Can anyone help me clarify the following?
We are developing a medical electrical, portable, handheld, probe device which is invasive in a natural bodily orifice of patients.
The probe is powered by a rechargeable battery and is IP54 rated.
The probe is intended to be disinfected after each use.
The probe is only intended for normal use in conjunction with a thin, single-use, non-conductive, biocompatible sheath (a separate medical device).
The "insertable portion" of the unsheathed probe is clad in silicone rubber, insulating any electrical components.
In normal use, the probe is always covered with the sheath and is never intended for direct contact with patient tissue.
The probability of occurrence of sheath rupture during use is very low.
BS EN 60601-1:2006+A12:2014, sub-clause 3.8 defines APPLIED PART as:
Would I be correct in stating in the device technical documentation that the probe device does not have an applied part, and as such, requirements for applied parts do not apply?
If I'm not correct, what would the rationale be?
Thanks in advance.
"part of ME EQUIPMENT that in NORMAL USE necessarily comes into physical contact with the PATIENT for ME EQUIPMENT or an ME SYSTEM to perform its function".
Thanks in advance.
