IEC 60601-2-27 - Comparison of 2nd to 3rd edition
thelastdon99
Does anyone out there have a comparison of The "Particular requirements for the basic safety and essential performance of electrocardiographic monitoring equipment" IEC-60601-2-27 2nd edition (2005) to the 3rd edition (2011)? I am working on a gap analysis and dont want to re-invent the wheel.
I wish when you purchased the newest standards the developers would clearly identify what was new and how the new clauses aligned with the old. Instead they change the numbering conventions and make it very criptic.
Any help or information would be greatly appreciated!
Thanks!
-2-27:2011 has introduced a definition of lead as:
LEAD
voltage between ELECTRODES
and this definition has been copied into the current draft of -2-26 (EEG).
Now, as an engineering type I think of a lead as being a bit of wire and not a signal but perhaps it makes sense in the ECG standard.
We were trying to find the rationale for that definition. It was introduced into -2-27 fairly late in it's development but we have not been able to find any record of the committee discussions that would have taken place to introduce the term.
Can anyone provide an explanation?
raymond02302
This difiniton derived from IEC 60601-2-51. Lead actually means the signal.This is why 12 lead ecg is so called but with 10 electrodes patient cablelead. You can read IEC 60601-2-51 for further information (including how to calculate the value of each lead with result of lead wires )
"Cable" you said is technically difinded as patient cable.
Thank you both, and I'd already found (and bookmarked) your informative pages Peter.
I can see that the definition makes some sense for ECG, but for EEG I think it is, at best, not very clear and otherwise is a contortion of the natural use of language that does not assist in the use of the standard.
P
Paamand
Re: 60601-2-27 comparison of 2nd to 3rd edition
Great site Peter! -> Bookmarked
I'm very much interested in the IEC 60601-2-25:2011 comparison. Any way to subscribe to that? :)
P IEC 60601-2-25:2011 Comparison Table (ECG, Diagnostic) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
L Top opening of enclsoure against fire in IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C EN 45502 vs IEC 60601-1-8 Other Medical Device Related Standards 0
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
DitchDigger IEC 60601-1 subclause 5.1 - Adequate evaluation in lieu of testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
