IEC 60601 subclause 8.9.1.12 - Earthed secondary circuits
eldercosta
Dear all,
I have a question regarding the interpretation of table 15, referred to on subclause 8.9.1.12, namely “Where the SECONDARY CIRCUIT is earthed or the ME EQUIPMENT is INTERNALLY POWERED, Table 15 applies”, which is the case of my device. Table 15 (Minimum air clearances for MOOP in secondary circuits) has clearances but what these clearances are from, considering enclosure (or the metal parts of it) are earthed?
eldercosta
Hello, Marcelo, thank you for chiming in.
So, in this case (i.e. earthed secondary circuit), it is redundant with MOOP between mains and secondary circuits and MOPP between applied parts and secondary circuits. Is it right?
Marcelo
No, in the case of MOOP you still have to have one mean of protection (basic insulation) from mains (and guarantee that this basic insulation is maintained thru the device expected service life as per 4.7 b), otherwise you would have mains on the secondary circuit in normal condition, and in this case you would introduce the failure of the earth, with the leakage current limits being exceeded).
In the case of MOPP, if the applied part is type F, it has to be separated particularly from earth (but also from all other parts) as per 8.5.2.1 by one MOPP, and even if it's a type B, if it has patient connections not protectively earthed, it has to comply with 8.5.2.2.
eldercosta
Hello, Marcelo.
I think we are talking of the same thing but my previous message was not clear whatsoever (BTW there is a 2xMOPP isolation between secondary and AP in my design). What I was thinking of and did not express in an appropriate way was that there might be some cases where isolation requiments superimpose or intersect on the isolation diagram and the most stringent (whether MOOP or MOPP) applies.
Anyway your first response helped to clarify the subject to me. Also I made a small mental simulation where the secondary circuit has a high voltage source instead of the low voltage of my design and it made clearer why and how some isolation requirements would apply even if the secondary was earthed. The standard tries to be as comprehensive as possible (cover every possible scenario) and sometimes a some requirements may not be clear for a particular use case.
Thank you very much for your help.
Marcelo
Hello, Marcelo.
Ah, ok, sorry for that.
Anyway, maybe the thing is to understand that the insulation coordination is more like a puzzle that you have to create for each device. For example, you mentioned that you have 2 MOPP between earthed secondary and AP, but you in principle need only 1 (as long as your secondary has the 1 MOP between mains and 4.7 is fulfilled), so these options are you to make, and you create the insulation system based on your needs (the main problem with having more insulation than needed is that it costs more without any gain to safety). Surely, and particular in the case of MOOP and MOPP, there are superimposed requirements (because an insulation can function as both), but it's not that hey superimpose by default, it's your design that dictates that.
eldercosta
Puzzle perfecly describes it. :)
you mentioned that have 2 MOPP between earthed secondary and AP, but you in principle need only 1 (as long as your secondary has the 1 MOP between mains and 4.7 is fulfilled)
That is one of the points I found very confusing in the standard. 8.5.2.1 states 1MOPP but the figures in Annex J state otherwise e.g. J5 and J6. It is not clear to me why.
Still about Annex J, J4 requires 1MOPP for signal I/O for maximum mains voltage but 2MOPP for working voltage. That seems odd to me, especially if the working voltage of secondary or AP is a few volts (case of my designs). What am I missing?
In my design, using 2MOPP between secondary and AP is fairly trivial as there are components that meet the requirements at an affordable cost. Also, in the dielectric strength test between mains and AP, most of the voltage goes over the AP isolation as its parasitic capacitance tends to be much smaller than the one of the AC/DC converter.
eldercosta
OK, I think I figured it out. If the working voltage is low, say less than 43V, then 2 MOPP creepage/clearance are similar (but not equal) to 1 MOPP for maximum mains voltage. If working voltage is higher, things may change and distances increase accordingly. Does that make sense?
DitchDigger IEC 60601-1 subclause 5.1 - Adequate evaluation in lieu of testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T Clearance and Creepage according to Subclause 8.9.1 for MOPP IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R IEC 60601-2-57 - Subclause 201.7.101.2 - Explanatory Label - LS Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
kevinkre IEC EN 60601-2-25 subclause 201.12.4.106.2 Channel Crosstalk (ECG Multichannel Crosstalk) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A What kind of test is described in subclause 56.3(c) of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M IEC 60601-1: 2012 - Subclause 11.3 - Constructional Requirements for Fire Enclosures IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC EN 60601-2-27 subclause 50.102.5 ECG Multichannel Crosstalk IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
JoCam Failure to test Class I medical device to IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Dielectric strength test as per IEC 60601-1 -Infant incubator IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
