kept a reference to this in our Quality Manual as follows;
7.3 Design & Development
At (our Company) we do not engage in designing, developing or changing the design of the products we supply. To this end, our quality management system does not encompass product design and development processes and therefore, clause 7.3 is not applicable to our business and has been excluded.
R. Harris
Thanks for the variety of responses. It seems we have some companies that reference all the quality system procedures and some that do not (if they are not required by ISO).
I recently had a consultant tell me that it's best not to refer to the procedures in your quality manual if they are not required. So I was considering making them work instructions so they are not as easily audited in the registration audit.
insect warfare
I have seen companies who write out each and every procedure in their quality manual only to update it frequently when a procedure goes obsolete. On the flipside, I have seen quality manuals that reference the webpage or shared folder itself, whatever you like, and this (I think) satisfies the 4.2.2b requirement to at least reference your procedures.
It would also protect your manual from redundant updates as your QMS documentation matures over time.
Something to chew on...:D
Brian
Sidney Vianna
Post Responsibly
I am sorry to say, but this is another case of poor advice/consulting. Not only from an ISO 9001 implementation perspective, but from a business perspective.
Consultants that (try to) find loopholes to make their clients pass audits easier are a big part of the problem. Organizations that hire them are just adding to the problem, not the solution.
Documentation should not exist in order for organizations to pass an audit, but instead, to help them in planning, executing and monitoring their business processes. It is sad to see organizations continually misperceiving ISO 9001 certification as a "pass-the-audit-and-get-the-cert" exercise.
25 years after the introduction of ISO 9001, we still struggle with this.
T "Indication for Use" Identifying Specific Procedures US Food and Drug Administration (FDA) 2
M Identifying Applied Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Identifying Hazards - Risk management process ISO 14971 - Medical Device Risk Management 6
C Identifying and Controlling External Documents Document Control Systems, Procedures, Forms and Templates 3
O Identifying KPI for AS9100 8.1.4 - Prevention of Counterfeit Parts - PCB assembly contract manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Identifying internal issues.. at what level? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Identifying externally provided services referenced by IATF16949 IATF 16949 - Automotive Quality Systems Standard 2
Marc ISO 9001:2015 - Identifying interested parties, or stakeholders ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Identifying AS9100 for a Legacy Product Manufacturing and Related Processes 11
Highground Identifying Guidance on Medical Device Software Level of Concern for the EU EU Medical Device Regulations 2
S Identifying Objectives & Targets for Quality Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J API Q1 5.6.1.2 (iii) Identifying how the supplied product conforms Oil and Gas Industry Standards and Regulations 1
A Identifying context for every process in an organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
LRE67 Need help identifying this "thing" Coffee Break and Water Cooler Discussions 9
Y Identifying lighting requirements for in house Calibrations General Measurement Device and Calibration Topics 8
A Identifying and Tracking Customer Specific Requirements Customer and Company Specific Requirements 1
P Identifying Medical Device Class and Applied Part IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Identifying gaps over ISO 13485 to be compliant to MDD 93/42/EEC requirements EU Medical Device Regulations 5
A Please suggest analysis for identifying the warranty Reliability Analysis - Predictions, Testing and Standards 1
P Renault CSR - Identifying the difference between an ASES and ASAS-P Audit IATF 16949 - Automotive Quality Systems Standard 4
Q Identifying Critical Items and Key Characteristics - Product Realization Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
D Procedure for Maintaining Industry Standards and Identifying Revisions Document Control Systems, Procedures, Forms and Templates 1
S Identifying Processes in a Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Risk Factors Checklist identifying the Risks for meeting the Customer Indent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Identifying version of Standards in Functional Specification of a New Device ISO 13485:2016 - Medical Device Quality Management Systems 6
K Identifying Required Testing to comply with IEC 60601 EU Medical Device Regulations 4
C Document Control and Identifying Distribution ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Identifying Potential Automotive Suppliers before Developing New Products Supplier Quality Assurance and other Supplier Issues 2
N Identifying Changes and Revisions in QMS Documents - 4.2.3.c Requirements Document Control Systems, Procedures, Forms and Templates 13
J Help in identifying Legal and other requirements for Indian localisation Miscellaneous Environmental Standards and EMS Related Discussions 4
A Audit NC - Not identifying our Customer Specific Requirements - TS16949 (7.3.6.3) General Auditing Discussions 7
8 Introducing a Balance Line - Identifying potential future pitfalls etc. Lean in Manufacturing and Service Industries 2
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
F Requesting Help in Identifying Ford Suppliers Supplier Quality Assurance and other Supplier Issues 6
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
A Identifying the Clean Room Requirements for a Medical Device in US and EU ISO 13485:2016 - Medical Device Quality Management Systems 3
M Identifying Routine and Non-Routine Activities: OSHA OHSAS 18001 Occupational Health & Safety Management Standards 6
E Developing the Essential Requirements Checklist - Identifying Requirements Other US Medical Device Regulations 3
E Identifying the Elements of Informed Consent expected by the IRB and FDA Other US Medical Device Regulations 4
F Identifying Calibration on Small Tools (Measurement Equipment) General Measurement Device and Calibration Topics 2
C Identifying Response Times for CAPAs (Corrective and Preventive Actions) Nonconformance and Corrective Action 2
J Need help identifying nonconformities in internal audits Internal Auditing 2
A Identifying trends in QMS Nonconformities Quality Manager and Management Related Issues 1
B Looking for a Standard identifying SME's (Standard Measuring Equipment) General Measurement Device and Calibration Topics 1
C CB Client Contract Agreement - Identifying nonconformances - AS9100 Registrars and Notified Bodies 7
M Identifying Rework in Maintenance or Craftsman Operations Lean in Manufacturing and Service Industries 12
R Identifying "or equivalent" Test Equipment when written in a Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Sheet Metal Identification Ideas - Best Practices for Identifying Raw Material Document Control Systems, Procedures, Forms and Templates 8
