IEC EN 61010 3rd Edition Safety Design Checklist
craig-c
Does anyone have a safety design checklist based on EN 61010 3rd Edition that they are willing to share?
Craig
yodon
I can't provide a checklist but we had one client recently go through the test effort and the test lab provided the following checklists (for an electronic device containing software to be used in the home environment):
* Alarms IEC 60601-1-8 (2012).doc
* Alarms, IEC 60601-1-8 (2006).doc
* Home Edition RMF IEC, 60601-1-11 Ed. 1.doc
* PEMS, IEC 60601-1 Ed. 3.0, Clause 14 (TRF G) ver. July ....doc
* PEMS, IEC 60601-1 Ed. 3.1, Clause 14 (TRF J), ver. April....doc
* Risk Process ISO 14971-1 (2007) (1).doc
* Risk Process ISO 14971-1 (2007) (2).doc
* Risk Process ISO 14971-1 (2007).doc
* Risk Process ISO 14971-1 (2000) (3).doc
* Risk Process ISO 14971-1 (2000).doc
* RMF IEC 60601-1 Ed 3.1 ver April 2014 TRF J.DOC
* RMF, IEC 60601-1 Ed. 3.0 (TRF G), ver. Dec. 2013.doc
* Software IEC 62304 (2006) Checklist.doc
* Usability IEC 60601-1-6 (2010) and 62366 (2007).doc
* Usability IEC 60601-1-6 (2013) and 62366 (2014).doc
* Usability IEC 62366 (2015) 11182015.doc
* ISO 14971-1 (2007) Checklist.doc
* ISO 14971-1 (2000) Checklist.doc
* Usability Checklist 62366-1.doc
Obviously, what's needed will depend on the type of device and the intended use environment. Point is that you might check with the test lab you use (presuming you use one) and see if they can provide applicable checklists.
Hershal
Metrologist-Auditor
Having done several assessments of the 61010 standard (including the harmonized versions), there are a few things to note.
The test labs (TLs) that support the certification bodies (CBs) rarely share their checklists with anyone but the accrediting bodies (ABs), even though due to a peer review process the others see them. Hence, between them they are generally fairly consistent. As an example, between UL, CSA, and ITS, the checklists will have differences for their own systems, but the technical content will be the same.
The technical content is based directly from the standard(s) to include the applicable -2s and any other required standards and goes test by test. Typically includes listing any and all standards applicable for that test, whether there are any already-certified components, what is under test, the test equipment (e.g., fixtures), calibrated equipment, personnel, environmental conditions, conditioning requirements if any, descriptions (beginning, end, and others points of significance), often pictures also, decision whether it meets that specific requirement, and engineering sign-offs at appropriate points. All this for every test. The CB takes all the information and determines if the item can receive the mark, and also whether a post-certification inspection requirement is needed and at what frequency.
That is why test test/certification process takes so long and is so expensive. The TLs will be accredited under ISO/IEC 17025. CBs will be accredited under ISO/IEC 17065. Inspection bodies (IBs), if post-certification inspection is required, will be accredited under ISO/IEC 17020.
Hope this helps.
