IEC 62366 for Stand-Alone Medical Device Software and Usability Engineering
Marcelo
#11
testable requirements for
USABILITY of the PRIMARY OPERATING FUNCTIONS including criteria
for determining the adequacy of
RISK CONTROL achieved by the USABILITY ENGINEERING
PROCESS." in the usability specification. However in the annex H, those requirements are written without criterias. So I'm confused.
I told you that Annex H is not exhaustive. As mentioned in the notes, the testable requirements for primary operating functions can be usability goals, and examples can be foung in Table D.5, Table D.6, and Annex G. Not in Annex H.
Shouldn't criterias be included in the usability validation plan instead of the usability specification?
Test criteria to verify design (in this case, the user interface design) are related to verification. Validation is related to the evaluation if the implemented design fulfills user or intented use requirements. Validation can have it's own criterias.
Also note that the standard call verification activities "tests" and validation activities "methods" to clearly show the difference between them.
Marcelo
#12
You test your requirements from usability spec and SRS in your software test plan. Doing that way, you verify both your SRS requirements and usability requirements during tests phases.
Take care when using the term "usability requirements". You do not verify usability requirements (which are the requirements related to a specification or intended use) with verification tests. Verification test only evaluate design requirements, meaning, the requirements for the user interface design in this case (as noted in the standard - The USER INTERFACE is subject to VERIFICATION to the USABILITY SPECIFICATION. The USABILITY SPECIFICATION is subject to VALIDATION, where the USABILITY VALIDATION plan incorporates the acceptance criteria).
The usability validation plan is a document with a broader view. It contains references to your qms procedures and to documents of your project, to show that you pass all the requirements of the 62366 standard.
Sorry, but where did this information come from? The usability validation plan does not evaluate that you pass all requirements of the standard (note that meeting the standard in principle does not means that validation is achieved). Validation verifies the device usability validation, which is related to the intended use of the device.
It does not need references to the QMS nor to project documentation. The usability validation plan only needs what is required by 5.6. For more info on this, please see 4.7.3.
With this in mind, please note that you example validation plan on your attached file is wrong.
A basic template usability validation plan per IEC 62366 would need at least the following information:
1 - Method(s) used for validation of the primary operating functions (which includes, for example, if the methods are quantitative or qualitative, which types of conditions are used - actual or simulated, what is the method process used, who is gonna be tested, remembering that it must be representative of the intended user population)
2 - Risk acceptability criteria per ISO 14971 (validation criteria)
3 - Frequent and reasonably foreseeable user scenarios (form the usability specification
sparvhok
#13
Thanks for your extensive answers.
"The USER INTERFACE is subject to VERIFICATION to the USABILITY SPECIFICATION."
Does this mean that we should verify that the user interface lives up to the usability specification?
What way would be the best way to do this verification?
Best regards
Michael
Marcelo
#14
As the usability specification is intented to create verifiable requirements for the verification, yes.
Way to to this, as mentioned in the standard:
"USABILITY VERIFICATION can be done by inspection of the implemented USER INTERFACE or through a PROCESS of observing and collecting data from intended USERS while they interact with either the MEDICAL DEVICE or a (high fidelity) MEDICAL DEVICE prototype in the intended or simulated environment of use."
c.mitch
#15
Thank you Marcello for your informative answer.
The example I uploaded in the cove is what I did for several medical devices. And it passed the audits. But this is not a systematic proof that I do it right to implement the standard.
My "validation plan" (between brackets, I'll have to change the name) draws the links between the documents of the project and the sections of the standard, to ensure that the standard is fully implemented.
The usability validation is part of the series of tests of software when it is delivered for testing with end-users, what I call a end-user test report with end-user scenarios (the #3 of your basic template).
However, the #1 and #2 of your basic template raise a warning for me and I'll check that mine are ok.
Marcelo
#16
I´s good that you acknowledge that, because this situation is happening a lot. For example, auditors auditing IEC 62366 have no idea what it is and then accept anything that seems more or less ok. Problem is, a lot of times they are being told it´s wrong, and then when they get back to the manufacturer, they say that what was accepted in the previous audit is not accepted anymore. CBs and NBs should have people trained in what they audit, but this is really a deep and ongoing problem (and IEC 62366 and other process standards do not help, cause they do not make it clear how to evaluate the conformity).
As I said, verifying that the standard has been implemented is verification, not validation.
Those can be either verification or validation, depending on what is "tested". If you only tests design implementation, then it´s verification. If you test user requirements, it´s validation.
Note that the general difference between verification and validation is:
Verification - test what I said I would design
Validation - test if what I designed is what the users needed.
