IEC 60601-2-24 Ed 2.0 (Infusion Pumps Particular Std.) - Redlines
meddevsd
Hi Everyone,
Does anybody know if a redlined document is avaialbe for the changes to the recently released edition of 60601-2-24 (Edition 2.0). I have heard comments as a number of critical details were left in error. Some of these seem to be omissions from the prior release as if they have dropped sentences. Some are serious such as omitting critical test values that appeared in all prior releases and without which tests can’t be performed, e.g. the sample period (critical) for weight measurements used in flow accuracy is not specified (was in former editions). Any feedback is greatly appreciated.
Peter Selvey
In cases of obvious editorial mistakes, they will usually issue a "corrigendum" pretty soon after the publication, which should be available for free and in place well before the end of any transition period.
meddevsd
Thank you for your reply. Any future updates would be appreciated. Also, do you know who to contact at IEC to follow up on these errors?
Regards.
M Infusion Pump Power Failure Alarm IEC 60601-2-24 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Why was Drip-Rate Infusion Pump removed from IEC 60601-2-24:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T Infusion Pump and IEC 60601 2nd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
T IEC 60601-2-24 for the Safety of Infusion Pumps IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M What is the Release Date for IEC 60601-2-24 for Infusion Pumps? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