T List of Tests - IEC 61010-1, 3rd edition and IEC 60601-1, 3.1 edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P IEC 61010 3rd Edition - When devices are listed to the 2nd edition CE Marking (Conformité Européene) / CB Scheme 5
H IEC 61010-1:2010/A1:2016 - Clause 10.5.3 - (b) - Interpretation CE Marking (Conformité Européene) / CB Scheme 6
H Regarding Double Insulation & Caution Symbol on Product according to IEC 61010-1 CE Marking (Conformité Européene) / CB Scheme 6
H IEC 61010-1 Clause No. 10.5 Resistance to Heat - Sub Clause 10.5.3 Insulating Material CE Marking (Conformité Européene) / CB Scheme 6
H Required explanation of sub clause 7.2.101.2 (Exception) of IEC 61010-2-020:2006 CE Marking (Conformité Européene) / CB Scheme 5
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M IEC 61010-1 requirements for motors Other Medical Device Related Standards 0
B IEC 61010, Touch currents related to burns at higher frequencies (cl. 6.3, A.3) Other Medical Device Related Standards 0
B IEC 61010-1 - Voltage / Dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J Universal Power Cord with Adapters - IVD IEC 61010-2-101 CE Marking (Conformité Européene) / CB Scheme 6
E IEC 61010-1 Dielectric strength test of inner power supply Other ISO and International Standards and European Regulations 0
G IEC 61010 - Single Fault Condition - Protective Impedance Implementation IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I IEC 61010-1 and Flammable Liquids Other ISO and International Standards and European Regulations 1
K IEC 61010-2-100 Labeling question - IVD equipment Other ISO and International Standards and European Regulations 1
F IEC 61010 Creepage and Clearence Requirements Other ISO and International Standards and European Regulations 2
G IEC 61010 Humidity Preconditioning and Condensation CE Marking (Conformité Européene) / CB Scheme 4
O IEC 61010-1 Ed 2: "Automatic Disconnection of the supply" CE Marking (Conformité Européene) / CB Scheme 3
T Is IEC 61010 needed for a populated PCB within a unit? CE Marking (Conformité Européene) / CB Scheme 2
L Does IEC 61010-1 apply for Surgical Microscopes? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
L Temperature - IEC 61010-1 ed2 & ed3 at chapter 10 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
S IEC 61010-1 and IEC 60601 - Borderline Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 10
B IEC 61010-1 Certification Requirements, and External Supply/ELV questions CE Marking (Conformité Européene) / CB Scheme 4
S Advantages of IEC 60601-1 over IEC 61010 IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Is IEC 61010-1 required for my silly little device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M IEC 60601 vs. IEC 61010 - CE Mark for our IVD medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R IEC 61010 vs IEC 60601-1 to ISO 15197 - Blood glucose monitoring device IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
T CB Scheme IEC 61010 / IEC 60601...+ NRTL mark IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K Leakage current tests for battery powered device with IEC 62368 compliant charger IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
F Defining the need to perform the Proximity magnetic fields immunity tests (IEC 61000-4-39) according to the IEC 60601-1-2 ed.4.1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M IEC 60601-1-8 clause 6.4.1 (statistics of the distribution of the sum of the maximum ALARM CONDITION + SIGNAL GENERATION DELAY) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
O ESD Testing IEC 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
T Class B IEC 62304 - 5.4 Software Detailed Design IEC 62304 - Medical Device Software Life Cycle Processes 4
E Meaning of ALARM PRESETS (subclause 6.5.1 of IEC 60601-1-8:2020) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Franky Zhang123 The Electrical Standards GB9706.1:2020 (same as IEC 60601-1:2012) etc. will be implemented on May 1st, 2023 in China. China Medical Device Regulations 0
D IEC 61000-3-2 applied at 120V and 100V IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
H IEC 62368-1 used in IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Artificial hand (IEC 60601-1-2) IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L Differences between IEC 60601-1-2 and IEC TR 60601-4-2 US Food and Drug Administration (FDA) 3
A IEC 62366-1:2015+A1:2020 IEC 62366 - Medical Device Usability Engineering 3
L EN 62304:2006/AC:2008 vs IEC 62304:2006/Amd 1:2015 IEC 62304 - Medical Device Software Life Cycle Processes 1
A IEC 62366-1:2015+A1:2020 IEC 62366 - Medical Device Usability Engineering 2
S PDF version of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P IEC 60601-2-25 requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Brexit IEC 61000-4-2 test point consideration IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
MaHoDie Is it possible to assign medical software to security class A (according to IEC 62304)? EU Medical Device Regulations 8
Richard Regalado Informational ISO/IEC 27001:2022 has been published IEC 27001 - Information Security Management Systems (ISMS) 0
F IEC 60601-2-54:2009 Accuracy of CURRENT TIME PRODUCT IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
M IEC 62366 Hazard-related Use Scenario vs FDA Critical Task EU Medical Device Regulations 3
C Sample qualification to be IEC 60601-1 series tested IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
