IEC 62368-1 / Electrical Energy Source vs. Power Source?
I'm coming from very little safety background, and am trying to wrap my head around the practical differences in IEC 62368-1 of a Power Source vs. a Electrical Energy Source.
I'm most confused in a case where we have a device that is powered from AC / DC adapter (5V, 1A), charges from a USB input, and has an internal LiPo battery (3.7V, 2A).
In some cases, I've seen the USB input & battery classified as an ES1 and PS1 source. How could this be correct?
My uninitiated reading of the standards would be that the AC Adapter / DC output would be the electrical energy source. I would think the LiPo battery would then be the Power Source?
I've looked a number of EN 62368 test reports, and I've seen a really wide divergence for these types of embedded devices in what exact component is classified as the ES or PS.
Does anyone have some high-level guidance on where the ES begins and ends, and then where the PS begins and ends?
Hello.
IEC 62368-1 defines energy sources depening on the nature of the hazard or type of injury that they may cuause to the user.
So, it is stated various types:
Electrical source is related to risk of electrical shock
Power source is related to risk of fire.
Other energy sources could be:
-Mechanical energy sources
-Radiation type source
-Chemical energy source
-Thermal energy source
Regarding to your specific question:
Electrical sources are classified taking in account only avalable voltage and current of the circuit under consideration.
Power sources are classified taking in account the total available power that the relevant circuit may supply.
They are independent classifications. For example: Your battery could be at same time ES1 ( more or less similar to SELV) and PS1 if the available power that it can supply is less than certain limit (simplifyng a lot, the limit would be 15W for PS1), but could be ES1 and PS2/PS3 if the total amount of available power that can supply is higher).
Similar procedure can be applied to the AC/DC adapter or any other energy source.
Best regards.
CharlieUK
The battery output can be PS1 due to protection circuitry, but there are additional requirements in Annex - for example a Lithium Ion battery must have a Fire Enclosure due to the electrolyte - though this Fire Enclosure might already be provided by the battery case
Le Chiffre Online training available for ISO/IEC 17021-1: Requirements for bodies providing audit and certification of management systems Training - Internal, External, Online and Distance Learning 2
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Help with BS EN ISO - IEC 80079-34 2020 (Explosive atmospheres QMS) Other ISO and International Standards and European Regulations 0
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E IEC 62353 normalization IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
T IEC 60601-1-8:2020 Is it necessary to change the alarm melody? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
S IEC 60601-2-30 - Is it mandatory to claim alarms? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M IEC 61010-1 requirements for motors Other Medical Device Related Standards 0
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
A IEC 62304 safety classification, External Controls and off-label use related risks IEC 62304 - Medical Device Software Life Cycle Processes 5
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
S IEC 62304 software costs and time Medical Device and FDA Regulations and Standards News 3
S IEC 62304 - Software verification cost IEC 62304 - Medical Device Software Life Cycle Processes 3
Sravan Manchikanti Software Risk Management & probability of occurrence as per IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
M IEC 62304 Software changes - Minor labeling changes on the GUI IEC 62304 - Medical Device Software Life Cycle Processes 3
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
R IEC 60601-1:2005+AMD1:2012+AMD2:2020 CSV IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
M What to Expect from Next IEC 60601-1 and IEC 60601-1-2 Amendments? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
T ISO/IEC 17065 certification scheme Help Other ISO and International Standards and European Regulations 7
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
K IEC 62304 - Functional and performance requirements for SOUP items IEC 62304 - Medical Device Software Life Cycle Processes 2
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
R Hand transmitted vibration 9.6.3 of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
W IEC 60601 - Essential performance c.2.34 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A IEC 62471 vs IEC/TR 62778 CE Marking (Conformité Européene) / CB Scheme 0
B IEC 61010, Touch currents related to burns at higher frequencies (cl. 6.3, A.3) Other Medical Device Related Standards 0
M IEC 61000-4-2: Requirements for coating declared as insulating IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
