I have question on temperature monitoring test of 60601-1
11.1.3 e) Test criteria :
The maximum temperature of a part is determined by measuring the temperature rise of the part under test and adding it to the maximum allowed ambient temperature specified in the technical description (see 7.9.3.1).
In technical description operating temperature range is 10 to 50 degree specify. So max temp is 50 degree.
At a time of temperature measurement I tested the applied part temperature increase on 4 degree then we have to add the 4 degree on max operating temp range i.e 50 then maximum temperature of a applied part is 54 degree. As per table 24 on 60601-1 applied part temp is 43 degree then how can i concluded on that. Please help me.
Regards
Roshan
Regards
Roshan
