IEC 60601-1 clause 8.8.3 - Dielectric Strength
Hi all,
The standard says:
Compliance is checked by applying the test voltage specified in Table 6 for 1 min:
Initially, not more than half the test voltage is applied, and then it is gradually raised over a period of 10 s to the full value, which is maintained for 1 min, after which it is gradually lowered over a period of 10 s to less than half the full value
Table 6 - Test voltages for solid insulation forming a PROTECTIVE MEANS
In a production line, all equipment must undergo this routine test, correct?
My doubt, would I have to strictly follow the 10s ramp-up of the voltage, then 1min in the voltage value according to table 6, and after 10s of the ramp-down of the voltage?
Or a reduction in these times can be made because we know that solid insulation can be destroyed, right?
Are there any acceptable manipulations that can shorten routine testing time without affecting the requirement of the standard?
Thanks,
Mike S.
Happy to be Alive
I can't answer your question, looks like no one else here can, either.
Often a standard will contain contact information, I would contact the creator of the standard and ask your question. I have done this before with several standards and it can be very helpful.
Benjamin Weber
There is no strict requirement for dielectric strength test in production lines, since 60601-1 is for type testing of the design/construction. IEC 62353 describes recurrent tests after repair. But there is no dielectric strength test. It's leakage currents, PE impedance, visual inspection and functional testing. Additionally there is inof on production line testing in IEC TR 62354, Annex K. Here a dielectric strength test is described, yet it only an informative annex, not normative.
Peter Selvey
Agree with Benjamin, there should be no fixed requirement to test dielectric strength in production. Dielectric strength is actually an ageing test for solid insulation, and really intended to be applied to individual parts, not assembled devices.
The aging aspect is theoretically applicable, and could be used as an argument to avoid production testing since the test could damage or shorten the life of the insulation. However, virtually all modern insulation can hande far longer times than in the standard, so practically it's not an issue.
Rather, the bigger problem is that in an assembled device, there is a huge potential for voltage to be distributed in a way that damages parts not intended to act as safety insulating barriers. Also it's common that the parts providing safety insulation are not actually stressed in tests performed from outside an assembled device.
With that in mind, a high voltage test can still be a useful production test to check for assembly errors. In this case, the 60s time is not relevant, it just needs to be enough to be sure the voltage is reached reliably e.g. 5s. Even the voltage does not need to match the standard. Such a test should be carefully planned with designers involved to make sure it does not damage parts. Mains to earth is usually OK, but mains to secondary, patient circuits, accessible parts usually cannot be done, or should be done in sub-assemblies only (if not already done by the part supplier).
If you have an NRTL report for Canada and the USA then dielectric strength testing is often a routine production test. The duration of the test aligns with the standard and it is a super quick and easy test to set up in a production line.
B IEC 60601-1 Clause 14.8 - Architecture IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Fire hazard classification - Clause in IEC 60601 about gauze and electricity ISO 14971 - Medical Device Risk Management 0
S ME system clause 16 of IEC 60601-1, 3.1 ed IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T What is PESS? Cited in Edition 3.1 of IEC 60601, clause 14.1 note 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E ME (Medical Equipment) Systems - IEC 60601-1 Clause 16.1 Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R Question on IEC 60601 clause 15.5.1.1 (transformer overheating) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L IEC 60601-1 3rd edition Clause 9.2.2 Trapping Zone (Acceptable Gaps) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
E IEC 60601-1 Clause 14 Questions IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R How to understand the exception of IEC 60601 sub-clause 8.11.5 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M MEEE Expected Service Life - IEC 60601-1 Clause 4.4 Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R How to calculate the Air Flow Rate in clause 201.12.4.4.105 of IEC 60601-2-16:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P IEC 60601-1 Clause 11.1.3 Winding Temperature Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J EMC (Electromagnetic Compatibility) Requirements - IEC 60601 3rd edition Clause 17 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
I Dielectric Test for HF Surgical Equipment (IEC 60601-2-2 clause 201.8.5.1.2) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M IEC 60601 Clause 7.1.3 - Durability of Markings - Methylated Spirits IEC 60601 - Medical Electrical Equipment Safety Standards Series 19
P Understanding IEC 60601-1:2005, Clause 8.1 b) - Short Circuiting Double Insulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
P IEC 60601 Clause 57.3 / 8.11.3.2 - PVC Flexible Cords IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
G Single Fault Condition for 3-Phase Medical System - IEC 60601 Clause 8.1b IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B IEC 60601-1 2nd Clause 17 and 3rd edition - Electrical Isolation IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
shimonv IEC 60601-1-2:2014+A1:2020 (Ed. 4.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
G IEC 60601 Compliance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-2-57 light source classification IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
L Top opening of enclsoure against fire in IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C EN 45502 vs IEC 60601-1-8 Other Medical Device Related Standards 0
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
