IEC 60601-1-2 EMC Tables
MikeKilkelly
It is my understanding that the IEC 60601-1-2 - 3rd edition requirement to have EMC tables in the Instruction manual is not a requirement for the 4th Edition of IEC 60601-1-2
Is there any requirement then to supply these EMC tables for product sold in the U.S?
regards
Mike
Hi Mike,
You are right to say that there is no absolute requirement to include the tables that were introduced by IEC 60601-1-2:2001 and retained by the 2007 edition.
However, clause 5.2.2.1 demands that the 'Technical Description' includes
a) compliance for each part of the tests
b) any deviations
c) all necessary instructions...
I have found that the easiest way to satisfy these requirements is to include the information... in a set of tables! - I have retained the existing tables as the least effort to comply.
Kuldeep Singh
Hi Everyone,
We are manufacture of Class II medical Device. Can anyone tell me about the "Immunity to proximity fields from RF Wireless communications equipment" under Cl. 8.10 of IEC 60601-1-2:2014.
Is it applicable to all medical devices ?
or
applicable only to those products having some wireless communications?
Your help will be appreciated and thanks in advance.
It is applicable to all devices.
There is such a proliferation now of mobile phones, pagers, walkie-talkies, wifi routers etc etc that medical devices can be expected to be exposed to that these tests become necessary.
And remember, this list is just a suggested minimum test requirement - depending on your device and it's proposed use scenario, you may have to do further tests or use higher levels than in the table.
Kuldeep Singh
Thanks Pads38 , Our devices are mostly used in Controlled environment like ICU, Operation theaters where Mobile phones are prohibited, secondly a warning for not using RF wired and wireless communication outlined in IFU. Can we justify this for non performing this test. Although our machine is tested as per IEC 61000-4-3 upto 2.7GHz.
Otherwise we have to send our all the machine to external lab for this test if there is any lab having feasibility upto 5.7GHz frequency range.
Jaydub
Any EMC test lab with IEC 60601-1-2 in their scope would be capable of performing this test. In addition to mobile phones, it also covers WiFi, Bluetooth etc. It might be one of those cases where it is easier to do the test than to explain why you didn't.
J IEC 60601-2-2 - EMC Requirements - Surgical instrument manufacturer IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
O EMC testing per IEC 60601-1-2 for considering new cables CE Marking (Conformité Européene) / CB Scheme 1
O EMC testing under RED and IEC 60601-1-2 CE Marking (Conformité Européene) / CB Scheme 1
C EMC Test Report Requirements to IEC 60601-1-2:2009 ISO 13485:2016 - Medical Device Quality Management Systems 4
P New EMC standard IEC 60601-1-2:2014 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
T IEC 60601-1-2 EMC and WiFi IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
T How to fulfill IEC 60601-1-2 EMC Testing Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S IEC 60601-1-2 EMC Testing Optional in US? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
C An ongoing EMC test in accordance with IEC/EN 60601-2-47 EMC IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
J EMC (Electromagnetic Compatibility) Requirements - IEC 60601 3rd edition Clause 17 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S EMI/EMC Failure Cause Analysis per IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Do HF accessories require EMC testing according to IEC 60601-1-2? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
S Does a 12V DC device need EMC (IEC 60601-1-2) Testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B IEC 60601-1: EMC problems: Confused about 915MHz ISM band in Europe IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Particular standard IEC 60601-2-40 references obsolete EMC standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A IEC 60601-1-2 - EMC Retesting Rational - Minor Component Changes IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