A lot of people think that what I design is what the user wanted - the problem here might be that I didn't ´t understand what the user wanted and designed something which did not fulfill their needs. That´s exactly what validation wants to verify.
#17
Hi Marcelo,
kindly help.
I am bit confused,between Usability Verification , Usability validation & Validation. i would like to state my understanding,
Usability Verification : Like software verification, prepare the test plan considering usability specification as input document and test according to the plan.
Usability validation : Nothing to do with the Usability specification, the input document is the user needs / user requirement (in our case it is called as marketing input, it is user requirement consolidated by our marketing department). as i understand usability validation is checking whether the final product meets its indended use/user needs/user requirement (final product : prototype after all software testing iteration & finalysed to release is taken for validation activities).but earlier also i was doing the "Validation" activity as same as i mentioned about usability validation.
hence usability validation & validation is one and the same.
kindly reply if my understanding is right ?
thank you,
adir88 Amendment 1 of IEC 62366-1 - Details yet? IEC 62366 - Medical Device Usability Engineering 2
K Primary Operating Functions (POF) in IEC 62366-1:2015. IEC 62366 - Medical Device Usability Engineering 7
V Applicability of IEC 62366-1 usability to resorbable bone substitutes IEC 62366 - Medical Device Usability Engineering 9
pashah Looking for Usability File Template acc. IEC 62366-1 and IEC 60601-1-6 IEC 62366 - Medical Device Usability Engineering 4
C Usability IEC 62366-1:2015 and MDR 2017/745 - Risk based approach IEC 62366 - Medical Device Usability Engineering 1
E Usability Process - Looking for a template (IEC 62366) IEC 62366 - Medical Device Usability Engineering 1
J IEC 62366 - Ethical approval IEC 62366 - Medical Device Usability Engineering 5
J IEC 62366 - Summative Evaluation IEC 62366 - Medical Device Usability Engineering 6
T I need to make test reports according IEC 62304 & IEC 62366 IEC 62366 - Medical Device Usability Engineering 2
C IEC 60601-1-6 2010 maps to IEC 62366:2007 - What about 62366-1:2015? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K Usability of ME Equipment - IEC-62366-1:2015 IEC 62366 - Medical Device Usability Engineering 3
T IEC 62366 Test Report Form IEC 62366 - Medical Device Usability Engineering 20
M IEC 62366-1:2015 Usability Verification / Validation Plan example wanted IEC 62366 - Medical Device Usability Engineering 20
T IEC 62366:2015 Annex C - changed parts from 5.1-5.8 --> but what about 5.9? IEC 62366 - Medical Device Usability Engineering 3
S IEC 62366 - Usability Test Protocol format Imported Legacy Blogs 0
M IEC 62366-1 published - March 2015 IEC 62366 - Medical Device Usability Engineering 7
S IEC 62366 vs. FDA Human Factors Requirements Human Factors and Ergonomics in Engineering 2
Z Final Validation Unit Requirements - Annex D of IEC 62366 IEC 62366 - Medical Device Usability Engineering 6
Z IEC 62366 and Medical Device Usability Validation IEC 62366 - Medical Device Usability Engineering 10
C Application of IEC 62366 - Usability of Non-Active Medical Devices IEC 62366 - Medical Device Usability Engineering 15
T IEC 62366 included in 3rd ed IEC 60601? IEC 62366 - Medical Device Usability Engineering 1
M IEC 62366:2007 - Is FDA Usability Engineering Standard a Requirement in Canada? Canada Medical Device Regulations 5
S IEC 62366 - Embedded Software in separate Usability Engineering File? IEC 62366 - Medical Device Usability Engineering 1
J Where to buy standards such as IEC 62366:2007 Other Medical Device Related Standards 2
D Training on IEC 62366 (Medical Device Usability Engineering) for CE Mark? IEC 62366 - Medical Device Usability Engineering 5
M What do you think the revision of IEC 62366 should bring? IEC 62366 - Medical Device Usability Engineering 16
A IEC 60601-1-6 last release or IEC 62366? IEC 62366 - Medical Device Usability Engineering 17
K How to apply IEC 62366 and what shall be changed in establishing a Technical File ISO 13485:2016 - Medical Device Quality Management Systems 2
D IEC EN 62366 Usability Retroactive Compliance Other Medical Device Related Standards 1
R ISO IEC EN 62366 Usability Engineering Essential Requirements IEC 62366 - Medical Device Usability Engineering 8
P IEC 62366 vs. IEC 60601-1-6 - Has IEC 62366 now replaced IEC 60601-1-6? IEC 62366 - Medical Device Usability Engineering 19
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
JoCam IEC 60601-1 and 60601-1-2 retest after PCBA change IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 3
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E IEC 62353 normalization IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
