IEC 60601-1 and 60601-1-2 - Not Applicable for My Medical Device
rcjpedro
#21
Thanks Marcelo for your time and expertise
The auditor first approach to our TF off site review was to state that it was not a medical device and to stop the audit right there. Because the intended use did not fit the Directive definition. Fortunately I remembered that a CAPA was opened on the first submission of the TF, regarding device classification, to the notified body that mentioned a Consensus Statement that it was indeed a medical device, from here the 28 pages CAPA ensued.
Thanks for this:
If electrical safety requirements would be expected, that standard would have mentioned and required compliance with IEC 60601. It does not.
I will use it. Can you provide any example where a product standard clearly mentions 60601 compliance?
In order to strengthen the argument
Marcelo
#22
One example would be the ISO 14708 series on active implantable medical devices, the particular standards on that series do call for IEC 60601 regarding electrical safety.
However, I think you are approaching this the wrong way. What I mentioned above is just my experience from using standards.
The correct way to show that IEC 60601 is not applicable is to go back to what I said about the definition of medical electrical equipment and the scope of IEC 60601. This is the only way to correctly justify not applying the standard, showing that the the equipment is out of the scope.
rcjpedro
#23
Hi Marcelo and thank you for your time.
How could I reply to MDD 93/42
ER9.2
ER12.5
ER12.6?
Reparei que és brasileiro,
Abraço cá de Portugal!
Marcelo
#24
ER9.2
ER12.5
ER12.6?
This is a different discussion. Your original question was related to how to justify not applying IEC 60601. That's why I focused on the scope of the standard.
Complying with the essential requirements can be done using any option that is deemed acceptable. Using a harmonized standard is only one (but it does give presumption of conformity). You can also use any standard, or even your own standards.
For example, you "could" use the requirement of IEC 60601 to fulfill the ERs mentioned. However, I'm not sure they would be the better solution, as the device is not a medical electrical equipment. A better solution may be using IEC 61010 instead.
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
DitchDigger IEC 60601-1 subclause 5.1 - Adequate evaluation in lieu of testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Transformer Requirements - IEC 60601-1 vs. IEC 61558-2-15 IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T Clearance and Creepage according to Subclause 8.9.1 for MOPP IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
A IEC 60601-1 and IEC 60601-2-2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
