I am led to believe that this would never be a Class C software. A misdiagnosis certainly could certainly lead to an extremely severe outcome for a patient, but unless the diagnostic device is somehow directly controlling therapy delivered to the patient (or otherwise being the sole arbiter of a therapy) I don't see how this level of harm is possible. Kudos to you if your device has become so critical to care! I suppose you can reach class C if somehow the temperature related hazard can severely harm an operator, but I doubt this is how class C is part of the conversation.
With that out of the way, I don't recommend trying to land on class A because you believe you might actually have a non-software risk control that can 'take over' if the software fails. Keep in mind that the FDA's Software Safety Classification also has 3 levels of concern (major, moderate, minor) roughly commensurate with the 62304 classification schemes, but the FDA explicitly does not allow for an a priori consideration of risk controls to reduce the classification of software. I think this is one case where the FDA got it right, and 62304 is overthinking this issue from the wrong direction. If I wanted to entertain the notion that 62304 is correct that external risk control measure can be implemented such that the classification is reduced (and specific 62304-development efforts are not value-added), I would have to see a complete analysis of the system (including development and testing) without software to demonstrate that any identified external risk controls are effective in the absence of software before I would believe that the software system really hasn't been allocated any necessary risk controls. This is not practical for a majority of ME device development, as software and hardware are generally developed in parallel.
The difference between a 62304 class A and class B software primarily come down to the nature of the development deliverables and the requisite amount of work that goes into those deliverables. If you start a project knowing you have class A, a project can save some effort by reducing the amount of necessary deliverables. The FDA will still require the deliverables for software with a classification of moderate which may not be on hand if the software was developed as class A. It has been my experience that (even setting aside the FDA requirements) more effort is required to rationalize the reduction of the entire software system from class B (assuming no risk controls external to software) to class A than can be saved by just treating it as class B.
Now specific to the system you describe, with my assumption that prior to decompositon (of software safety elements) that the software system is class B (classification = moderate). If the thermistor cut-out circuit is a back-up for the software-controlled oven control, then the software is clearly controlling the temperature and it should be treated as class B. The development team is certainly has specific requirements for the software and is doing development work, testing the code and is open to the idea of modifying the code for optimization and bug fixes. For class B, the risk lines that discuss this feature of the software are going to reference the requirements, elements of the software architecture and the assorted testing specific to this feature. These risk lines will also include an additional link to the hardware element providing an additional backup.
If you believe the software is class A (and somehow rationalize it as a minor classification per FDA) your risk lines should identify the thermistor as having the primary responsibility for the temperature profiles and also as being the primary risk control. Don't waste any development effort on the software (for this function) as whatever the team throws together won't need to really work as the thermistor is doing everything. If you actually believe this (class A) the project shouldn't be wasting resources on the software development.
One final word of caution for these specific design choices. No matter which way you go (thermistor is primary, software is primary) you have described a system which potentially has two 'bosses' and can lead to arbitration conflicts. This circumstance ought to be explicitly called out in the risk files with an appropriate level of analysis to guarantee that any such risks are acceptable.
