IEC60601 Battery powered devices intended for measuring bio-impedance
X
xavo89
Hi everyone!
We are currently designing an impedance measurement device which will also be intended for measuring bio-impedance, that is, for body measurements. Therefore, we want to know how to ensure our device is compliant with IEC60601. We have read the IEC60601-1 but we are not experts on it, so some doubts came up.
The device requires up to 4 patient connections (applied parts): two for current injection through the body and the other two for potential measuring. Current injection is limited to 375 uARMS @ 10-100 kHz. Besides, all 4 connections are ac-coupled with capacitors, so no risk of dc currents is present. This capacitors should also reduce currents of 50 Hz to a safe value. The equipment will be battery-powered (single cell rechargeable ion-Li battery) but battery charge will never be performed whenever the device is connected to the patient.
The problem is: which electrical tests should our device pass? Since it is battery powered neither earth leakage nor patient leakage current would apply, right? From this point of view, only patient auxiliary current should be tested. Any idea of what other electrical tests should our device pass?
Thank you very much!
E
esalsan
I have no electrical background and my experience with 60601 was only brief but, as I recall it you can summarise what you are trying to do, your risk analysis and the design decisions you are taking based on that risk analysis and how you are planning to test it, and contact your testing house for advice - a sort of "is this the right approach?" question.
Sometimes they can also tell you that some of the parts that are technically not applied parts will be tested as such.
Good luck!
Peter Selvey
There are roughly 1250 discrete requirements in IEC 60601-1. Most would be not applicable for a battery operated device, with the main remaining ones being related to marking, manuals, mechanical tests (e.g. drop tests), battery related items and patient auxiliary currents (normal and single fault condition).
But you still need to go through each of the 1250 items to figure out what is applicable. For example, there is a requirement for connectors hidden somewhere in there, which might be important if you use detachable cables for connecting to the electrodes.
The standard has a limit of 100uAac for patient aux current, compensated for frequencies above 1kHz. If for example your current is 375uArms at 10kHz, the compensated value would be 37.5uA (assuming a 10kHz sine wave), which would be well below the limit. You should consider also fault condition, e.g. failure of capacitor or other part which could increase the current. A simple design approach might be to break the output capacitor into two so that failure of one cannot exceed ac or dc limits.
M IEC60601-1 Battery Powered Body Worn Device Leakage Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A IEC60601-1 - Battery Charger Requirement - Home Healthcare Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
S IEC60601-1 Training recommendations Training - Internal, External, Online and Distance Learning 1
L IEC60601-1-11 Home Healthcare + IEC60601-1-2 EMC (Functional Earth allowed?) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
L Allowable AC mains fuse types for latest IEC60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
T IEC60601-1: Isolation for an applied part with working voltage of 1500Vp. IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
J IEC60601-2-18 - Endoscopic Surgical Monitor System Images IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N New EMC IEC60601-1-2 4.0 Ed. Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
B Figure A.20 of IEC60601-1 about definition of "Hand-held" & "Portable" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K IEC60601 3rd Edition Insulation Thickness for electrosurgical devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J Need for IEC60601-1 2nd edition certification? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Where to buy IEC60601-1 Symbols IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
L IEC60601-2-44 - Indicator Light Requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C Do all Class 1 Medical Devices (Electrical) have to comply with IEC60601-1? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
M Can I continue using IEC60601-1 Ed2 PSU for MOOP (Means Of Operator Protection) IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
N High Integrity Components Definition according to clause 4.9 of IEC60601-1 3rd ED IEC 60601 - Medical Electrical Equipment Safety Standards Series 43
shimonv When to do the IEC60601-1 Safety Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
S OSHA and IEC61010 and IEC60601-1 - Varied Requirements Occupational Health & Safety Management Standards 1
J Which kind of medical equipment must comply with IEC60601-1-8? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J About the Intelligent Alarm System in IEC60601-1-8 (Anaesthetic Systems) IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
N Overhaul of a 20 mm threshold -3rd Ed of IEC60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Number of changes in Amendment 1 of the 3rd Ed. of IEC60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
N Software Validation in accordance to IEC60601-1-4 IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A ILAC explanation - IEC60601-1 testing certified by an A2LA laboratory IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A USB Port Isolation as per IEC60601-1 - Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R USB Port (Signal I/O) Isolation as per IEC60601-1 - Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 40
N Ansi/aami/iso13485:2003 + Iso14971:2000 + Iec60601-1-4:2000 + Mdd93/42/eec IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
C IEC60601-1 3rd edition +ve vote - Medical Electrical Equipment Safety Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
L EN 62368 (In an Annex - M.4.2.1) Secondary Lithium Battery Charging Safeguards CE Marking (Conformité Européene) / CB Scheme 2
S Battery powered device - electrical protection requirement IEC 60601 - Medical Electrical Equipment Safety Standards Series 18
A IEC 60601-1 Dielectric Strength test for battery operated devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q EU Rep for Packaging waste, WEEE and Battery disposal CE Marking (Conformité Européene) / CB Scheme 0
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
T Battery Powered Device - MOP and Patient Auxiliary Currents IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
F IEC 62133 cell vs. Battery Pack - Certification on the cell only IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E IEC 60335-1 li-ion battery requirements Other ISO and International Standards and European Regulations 0
E CB scheme applicability for battery powered medical devices CE Marking (Conformité Européene) / CB Scheme 0
F MOPP in battery powered device with metal enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Assembly of cells into battery - Medical Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Leakage Current test and Dielectric strength for Battery operated ECG device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Battery Enclosure Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
C Lithium battery powered Medical Device - 15.3.3 Impact test, broken enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Classification of a device that uses an existing battery IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Dielectric Test of Battery Powered Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E Electrical safety (battery-powered medical device) EU Medical Device Regulations 1
L Battery requirements for medical device (US/Canada/EU) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
E Testing ME equipment powered by Battery EU Medical Device Regulations 0
