IEC 62133 Test Report for Lithium Battery Certification
  • Thread starter karthika subramaniam
  • Start date
K
One of our product is under IEC 60601-1 testing, in which we are using android device (Mobile).
We have developed android app which is installed on android device for controlling medical devices motions.
We have provided the Android device certification for IEC 60950-1 for IT equipment.
Regulatory Board, Test Lab is asking for IEC 62133 test report for Lithium battery and also USB charging cable certification that comes along with android device.
We have completed EMC/I testing. If we change MSO, there will be impact on EMC/I testing as well.
Please help
Mark Meer
What is "MSO"?
I presume that you've asked the supplier of your android device what kinds of documentation they can provide?
The USB cable will likely have a UL-listing (nothing to do with IEC 62133).
As for the battery, it might be a problem, as older consumer batteries may not have been tested IEC 62133 (instead, more likely something like UL1642).
If they DON'T have IEC 62133 testing done, there's a few options I can think of:
1. Negotiate with them (e.g. pay them) to get their batteries tested.
2. Find a battery supplier that can provide a battery with the same specification that you can have tested yourself. This is onerous, but has the advantage that you are in control of the battery.
3. Justify in your risk management documentation that whatever battery standards your current supplier uses is sufficient to ensure risk is acceptable. You can then justify not meeting that requirement of IEC 60601-1. In this case you wouldn't be claiming full compliance to the standard, but the tests can still be used as evidence for safety.
Best of luck!
MM
K
Hi Mark
MSO - Multiple Socket Outlet
Regarding 3) How can we address in RMF, can you throw some light?
Thank you
I would suggest that the Android device is an accessory to the medical device and is NOT itself a medical device.
The 'app' should be considered a medical device so should satisfy the requirements of 60601-1 Clause 14 and 62304 (lifecycle).
There should be no requirement for the battery in the Android device.
M When is EN 62133-1 (new version i.e. IEC 62133:2017) mandatory in EU Other ISO and International Standards and European Regulations 3
M IEC 62133:2012 is now IEC 62133-1:2017 & IEC 62133-2:2017 Other ISO and International Standards and European Regulations 0
F IEC 62133 cell vs. Battery Pack - Certification on the cell only IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC 62133 - CB Scheme Required by FDA 510k Other Medical Device Related Standards 3
T IEC 62133 Certified Battery Manufacturers Other Medical Device Related Standards 3
R IEC 62133 to satisfy 60601-1 3rd edition - What happen to 60086-4 Other Medical Device Related Standards 18
W When will Kuwait require Lithium Ion Batteries be tested to IEC 62133 standard Other Medical Device Regulations World-Wide 1
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E IEC 62353 normalization IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M IEC 61010-1 requirements for motors Other Medical Device Related Standards 0
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
A IEC 62304 safety classification, External Controls and off-label use related risks IEC 62304 - Medical Device Software Life Cycle Processes 5
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
S IEC 62304 software costs and time Medical Device and FDA Regulations and Standards News 3
S IEC 62304 - Software verification cost IEC 62304 - Medical Device Software Life Cycle Processes 3
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
