IEC 60601-1-2 EMC Testing Optional in US?
samuelson
I am currently working on getting a Class I medical device to market in the US and realize I must test to the UL - 60601-1 standard, but my question is whether or not the device is needed to test to UL 60601-1-2 for EMC testing?
The device is classified as a Therapeutic Massager under product code ISA
Strictly speaking you do not have to test to 60601-1-2.
However,
that standard is the recognised standard (by FDA) for medical device EMC so it could be good engineering to go ahead and test anyway.
You have to have some confidence that your device will not unduly interfere with other equipment (blank out the TV every time it's switched on) or be affected unduly by other devices / ESD / surges on the power line etc (reliability issues).
There may be ways of simplifying the tests - for instance, if you can show it is a "simple" device with nothing operating above 9kHz, then you can drastically reduce the Emissions tests (using the base CISPR 14-1 standard instead of CISPR 11-1). Similarly, if you are battery powered then many of the Immunity test become Not Applicable.
As your device is 510(k) exempt the involvement of the FDA could be limited to just Establishment Registration. But it may be useful to understand FDA thinking both on EMC and their rather old guidance upon submitting a 510(k) for products like yours.
http://www.fda.gov/Radiation-Emitti...ElectromagneticCompatibilityEMC/ucm116550.htm
http://www.fda.gov/MedicalDevices/DeviceRegulationandGuidance/GuidanceDocuments/ucm080337.htm
cdewitt
If your device has anything that switches at 9KHz or above it needs to be certified that its emissions are below FCC limits to be sold in the US whether they need to meet 60601-1-2 or not. For emissions they amount to the same thing, just the immunity is missing but if you plan to sell in the EU you'll need to meet emissions and immunity.
tomshoup
Strictly speaking, if you claim compliance to 60601 that includes all the applicable collateral standards (see clause 1.3 in 60601-1), so you should have objective evidence that you also meet the requirements of the 60601-1-2 collateral EMC standard.
As others have said, if you have a digital device operating above 9kHz, then you have to also comply with FCC regulations in the US. However, digital devices used as medical equipment are exempted from most FCC regulations [47 CFR 15.103 (c) & (d)] but you have to comply with the "etiquette" provision in 47 CFR 15.5 which states that your device can't cause harmful interference with other devices and that your device must accept interference from other devices. The best way to know that your device complies with this etiquette provision is to test to 60601-1-2.
thisby_
Hello Tom,
I would like to ask you if, having tested your device for the IEC 60601-1-2 is this enough to say it also complies with FCC?
Here is my problem, we have tested our medical device to comply with IEC60601-1-2 but while I was reading the Guidance Document from the FDA for Radio Frequeny Wireless From August 2013 I got confused and I am not sure if we are suppose to do any other tests or the IEC60601-1-2 is enough to demostrate also compliance with FCC part 15.
Thank you!
Emilia
tomshoup
No, testing to 60601-1-2 EMC is not sufficient to claim compliance with FCC regulations. The best way to claim compliance to the FCC regulations is to have your test lab prepare a report based on doing the tests. If you don't have a radio in your device that intentionally transmits (e.g. no WiFi, no Bluetooth), you could probably avoid the cost of another test and use the 60601-1-2 data to compile your own report that demonstrates that your device meets the requirements of what the FCC calls an unintentional radiator, i.e. it emits EM signals because of high-speed digital signals but is otherwise not intended to radiate EM signals.
thisby_
Hello again Tom,
I received the report from the test lab and we did both IEC60601-1-2 tests and also CISPR 11 tests. Is this enough to show compliance with the FCC?
Note that our device is an host device for an already FCC certified WiFi module.
I am not sure what the path to follow to an authorization procedure to what concerns the FCC (not sure if Verification is enough or a DoC is needed). Do you have any idea?
What would be the labeling requirements for the Verification case?
I would really appreciate if you could give me some inlights!
Thank you,
Emilia
tomshoup
Since your device contains a radio, an intentional radiator in FCC language, your best course would be to go back to your test lab and ask them to prepare a report showing compliance to the FCC regulations. I think it is likely that your test lab only has some of the data they need to show FCC compliance and are likely missing immunity data (CISPR 11 is emission only). But your test lab wants your business and should be willing to give you a quote for preparing a report to show compliance to the applicable FCC regulations. If you knew you had all the data, you could create a matrix that showed the line items in the reports you have traced to the FCC regulations, but you'd have to be proficient in knowing which FCC regulations apply and that the data were acquired in the appropriate way.
akp060
I have a similar issue to this. I have read this multiple times and correlated it with my own search.
1. As per the measurement standards in 47 CFR 15.31, an intentional radiator would have to test to ANSI C63.10-2013.
Electronic Code of Federal Regulations (eCFR)
2. FDA Guidance mentions this standard but is not a recognized consensus standard. In fact, if you search for C63.10 it shows C63.15 (which complements C63.10 as per the former's scope)
3. I have seen that recently FDA cleared devices have mentioned the FCC compliance statement of preapproved modules (tested by the telecommunications bureau) and not test their finished devices to ANSI standards.
My questions with respect to the discussions on this thread are:
1. If tested to IEC 60601-1-2 will ANSI C63.10 or ANSI C63.15 compliance be required given that FCC checks compliance as per 47 CFR 15.31? If yes, what tests are not covered in the former standard?
2. If you have a preapproved module whether there is anything specific in the module's certification that should be mentioned in order to meet FCC compliance without testing for ANSI C63.10
M IEC 60601-1-2 EMC Tables IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
J IEC 60601-2-2 - EMC Requirements - Surgical instrument manufacturer IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
O EMC testing per IEC 60601-1-2 for considering new cables CE Marking (Conformité Européene) / CB Scheme 1
O EMC testing under RED and IEC 60601-1-2 CE Marking (Conformité Européene) / CB Scheme 1
C EMC Test Report Requirements to IEC 60601-1-2:2009 ISO 13485:2016 - Medical Device Quality Management Systems 4
P New EMC standard IEC 60601-1-2:2014 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
T IEC 60601-1-2 EMC and WiFi IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
T How to fulfill IEC 60601-1-2 EMC Testing Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C An ongoing EMC test in accordance with IEC/EN 60601-2-47 EMC IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
J EMC (Electromagnetic Compatibility) Requirements - IEC 60601 3rd edition Clause 17 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S EMI/EMC Failure Cause Analysis per IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Do HF accessories require EMC testing according to IEC 60601-1-2? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
S Does a 12V DC device need EMC (IEC 60601-1-2) Testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B IEC 60601-1: EMC problems: Confused about 915MHz ISM band in Europe IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Particular standard IEC 60601-2-40 references obsolete EMC standard IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A IEC 60601-1-2 - EMC Retesting Rational - Minor Component Changes IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
