IEC 60601-1-8 - When does an error message become an alarm signal?
N
NASAN Medical
#11
dear Shimon,
it will surly help me out..........
i guess if in-house test reports is acceptable to Notified Body then no issues.
but if you do testing in-house testing facility then how would you eliminate sound around your test equipment?
do we actually measure in dB level or just waveform is sufficient? plus, how would you validate it with out TRF?
hope you get my point..
thank you.
shimonv
#12
dear Shimon,
thank you.
I advise you to do an external test. It will probably be quicker and cost effective in comparison to you investing the time to write a protocol and test report. After the first external test you might be in a better position to do it in-house.
Shimon
N
NASAN Medical
#13
dear Shimon,
thanks alot. that's true, its time consuming and hard to follow protocol and TRF requirements.
i will discuss your view with my team-mates.
thanx again......
thanx elsmar forum.....
Peter Selvey
#14
Just an interesting side note to the original discussion - when the standard was first published, there was no actual definition of an "alarm". Instead the key terms "alarm condition", "alarm signal" and "alarm system" just referred to each other (circular references) without ever establishing exactly what an "alarm" is.
The latest edition/amendment still has not fixed this and the circular references remain. Clause 4 provides a de-facto definition which indicates an alarm is something that notifies the operator as a risk control. Structurally that is wrong, you should be able to determine if a standard is applicable purely from the scope and definitions. The history and wrong structure might be part of the reason the standard gets overlooked.
In the case of notifications, error messages, they could be a risk control but the requirements in the standard are fairly light, for example being legible from the position of the operator. In my opinion, they could be easily incorporated in IEC 60601-1, leaving IEC 60601-1-8 free to focus on "real" alarms that need reasonable prompt attention. Otherwise, you end up spending time and effort making a big IEC 60601-1-8 report that is 98% not applicable.
:2cents:
#15
So, how do we reconcile with the terminology of warning indications and alarm indications as per 60601-1 3.2 ed. Both are used for risk mitigation, but are called out as differently.
Also, for technical alarms such as power fail, 60601-1-8 provides exemption for not meeting audio characteristic. Does this mean that we need to visual/ flashing requirements even in this case? Let me know your thoughts
MDD_QNA IEC 60601-1 Ed2 vs Ed3 - Does a product that conforms to Ed3 also fulfill Ed2? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S IEC 60601-2-27: What does "linear within ±20% of the full scale output" mean? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E What does "other APPLIED PARTS" mean in IEC 60601-1 ed 3.0 8.7.4.7 b) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Does long-term body worn medical monitoring device need to meet IEC 60601-1-11? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S IEC 60601-1 3rd Gap analysis template TO BUY - Does anyone know where? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Will buyers (hospitals) require IEC 60601, even when FDA does not? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Does the Banana connector deviate from the IEC 60601-2-25? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C Does IEC 60601-2-49 apply to Thoracic Bioimpedance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S Does a 12V DC device need EMC (IEC 60601-1-2) Testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A Does Canade recognize IEC 60601-2-22? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
