IEC 60601-1-2 ESD: Lower Compliance Level for ESD Immunity
N
nbarabino
Hi
According to IEC 60601-1-2 it can be specified a lower compliance level for ESD immunity if the appropriate environment for use is specified.
The question is, how to know which is the appropriate environment (i.e., relative humidity, surface material, etc.) for a certain compliance level, e.g. 4kV/4kV air/contact discharges instead of 8kV/6kV.
Thank you
Regards
Marcelo
Re: IEC 60601-1-2 ESD: Lower compliance level
You are doing things backward.
First you need to define the environment of use of your device. If it?s intended environment can be expected to have lower ESDproblems, then you define the levels based on the environment.
The rationale for that clause (6.2.2.1) states that 4kV would be satisfactory for both air and contact if the materials were wood, concrete or ceramic (tiles). But most clinical areas typically use vinyl flooring for it's ease of cleaning. So that then requires the 8/6KV levels.
If you look at clause 6.2.1.1 - Immunity Test Levels - it only allows lower levels when "justified by significant physical, technological or physiological limitations". I would not expect that justification to be possible unless it was part of a "particular" standard. (60601-2-xx). For instance, 60601-2-26 (EEG) allows equipment to show a "temporary degradation" for up to 10 seconds. But does not allow a lower test level.
To claim that the expected environment is not prone to ESD build up would have to mean that the equipment would only ever be used in a very restricted environment. The obvious one would be a device for use during surgery. But then the device is more likely to be critical (failure would represent a significant hazard). Which would suggest the need for robust equipment.
So, unless you can prove that your device is only for use during hydrotherapy sessions [ ;-) ] I think you are stuck with the 8/6kV levels.
N
nbarabino
Thank you Marcelo and Pads38.
The intended environment of use is the patient's home environment. Also the device is not critical, and a failure due to ESD will not represent a hazard. Do you think it is possible to claim compliance with 4kV/4kV under this conditions?
Regards
The intended environment of use is the patient's home environment. .................. Do you think it is possible to claim compliance with 4kV/4kV under this conditions?
Regards
In my opinion - no. Sorry.
A home environment is less well controlled than a clinical environment so could be expected to be more challenging. Also note that in 60601-1-11 (requirements for equipment for a home healthcare environment) the possibility of excluding certian connectors from discharge (by labeling) is removed. Discharge is to any point where the test finger can reach.
Remember also that equipment that relies on an earth connection is not suitable for home environments.
If you really cannot meet the requirements then you might have to argue that the device does not provide "essential performance" (see 6.2.1.10). But notified bodies, or other regulators, do not like seeing that so you would need rock-solid justification.
N
nbarabino
Ok, thank you.
Earth connection is not a problem as the device is internally powered.
Regarding the ESD protection, anyone here has experience with ESD shielding techniques?
I Device Can't Pass IEC 60601-2 ESD Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
DitchDigger IEC 60601-1 subclause 5.1 - Adequate evaluation in lieu of testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Transformer Requirements - IEC 60601-1 vs. IEC 61558-2-15 IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T Clearance and Creepage according to Subclause 8.9.1 for MOPP IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
