IEC 60601 Medical Device Testing House Costs
Jeffers
Hello Elsmar,
As regulatory manager for a very small medical device manufacturer, I am often in a position where I need to educate myself on standards. We are a CE certified company, and are planning to release a new medical device into the market. The device is battery powered, and is our first "electrically powered" medical device. The device is extremely simple, no complex wiring, no complex circuitry. We have generally completed the R&D stages for the product, and are preparing a 510K submission to the FDA.
I believe our device will need to comply with the following standards:
IEC 60601-1
IEC 60601-1-2
IEC 80601-2-60:2012
I have received quotes from a few different testing houses to perform the required tests and provide a report with the results. It was recommended to me to allow one testing house to perform 60601-1 and another testing house to perform 60601-1-2.
When a company has this testing performed, does a single test house typically perform all of the testing, or is this a frequent relationship, with each testing house specializing in a certain group of tests?
If any other information is required, please let me know. If anyone has a recommendation for a testing house, that is also appreciated.
Marcelo
Re: IEC 60601 Testing House Costs
It depends.
It's very common for test house to test to the general standard, some collaterals (but not EMC), and some particulars.
It's also common to separate some testing (although this may create a problem because the standards should be used together). This is common for 60601-1-2 because EMC testing is usually performed at a high specialized testing laboratory (the same can be said about X-ray devices).
Marcelo
Anyway, I think it's better to test in a single test house, if possible. Besides applying the standards together as they should be, testing together might lower the price (at least, that's what happens in Brazil).
Jeffers
Marcelo,
Thank you for the prompt update. I suspect this question is not fair, but would you have any idea on a very rough price range for this type of testing? I understand how difficult that is without having an idea of the device. It is so extremely simple, the BOM has three items.
Would you expect the testing to be less than $5,000.00USD?
Between $5,000 - 10,000USD?
$10,000 - 20,000USD?
Over $20,000USD?
Marcelo
The fact that the device is simple usually does not make much difference in the price, unless the test house do give discounts for tests not applied (not usual in my experience).
I have no idea of the prices of testing abroad right now, but from past experience it will probably cost between 10,000 - 20,000USD for a device which applies 60601-1, 60601-1-2, some other collateral and no particular.
Although I've seen comments that prices have hiked due to the third edition, in this case you would easily pay more than 20,000USD.
Jeffers
The fact that the device is simple usually does not make much difference in the price, unless the test house do give discounts for tests not applied (not a usually thing in my experience).
Exactly what I was looking for, but not necessarily what I wanted to hear!
Thank you for the assistance, Marcelo, and for taking the time to share your knowledge and time with your thorough response.
Something that may make a difference on both cost and the use of different test houses for the base standard and the EMC standard is your use of certification marks.
When you want to be able to display a mark (such as UL, ETL) the certifying test house has to certify to all applicable collateral standards, as well as the base 60601-1. So they might not accept the test results from a third party EMC test house.
Also, certifying test hoses tend to be bigger and more expensive and, for the use of a mark, they will require production inspections.
I suspect that you will also need to add 60601-1-6 / 62366 to your list of applicable standards.
SteveK
Had some quotes from a few UK test houses about a year back; for exactly this work for a low voltage device (conducting both 60601-1 & 60601-1-2), and Marcelo’s price range for the work is unfortunately about right (converting from Pounds – circa $12,000 to $24,000 in our case). The cost has probably risen since then! One test house did quote twice as much as another. Not actually had any testing conducted as yet – long term project!
Steve
I had a look back at some quotes received over the last couple of years. As Steve suggests there is a wide variation, with little to explain the differences.
First quote - CB test house, device classification IIa, mains powered, including PEMS, plus usability and a particular standard (60601-2-xx).
Excluding EMC, biocompatability, and packaging tests
£23,000
Second - ISO 17025 test house, IIa, mains powered, PEMS N/A, excluding particulars, EMC and any extras.
5,000 euro.
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Scope of application for IEC 60601-1-11 Medical electrical equipment — Part 1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
rezayatmand IEC 60601-2-18 Medical electrical equipment - Part 2-18: Particular requirements for the basic safety and essential performance of endoscopic equipmen IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D IEC 60601 for a Software only Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
G Electrical Safety standard for medical device not covered by IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B The most important criteria of IEC 60601-1 medical devices safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
JoCam Medical Device that is class II electrical and IEC 60601-1-11 EU Medical Device Regulations 5
M Ground stud requirements on our medical device in IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E ME (Medical Equipment) Systems - IEC 60601-1 Clause 16.1 Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
R IEC 60601-1 and 60601-1-2 - Not Applicable for My Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 23
R IEC 60601-2-18 Endoscopic Medical Electronic Equipment question IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S IEC 60601-1 - Label Physical Requirements for Disposable (Single Use) Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Q IEC 60601 for Non-Medical Research Purpose Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S IEC 60601-1 - Device Energized by other Device - Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
thisby_ Changes in an already certified IEC 60601 Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Does long-term body worn medical monitoring device need to meet IEC 60601-1-11? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
N IEC 60601-1 , 3rd edition and the FDA - Special 510k to my updated Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 40
P IEC 60601-1-11 - Medical Electrical Equipment IP (Ingress Protection) Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
Z IEC 60601-1-2 for very simple Medical Device Accessory IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
I IEC 60601-1 Least Favourable Working Conditions for Medical Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Requirements to Ship Medical Devices to the EU - IEC 60601-1 3rd. Ed. IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
I IEC 60601-2-52 - HD22.10 H05-BQ-F type Power Cable for Medical Beds IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G 510K for Active Medical Device - IEC 60601-1 or UL 60601-1 Compliance Other US Medical Device Regulations 3
R Class II Medical Device Marking - Different IEC 60950 & IEC 60601 Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 17
P Is IEC 60601-1 applicable to software-only medical devices? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
C IEC 60601 vs. CE Mark HMIs - Which should be used for a Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
J Marking (Labeling) Requirements on Medical Equipment per IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S IEC 61010-1 and IEC 60601 - Borderline Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
S IFU for combined OTC Medical Device in light of IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Single Fault Condition for 3-Phase Medical System - IEC 60601 Clause 8.1b IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Medical Device IDE - IEC 60601-1 Certification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Brazilian Requirements for Medical Device Production Testing to IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Medical Equipment (AC Adapter) Classification as per IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E IEC/EN 60601 Testing and CE Marking for a Non Medical Device CE Marking (Conformité Européene) / CB Scheme 11
N CB Scheme and Conformity of Medical Equipment to IEC/EN 60601 EU Medical Device Regulations 2
M IEC 60601 - List of required tests - Medical Device Class IB IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
M IEC 60601 vs. IEC 61010 - CE Mark for our IVD medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
M IEC 60601 Medical electrical equipment - Send declaration and guidance to customers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
L When IEC 60601-1 2nd edition can not be used for CE mark medical device application? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Leakage current from battery - IEC 60601-1 Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
P Version of Medical device safety standard - IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
F Medical Electrical Equipment / System Peripherals - IEC 60601-1-3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
D Training for IEC 60601-1-8:2006 Alarm Systems in Medical equipment. IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Usability standard IEC 60601-1-6 in the Medical Device Industry IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D IEC 60601-1:2005 - Medical device standardization - Seeking information IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
A IEC 60601-1 for low voltage medical devices? DC power less than 10V IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S IEC 60601-1-11 Requirements related to Storage and Distribution IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
